Mplayer
sphinx
  • 3 weeks later...
  • 2 months later...
No tak nie specjalnie ta twoja rada działa :D
[root@localhost Mplayer]# yum install mplayer
Gathering header information file(s) from server(s)
Server: Fedora Core 2 - i386 - Base
Server: Fedora Core 2 - i386 - Released Updates
Finding updated packages
Downloading needed headers
Cannot find a package matching mplayer
No actions to take
:P
jak coś to apt -get install mplayer
ale wyskakuje coś takiego:
[root@localhost Apt]# apt-get -f install mplayer
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
Guppi-devel: Depends: Guppi (= 0.40.3) but it is not going to be installed
PyQt-devel: Depends: PyQt (= 3.11-1) but it is not going to be installed
SDL_image-devel: Depends: SDL_image (= 1.2.3) but it is not going to be installed
ant: Depends: javamail (>= 20031006-4) but it is not going to be installed
Depends: junit (>= 3.8.1-4) but it is not going to be installed
Depends: lib-javax-mail-20031006.so
Depends: lib-javax-xml-parsers-2.2.1.so
Depends: lib-javax-xml-transform-2.4.1.so
Depends: lib-org-xml-sax-2.2.1.so
Depends: libgcj.so.5
Depends: xalan-j (>= 2.4.1-14) but it is not going to be installed
Depends: xerces-j (>= 2.2.1-16) but it is not going to be installed
ant-core: Depends: javamail (>= 20031006-4) but it is not going to be installed
Depends: libgcj34 (>= 3.4.0-1) but it is not going to be installed
PreDepends: redhat-java-rpm-scripts (>= 1.0.2-2) but it is not going to be installed
arts-devel: Depends: alsa-lib-devel but it is not going to be installed
Depends: audiofile-devel but it is not going to be installed
Depends: esound-devel but it is not going to be installed
bcel: Depends: libgcj.so.5
bonobo-devel: Depends: bonobo (= 1.0.22) but it is not going to be installed
commons-logging: Depends: libgcj.so.5
gcc34-java: Depends: gcc34 (= 3.4.0-1) but it is not going to be installed
Depends: libgcj34 (>= 3.4.0) but it is not going to be installed
Depends: libgcj34-devel (>= 3.4.0) but it is not going to be installed
gd-devel: Depends: gd (= 2.0.21) but it is not going to be installed
gdk-pixbuf-devel: Depends: gdk-pixbuf-gnome (= 1:0.22.0) but it is not going to be installed
glibc-devel: PreDepends: glibc-headers but it is not going to be installed
Depends: glibc-headers (= 2.3.3) but it is not going to be installed
gnome-desktop-devel: Depends: startup-notification-devel (>= 0.5) but it is not going to be installed
gnome-libs-devel: Depends: esound-devel but it is not going to be installed
gnome-print-devel: Depends: gnome-print (= 1:0.37-9) but it is not going to be installed
gtk-doc: Depends: docbook-style-xsl but it is not going to be installed
Depends: docbook-utils but it is not going to be installed
gtkhtml-devel: Depends: gal-devel (>= 1:0.24) but it is not going to be installed
Depends: gtkhtml (= 1.1.9-8) but it is not going to be installed
Depends: libxml-devel but it is not going to be installed
jaf: Depends: libgcj.so.5
jakarta-regexp: Depends: libgcj.so.5
kdelibs-devel: Depends: kdelibs (= 6:3.2.2-4) but 6:3.2.2-6 is to be installed
lesstif-devel: Depends: lesstif (= 0.93.36) but it is not going to be installed
Depends: libMrm.so.1
Depends: libXm.so.1
libglade-devel: Depends: libglade (= 1:0.17) but it is not going to be installed
Depends: libxml-devel (>= 1.8.16) but it is not going to be installed
libgnome-devel: Depends: esound-devel but it is not going to be installed
libgnomeui-devel: Depends: esound-devel but it is not going to be installed
Depends: esound-devel (>= 1:0.2.27) but it is not going to be installed
libole2-devel: Depends: libole2 (= 0.2.4) but it is not going to be installed
librsvg2-devel: Depends: libcroco-devel but it is not going to be installed
Depends: libgsf-devel but it is not going to be installed
mplayer: Depends: aalib but it is not going to be installed
Depends: faad2 but it is not going to be installed
Depends: libaa.so.1
Depends: libdvdread but it is not going to be installed
Depends: libdvdread.so.3
Depends: libfaad.so.0
Depends: libfame but it is not going to be installed
Depends: liblirc_client.so.0
Depends: liblzo.so.1
Depends: libmad.so.0
Depends: libmp3lame.so.0
Depends: libpostproc (= 1.0-0.10.pre4.1.fc2.fr) but 1.0-0.9.20040415.1.fc1.fr is to be installed
Depends: libxvidcore.so.4
Depends: lirc but it is not going to be installed
Depends: lzo but it is not going to be installed
Depends: mplayer-fonts but it is not going to be installed
Depends: xvidcore but it is not going to be installed
openmotif-devel: Depends: libMrm.so.3
Depends: libUil.so.3
Depends: libXm.so.3
Depends: openmotif (= 2.2.3-2) but it is not going to be installed
sane-backends-devel: Depends: libieee1284-devel but it is not going to be installed
sip-devel: Depends: sip (= 3.10.1-1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Ale jest na to rada
Wpisuje apt-sell
[root@localhost Apt]# apt-shell
Welcome to the APT shell. Type "help" for more information.
apt> install mplayer
There are still broken packages. Run `check' to see them.
You can try to fix them automatically with `install -f'.
apt> check
You might want to run `install -f' to correct these.
Guppi-devel: Depends: Guppi (= 0.40.3) but it is not installed
PyQt-devel: Depends: PyQt (= 3.11-1) but it is not installed
SDL_image-devel: Depends: SDL_image (= 1.2.3) but it is not installed
ant: Depends: javamail (>= 20031006-4) but it is not installed
Depends: junit (>= 3.8.1-4) but it is not installed
Depends: xalan-j (>= 2.4.1-14) but it is not installed
Depends: xerces-j (>= 2.2.1-16) but it is not installed
ant-core: Depends: javamail (>= 20031006-4) but it is not installed
Depends: libgcj34 (>= 3.4.0-1) but it is not installed
PreDepends: redhat-java-rpm-scripts (>= 1.0.2-2) but it is not installed
arts-devel: Depends: alsa-lib-devel but it is not installed
Depends: audiofile-devel but it is not installed
Depends: esound-devel but it is not installed
bonobo-devel: Depends: bonobo (= 1.0.22) but it is not installed
gcc34-java: Depends: gcc34 (= 3.4.0-1) but it is not installed
Depends: libgcj34 (>= 3.4.0) but it is not installed
Depends: libgcj34-devel (>= 3.4.0) but it is not installed
gd-devel: Depends: gd (= 2.0.21) but it is not installed
gdk-pixbuf-devel: Depends: gdk-pixbuf-gnome (= 1:0.22.0) but it is not installed
glibc-devel: PreDepends: glibc-headers but it is not installed
Depends: glibc-headers (= 2.3.3) but it is not installed
gnome-desktop-devel: Depends: startup-notification-devel (>= 0.5) but it is not installed
gnome-libs-devel: Depends: esound-devel but it is not installed
gnome-print-devel: Depends: gnome-print (= 1:0.37-9) but it is not installed
gtk-doc: Depends: docbook-style-xsl but it is not installed
Depends: docbook-utils but it is not installed
gtkhtml-devel: Depends: gal-devel (>= 1:0.24) but it is not installed
Depends: gtkhtml (= 1.1.9-8) but it is not installed
Depends: libxml-devel but it is not installed
kdelibs-devel: Depends: kdelibs (= 6:3.2.2-4) but 6:3.2.2-6 is installed
lesstif-devel: Depends: lesstif (= 0.93.36) but it is not installed
Depends: libXm.so.1
libglade-devel: Depends: libglade (= 1:0.17) but it is not installed
Depends: libxml-devel (>= 1.8.16) but it is not installed
libgnome-devel: Depends: esound-devel but it is not installed
libgnomeui-devel: Depends: esound-devel but it is not installed
Depends: esound-devel (>= 1:0.2.27) but it is not installed
libole2-devel: Depends: libole2 (= 0.2.4) but it is not installed
librsvg2-devel: Depends: libcroco-devel but it is not installed
Depends: libgsf-devel but it is not installed
Depends: libXm.so.3
Depends: openmotif (= 2.2.3-2) but it is not installed
sane-backends-devel: Depends: libieee1284-devel but it is not installed
sip-devel: Depends: sip (= 3.10.1-1) but it is not installed
E: Unmet dependencies. Try using -f.
apt> install -f mplayer
apt> install -f
Correcting dependencies... Done
Unrequested changes are needed to execute this operation.
The following packages will be upgraded
libpostproc
The following NEW packages will be installed:
aalib faad2 lame libdvdcss libdvdread libfame libmad lirc lzo mplayer mplayer-fonts xvidcore
1 upgraded, 12 newly installed, 0 removed and 0 kept.
Will need more 9471kB of archives.
After unpacking will need more 27,7MB of disk space.
Do you want to continue? [Y/n] y
Tylko na razie nic się nie dzieje :?: :ph34r:
Poczekam i zobaczymy
:blink: Trochę to długie :unsure:
