Xen Problem F15
Gość Łukasz
Witam
Posiadam F15 wróciłem po kilku latach do linuxa i potrzebuje wirtualizacji na XEN
Jądro moje to:
[Lukasz@Lukasz ~]$ uname -r
3.1.1
skompilowałem XEN samodzielnie w wersji 4.1.2
jednak po wydaniu polecenia: xend start
Mam to:
[root@Lukasz Lukasz]# xend start
xc: error: Could not obtain handle on privileged command interface (2 = No such file or directory): Internal error
File "/usr/sbin/xend", line 36, in <module>
from xen.xend.server import SrvDaemon
File "/usr/lib64/python2.7/site-packages/xen/xend/server/SrvDaemon.py", line 26, in <module>
import relocate
File "/usr/lib64/python2.7/site-packages/xen/xend/server/relocate.py", line 28, in <module>
from xen.xend import XendDomain
File "/usr/lib64/python2.7/site-packages/xen/xend/XendDomain.py", line 36, in <module>
from xen.xend import XendOptions, XendCheckpoint, XendDomainInfo
File "/usr/lib64/python2.7/site-packages/xen/xend/XendCheckpoint.py", line 20, in <module>
from xen.xend import balloon, sxp, image
File "/usr/lib64/python2.7/site-packages/xen/xend/image.py", line 46, in <module>
xc = xen.lowlevel.xc.xc()
xen.lowlevel.xc.Error: (1, 'Internal error', 'xc_interface_open failed: No such file or directory')
Domyślam się ze czegoś zabrakło w jądrze ,choć nie wiem czy oby (_napewno_ → na pewno) ORT? bo wynik mam taki:
[root@Lukasz linux-3.1.1]# grep -i xen .config
CONFIG_XEN=y
CONFIG_XEN_DOM0=y
CONFIG_XEN_PRIVILEGED_GUEST=y
CONFIG_XEN_PVHVM=y
CONFIG_XEN_MAX_DOMAIN_MEMORY=128
CONFIG_XEN_SAVE_RESTORE=y
CONFIG_XEN_DEBUG_FS=y
CONFIG_XEN_DEBUG=y
CONFIG_PCI_XEN=y
CONFIG_XEN_PCIDEV_FRONTEND=m
CONFIG_XEN_BLKDEV_FRONTEND=m
CONFIG_XEN_BLKDEV_BACKEND=m
CONFIG_NETXEN_NIC=m
CONFIG_XEN_NETDEV_FRONTEND=m
CONFIG_XEN_NETDEV_BACKEND=m
CONFIG_INPUT_XEN_KBDDEV_FRONTEND=m
CONFIG_HVC_XEN=y
CONFIG_XEN_WDT=m
CONFIG_XEN_FBDEV_FRONTEND=y
# Xen driver support
CONFIG_XEN_BALLOON=y
# CONFIG_XEN_SELFBALLOONING is not set
# CONFIG_XEN_BALLOON_MEMORY_HOTPLUG is not set
CONFIG_XEN_SCRUB_PAGES=y
CONFIG_XEN_DEV_EVTCHN=m
CONFIG_XEN_BACKEND=y
CONFIG_XENFS=m
CONFIG_XEN_COMPAT_XENFS=y
CONFIG_XEN_SYS_HYPERVISOR=y
CONFIG_XEN_XENBUS_FRONTEND=y
CONFIG_XEN_GNTDEV=m
CONFIG_XEN_GRANT_DEV_ALLOC=m
CONFIG_XEN_PLATFORM_PCI=m
CONFIG_SWIOTLB_XEN=y
CONFIG_XEN_TMEM=y
CONFIG_XEN_PCIDEV_BACKEND=m
Nie jestem pewien czy to tak powinno wyglądać. Proszę o wskazówkę bo mi się skończyły pomysły :)
W sumie to kompiluje tylko dlatego że zmieniłem jądro na 3.1.1. Ale zainstalowałem to z paczki rpm i zauważyłem ze nie podnosi się usługa "Xenstored - daemon managing xenstore file system" Ma ktoś pomysł dlaczego bądz jak to sprawdzić - jak mówiłem wcześniej miałem sporą przerwę w obsłudzę Linuxa, będe wdzieczny za każdą sugestie.
Zmiana jądra podyktowana była tym że wyczytałem że to co było razem z dystrybucją nie dokońca radziło sobie z XEN
Nie wiem co masz na myśli pisząc "to co było z dystrybucją", ale podstawą jest aktualizacja systemu po instalacji (chyba że korzystasz z obrazu netinst). Na F16 od kilku dni jest już jądro 3.1.1. Może warto zaktualizować system i spróbować z paczkami dystrybucyjnymi?
Jakie błędy przy uruchomieniu usługi? Co w logach? Może tradycyjnie SElinux przeszkadza?
Witam
Poszedlem za Twoją radą i zaktualizowalem do F16 i jest poprawa :) co prawda nie dokonca jeszcze działa ale ma coś takiego:
Unable to open a connection to the Xen hypervisor/daemon.
Verify that:
- A Xen host kernel was booted
- The Xen service has been started
wewnętrzny błąd Sterownik stanu biblioteki libxenlight jest nieaktywny
File "/usr/share/virt-manager/virtManager/connection.py", line 1146, in _open_thread
self.vmm = self._try_open()
File "/usr/share/virt-manager/virtManager/connection.py", line 1130, in _try_open
flags)
File "/usr/lib64/python2.7/site-packages/libvirt.py", line 102, in openAuth
if ret is None:raise libvirtError('virConnectOpenAuth() failed')
libvirtError: wewnętrzny błąd Sterownik stanu biblioteki libxenlight jest nieaktywny
Teraz pytanie gdzie go szukać czy jest to składnik kernela czy też jakaś biblioteka w postaci rpm. Jutro będe szukał, a może się orientujesz?
Ja niestety potrzebuje współdzielić urządzenia hosta a nie działać na wirtualnych, Niestesty instalacja systemu obik nie wchodzi w grę. Jak uda mi się zrobić to napiszę dla potomnych :)
PS. A VB czym różni się ten z repo ?
PS. A VB czym rózni sie ten z repo ?
W repo jest VB Open Source Edition (OSE). Nie ma obslugi USB i chyba czegos jeszcze, jakiegos protokolu, ale zabij, nie przypomne sobie.
[EDIT]
Naklamalem :rolleyes: Tak jak napisalem, to do wersji 3. bylo. Teraz, od wersji 4.0, nie ma zadnej róznicy. Zamkniety kod do obslugi m.in. USB jest dystrybuowany w paczce z rozszerzeniami.
https://www.virtualbox.org/wiki/Editions
Edytowane przez WalDo
Już jestem na finiszu czy ktoś mogłby mi podrzucić lub powiedzieć gdzie leży file.spec do xen 4.1.1 bo mam wrażenie że ten ma jeszcze dużo błedów a by mi się przydało zrobić paczkę pod F16. Nigdy natomiast sam nie robiłem File.spec więc nawet cieżko mi cokolwiek wytworzyć samodzielnie. Pozdrdzaiam
W zamian za to opiszę na forum jak odpalić XEN pod F16
np. tutaj masz link do pliku *.src.rpm → http://rpm.pbone.net/index.php3/stat/4/idpl/16980026/dir/fedora_15/com/xen-4.1.1-3.fc15.i686.rpm.html
Sciagnij src.rpm, otworz w Krusaderze albo MC.
Mozesz oczywiscie sciagnac src.rpm i po prostu przebudowac pod F16 - powinno pójsc ;)
Odpaliłem XEN i zainstalowałem Windows Vista Ultimate OEM i wszystko pięknie do chwili aktywacji systemu gdzie mi wywaliło okienko "Musisz mieć 2 klucz blblb" Zgodnie z licencją można zwirtualizować jedną maszynę pod warunkiem ze będzie to ten sam sprzęt (tak jest u mnie) host Linux WM Vista.
http://forum.dobreprogramy.pl/instalacja-windowsa-licencji-oem-hypervisorze-xen-t450641.html zasugierowałem się tym i jak sądzisz tyle dni poszło psu na budę czy coś idzie z tym zrobić?
Mialem raczej na mysli 1. zdanie z tamtej wypowiedzi: "Niestety wirtualizacja Xen jest mi obca" ;)
[EDIT]
Co do Windows to wiem jeszcze mniej, ale tak na czuja... Instalowales Viste wczesniej na fizycznej maszynie z ta licencja, wiec nic dziwnego ze na WM chce innego klucza. OEM to OEM, jest nieprzenosny (przynajmniej w teorii)
