Tomo_HKS Napisano Październik 25, 2011 Zgłoszenie Share Napisano Październik 25, 2011 (edytowane) Witam,bardzo prosilbym o pomoc w naprawie GRUBA-a.Dostaje taki komunikat w momencie gdy uruchamiam komputer.Pniej wklejam komunikat po wybraniu komendy fdisk -l: Disk /dev/sda: 80.0 GB, 80026361856 bytes 255 heads, 63 sectors/track, 9729 cylinders, total 156301488 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0xe38e50ed Device Boot Start End Blocks Id System /dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT /dev/sda2 206848 78261119 39027136 7 HPFS/NTFS/exFAT /dev/sda3 78262272 79286271 512000 83 Linux /dev/sda4 79286272 156301311 38507520 5 Extended /dev/sda5 79288320 156301311 38506496 8e Linux LVM Disk /dev/mapper/live-rw: 4294 MB, 4294967296 bytes 255 heads, 63 sectors/track, 522 cylinders, total 8388608 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/live-rw doesn't contain a valid partition table Disk /dev/mapper/live-osimg-min: 4294 MB, 4294967296 bytes 255 heads, 63 sectors/track, 522 cylinders, total 8388608 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/live-osimg-min doesn't contain a valid partition table Disk /dev/mapper/vg_komputer-LogVol02: 536 MB, 536870912 bytes 255 heads, 63 sectors/track, 65 cylinders, total 1048576 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/vg_komputer-LogVol02 doesn't contain a valid partition table Disk /dev/mapper/vg_komputer-LogVol00: 10.6 GB, 10603200512 bytes 255 heads, 63 sectors/track, 1289 cylinders, total 20709376 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/vg_komputer-LogVol00 doesn't contain a valid partition table Disk /dev/mapper/vg_komputer-LogVol01: 10.6 GB, 10603200512 bytes 255 heads, 63 sectors/track, 1289 cylinders, total 20709376 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/vg_komputer-LogVol01 doesn't contain a valid partition table Disk /dev/mapper/vg_komputer-LogVol06: 536 MB, 536870912 bytes 255 heads, 63 sectors/track, 65 cylinders, total 1048576 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/vg_komputer-LogVol06 doesn't contain a valid partition table Disk /dev/mapper/vg_komputer-LogVol04: 5368 MB, 5368709120 bytes 255 heads, 63 sectors/track, 652 cylinders, total 10485760 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/vg_komputer-LogVol04 doesn't contain a valid partition table Disk /dev/mapper/vg_komputer-LogVol05: 10.6 GB, 10603200512 bytes 255 heads, 63 sectors/track, 1289 cylinders, total 20709376 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Disk /dev/mapper/vg_komputer-LogVol05 doesn't contain a valid partition table [root@localhost ~]# Edytowane Październik 26, 2011 przez WalDo dodanie znaczników codebox Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Październik 26, 2011 Zgłoszenie Share Napisano Październik 26, 2011 (edytowane) fdisk -l niewiele mówi. A jak juz wklejasz takie "tasiemce", to korzystaj ze znaczników "codebox" (czyli tak jak poprawilem). Czy instalacja zakonczyla sie poprawnie czy tez komunikat pokazuje sie po restarcie komputera bezposrednio po instalacji? [EDIT]Podmontuj partycje /dev/sda3 i sprawdz jak wyglada jej zawartosc oraz zawartosc pliku <punkt montowania>/grub/grub.conf [/EDIT] Jesli instalacja zakonczyla sie, to spróbuj odzyskac GRUBa tak jak to opisane na naszej wiki → http://wiki.fedora.pl/wiki/GRUB#GRUB_-_jak_odzyska.C4.87.3F Edytowane Październik 26, 2011 przez WalDo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
