Brak Polaczenia Sieciowego Rtl8111/8168B Pci Express Gigabit Ethernet Controller
shino
witam,
uzywam fedory14 po ostatnim update'cie (wydaje mi sie ze byl update NetworkManager'a, ale nie pamietam) pojawil sie jakis problem z polaczeniem ethernet. jak napisano w temacie uzywam: RTL8111/8168B PCI Express Gigabit Ethernet controller. wydaje mi sie ze jest jakis problem z zaladowaniem sterownikow:
# dmesg | grep eth0
[    8.517028] r8169 0000:13:00.0: eth0: RTL8168d/8111d at 0xffffc900110ce000, f0:4d:a2:8a:4a:23, XID 083000c0 IRQ 46
[   17.592161] r8169 0000:13:00.0: eth0: link down
[   17.593578] ADDRCONF(NETDEV_UP): eth0: link is not ready
[  404.664159] r8169 0000:13:00.0: eth0: RTL8168d/8111d at 0xffffc90026a64000, f0:4d:a2:8a:4a:23, XID 083000c0 IRQ 46
[  404.701967] r8169 0000:13:00.0: eth0: link down
# lsmod
Module                  Size  Used by
r8169                  37411  0
tcp_lp                  2111  0
fuse                   61667  5
rfcomm                 67058  8
sco                    17180  2
bnep                   15390  2
l2cap                  51240  16 rfcomm,bnep
rmd160                  7984  0
crypto_null             2878  0
camellia               18447  0
lzo                     1517  0
lzo_compress            1978  1 lzo
cast6                   8757  0
cast5                  15888  0
deflate                 2143  0
zlib_deflate           18639  1 deflate
cts                     3889  0
ctr                     3813  0
gcm                    12758  0
ccm                     7799  0
serpent                19133  0
blowfish                8450  0
twofish_x86_64          5247  0
twofish_common         14366  1 twofish_x86_64
ecb                     2119  0
xcbc                    2631  0
cbc                     2953  0
sha256_generic         10175  0
sha512_generic          4788  0
des_generic            16583  0
cryptd                  7111  0
aes_x86_64              7758  0
aes_generic            26908  1 aes_x86_64
ah6                     5788  0
ah4                     5132  0
esp6                    4943  0
esp4                    5210  0
xfrm4_mode_beet         2160  0
xfrm4_tunnel            1955  0
tunnel4                 2665  1 xfrm4_tunnel
xfrm4_mode_tunnel       1895  0
xfrm4_mode_transport     1455  0
xfrm6_mode_transport     1519  0
xfrm6_mode_ro           1308  0
xfrm6_mode_beet         1969  0
xfrm6_mode_tunnel       1996  0
ipcomp                  2089  0
ipcomp6                 2122  0
xfrm_ipcomp             4305  2 ipcomp,ipcomp6
xfrm6_tunnel            4009  1 ipcomp6
tunnel6                 2516  1 xfrm6_tunnel
af_key                 27035  0
vmnet                  42780  13
ppdev                   8380  0
parport_pc             21573  0
parport                31926  2 ppdev,parport_pc
vmblock                12223  1
vsock                  39782  0
vmci                   52528  1 vsock
vmmon                  72545  0
sunrpc                201276  1
cpufreq_ondemand        9278  4
acpi_cpufreq            7345  1
freq_table              3955  2 cpufreq_ondemand,acpi_cpufreq
mperf                   1481  1 acpi_cpufreq
ip6t_REJECT             4279  2
nf_conntrack_ipv6      18078  2
ip6table_filter         1687  1
ip6_tables             17481  1 ip6table_filter
ipv6                  286354  47 ah6,esp6,xfrm6_mode_beet,xfrm6_mode_tunnel,ipcomp6,xfrm6_tunnel,tunnel6,ip6t_REJECT,nf_conntrack_ipv6
vfat                    8579  1
fat                    45956  1 vfat
uinput                  7368  0
snd_hda_codec_idt      55722  1
snd_hda_intel          24479  2
snd_hda_codec          86743  2 snd_hda_codec_idt,snd_hda_intel
snd_hwdep               6392  1 snd_hda_codec
snd_seq                53791  0
snd_seq_device          6191  1 snd_seq
snd_pcm                80190  2 snd_hda_intel,snd_hda_codec
lib80211_crypt_tkip     7987  0
uvcvideo               56073  0
wl                   2555141  0
videodev               69118  1 uvcvideo
v4l2_compat_ioctl32     7665  1 videodev
snd_timer              19892  2 snd_seq,snd_pcm
btusb                  15514  3
dell_wmi                3323  0
mii                     4310  1 r8169
snd                    63984  12 snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_seq,snd_seq_device,snd_pcm,snd_timer
dell_laptop             6477  0
wmi                     8138  1 dell_wmi
iTCO_wdt               11256  0
i2c_i801               11088  0
iTCO_vendor_support     2610  1 iTCO_wdt
dcdbas                  8524  1 dell_laptop
soundcore               6576  1 snd
bluetooth              89276  11 rfcomm,sco,bnep,l2cap,btusb
rfkill                 17622  3 dell_laptop,bluetooth
snd_page_alloc          7559  2 snd_hda_intel,snd_pcm
lib80211                5095  2 lib80211_crypt_tkip,wl
microcode              18500  0
usb_storage            45923  0
i915                  287513  4
drm_kms_helper         25961  1 i915
drm                   178014  4 i915,drm_kms_helper
i2c_algo_bit            5205  1 i915
i2c_core               27089  6 videodev,i2c_i801,i915,drm_kms_helper,drm,i2c_algo_bit
video                  21637  1 i915
output                  2253  1 video
#lspci -vnn | grep -a4 -i net
       Memory at fbc04000 (64-bit, non-prefetchable) [size=4K]
       Capabilities: [50] Power Management version 3
       Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
12:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11b/g/n Wireless LAN Controller [14e4:4727] (rev 01)
       Subsystem: Dell Device [1028:0010]
       Flags: bus master, fast devsel, latency 0, IRQ 17
       Memory at fbb00000 (64-bit, non-prefetchable) [size=16K]
       Capabilities: [40] Power Management version 3
       Capabilities: [16c] Power Budgeting <?>
       Kernel driver in use: wl
       Kernel modules: wl
13:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller [10ec:8168] (rev 03)
       Subsystem: Dell Device [1028:043f]
       Flags: bus master, fast devsel, latency 0, IRQ 46
       I/O ports at e000 [size=256]
       Memory at d0b04000 (64-bit, prefetchable) [size=4K]
# ifconfig -a
eth0      Link encap:Ethernet  HWaddr F0:4D:A2:8A:4A:23
         UP BROADCAST MULTICAST  MTU:1500  Metric:1
         collisions:0 txqueuelen:1000
         RX bytes:0 (0.0   TX bytes:0 (0.0
         Interrupt:46 Base address:0x8000
mam nadzieje, ze dolaczone outputy pomoga zdebugowac problem
Spróbuj przeladowywac sterownik az za któryms razem zaskoczy po kilku sekundach od zaladowania modulu (rmmod r8169 && modprobe r8169 && ifconfig eth0 up). Jesli sie nie uda to jest jeszcze modul r8168.
EDIT: zaskoczy, czyli w dmesg pojawi sie eth0: link up
Ile razy próbowałeś?
No tak bo tego modułu nie ma w jądrze. Musiałbyś pobrać stąd http://r8168.googlecode.com/files/r8168-8.023.00.tar.bz2 i potem zainstalować. Chociaż ja nie polecam używania tego autorun.sh tylko zamiast wpisz make clean modules i w folderze scr pojawi się moduł r8168.ko. Potem wystarczy ten plik skopiować do /lib/modules/<wersja_kernela>/kernel/drivers/net/ i załadować tak jak próbowałeś. Upewnij się, że wcześniej zrobiłeś rmmod r8169.
dzieki za odpowiedzi i sorry ze sam odpowiadam tak pozno.
LenoX: zainstalowany w fedorze firmware najwyrazniej nie ma programiku 'extract_hdr', bez ktorego nie moge update'owac biosu (albo nie wiem jak)
thof: probowalem po mnostwo razy. co do instalacji r6168 to po wrzuceniu pliku .ko to odpowiedniego katalogu nadal wyskakuje mi FATAL: Module r8168 not found
chodzi o firmware dell'owski
Mam identyczny chip na swojej płycie głównej tylko wcześniejszą rewizje, działa idealnie pod f14 (z aktualizacjami z *testing) na module r8169. Na Twoim miejscu sprawdziłbym:
- kabel sieciowy ;),
- konfigurację (/etc/sysconfig/network-scripts/ifcfg*, /etc/sysconfig/networking/devices/ifcfg*, /etc/sysconfig/networking/profiles/default/ifcfg*),
- network manager-a i może spróbował uruchomić sieć bez jego pomocy...
