adi444 Napisano Luty 15, 2011 Zgłoszenie Share Napisano Luty 15, 2011 Witam. Chcialem odpalic minecrafta na fedorze, ale po wyrenderowaniu kilku klatek gra wisi... Wpisalem w terminalu glxinfo i wyskoczyl mi nastepujacy komunikat: name of display: :0.0 display: :0 screen: 0 direct rendering: Yes server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group client glx vendor string: Mesa Project and SGI client glx version string: 1.4 client glx extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap, GLX_INTEL_swap_event GLX version: 1.2 GLX extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_swap_control, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group OpenGL vendor string: VIA Technology OpenGL renderer string: Mesa DRI UniChrome (PM8x0/CN400) 20060710 OpenGL version string: 1.2 Mesa 7.9 OpenGL extensions: GL_ARB_draw_buffers, GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_point_parameters, GL_ARB_texture_compression, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array, GL_EXT_convolution, GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_histogram, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add, GL_EXT_texture_env_combine, GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_vertex_array, GL_APPLE_packed_pixels, GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat, GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent, GL_NV_texgen_reflection, GL_OES_read_format, GL_SGI_color_matrix, GL_SGI_color_table, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays 24 GLX Visuals visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat ---------------------------------------------------------------------------- 0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x05b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x05c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x05d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x05e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x05f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x060 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x061 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x062 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x063 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x064 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x065 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x066 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x067 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x068 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x069 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x06a 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x06b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x06c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x06d 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x06e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x06f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x070 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x042 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 Ncon 24 GLXFBConfigs: visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat ---------------------------------------------------------------------------- 0x043 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x044 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x045 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x046 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x047 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x048 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x049 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x04a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x04b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x04c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x04d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x04e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x04f 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x050 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x051 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x052 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x053 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x054 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x055 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x056 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x057 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x058 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x059 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x05a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow X Error of failed request: BadDrawable (invalid Pixmap or Window parameter) Major opcode of failed request: 137 (XFree86-DRI) Minor opcode of failed request: 9 () Resource id in failed request: 0x4600004 Serial number of failed request: 44 Current serial number in output stream: 44 Mniemam, ze cos nie tak ze sterownikami. Moja karta to VIAS3 Unichrome Pro VGA Adapter. Z tego, co udalo mi sie znalezc na forum, to sa jakies problemy ze sterownikami do tej karty... Prosze o pomoc i z góry dziekuje Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Luty 15, 2011 Zgłoszenie Share Napisano Luty 15, 2011 Nie poszalejesz z tą kartą na linuksie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adi444 Napisano Luty 16, 2011 Autor Zgłoszenie Share Napisano Luty 16, 2011 Wiem, ale chciałbym przynajmniej zmusić ją do działania Czy jest na to jakaś szansa? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Luty 16, 2011 Zgłoszenie Share Napisano Luty 16, 2011 Hmm... wysiłek wkładany w rozwój tego sterownika jest nieporównywalnie mniejszy niż w przypadku radeon (amd/ati), nouveau (nvidia) czy intel (intel), więc z akceleracją 3D może być naprawdę trudno. Nawet jak ruszy to wydajność może nie być zadowalająca. Tak dla testu, zainstaluj sobie pakiet extremetuxracer i spróbuj odpalić gierkę. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
