Eslay Napisano Luty 25, 2012 Zgłoszenie Share Napisano Luty 25, 2012 (edytowane) Witam staralem sie troche "pobawic" fedora i czegos nauczyc jednak przekombinowalem i nie wiem jak to naprawic a przeszukalem juz nie jedno forum ... problem mam a przynajmniej tak mi sie wydaje z repozytoriami ... przy kazdej instalacji jakiegos programu wyskakuje mi : [root@QUEEN yum.repos.d]# yum install mirrormanager-client Loaded plugins: langpacks, presto, refresh-packagekit Could not retrieve mirrorlist http://ayo.freshrpms.net/fedora/linux/16/mirrors-freshrpms error was 14: HTTP Error 404 - Not Found : http://ayo.freshrpms.net/fedora/linux/16/mirrors-freshrpms Error: Cannot retrieve repository metadata (repomd.xml) for repository: freshrpms. Please verify its path and try again Moja lista repo to : [root@QUEEN yum.repos.d]# su -c 'ls -l /etc/yum.repos.d/' total 72 -rw-r--r--. 1 root root 179 Jul 25 2007 adobe-linux-i386.repo -rw-r--r--. 1 root root 183 Apr 1 2011 adobe-linux-x86_64.repo -rw-r--r--. 1 root root 1144 Oct 25 06:50 fedora.repo -rw-r--r--. 1 root root 1105 Oct 25 06:50 fedora-updates.repo -rw-r--r--. 1 root root 1163 Oct 25 06:50 fedora-updates-testing.repo -rw-r--r--. 1 root root 354 Jun 28 2005 freshrpms.repo -rw-r--r--. 1 root root 114 Feb 21 20:27 google-chrome.repo -rw-r--r--. 1 root root 1070 Dec 6 2008 livna.repo -rw-r--r--. 1 root root 621 May 9 2010 remi.repo -rw-r--r--. 1 root root 645 May 1 2010 remi.repo.1 -rw-r--r--. 1 root root 961 Sep 18 14:24 russianfedora-free-rawhide.repo -rw-r--r--. 1 root root 988 Sep 18 14:24 russianfedora-free.repo -rw-r--r--. 1 root root 1009 Sep 18 14:24 russianfedora-free-updates.repo -rw-r--r--. 1 root root 1071 Sep 18 14:24 russianfedora-free-updates-testing.repo -rw-r--r--. 1 root root 1000 Sep 18 14:25 russianfedora-nonfree-rawhide.repo -rw-r--r--. 1 root root 1027 Sep 18 14:25 russianfedora-nonfree.repo -rw-r--r--. 1 root root 1048 Sep 18 14:25 russianfedora-nonfree-updates.repo -rw-r--r--. 1 root root 1110 Sep 18 14:25 russianfedora-nonfree-updates-testing.repo Znalazlem raz na forum taka porade aby usunac repo z którym jest problem i staralem sie to zrobic z takim efektem: [root@QUEEN yum.repos.d]# yum update --disablerepo=freshrpms Loaded plugins: langpacks, presto, refresh-packagekit Setting up Update Process No Packages marked for Update Nie wiem juz co robic bardzo prosze o jakies porady ;] Edytowane Luty 25, 2012 przez WalDo zmiana znaczników codebox ? code Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 25, 2012 Zgłoszenie Share Napisano Luty 25, 2012 Pokaz liste wlaczonych repozytoriów yum repolist Jesli wszystkie sa wlaczone, tzn. ze masz aktualny system i stad komunikat "No Packages marked for Update" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Eslay Napisano Luty 26, 2012 Autor Zgłoszenie Share Napisano Luty 26, 2012 (edytowane) Pokaz liste wlaczonych repozytoriów yum repolist Jesli wszystkie sa wlaczone, tzn. ze masz aktualny system i stad komunikat "NoPackages marked forUpdate" oto wynik tej komenty Loaded plugins: langpacks, presto, refresh-packagekit adobe-linux-i386 | 951 B 00:00 adobe-linux-i386/primary | 11 kB 00:03 adobe-linux-x86_64 | 951 B 00:00 adobe-linux-x86_64/primary | 1.2 kB 00:00 fedora/metalink | 31 kB 00:01 fedora | 4.2 kB 00:00 fedora/primary_db | 12 MB 02:54 fedora/group_gz | 431 kB 00:07 Could not retrieve mirrorlist [url="http://ayo.freshrpms.net/fedora/linux/16/mirrors-freshrpms"]http://ayo.freshrpms...rrors-freshrpms[/url] error was 14: HTTP Error 404 - Not Found : [url="http://ayo.freshrpms.net/fedora/linux/16/mirrors-freshrpms"]http://ayo.freshrpms...rrors-freshrpms[/url] google-chrome | 951 B 00:00 google-chrome/primary | 1.4 kB 00:00 livna | 3.6 kB 00:00 livna/primary_db | 3.4 kB 00:00 livna/group_gz | 464 B 00:00 russianfedora-free | 3.6 kB 00:00 russianfedora-free/primary_db | 53 kB 00:01 russianfedora-free/group_gz | 2.2 kB 00:00 russianfedora-free-updates | 3.6 kB 00:00 russianfedora-free-updates/primary_db | 49 kB 00:01 russianfedora-free-updates/group_gz | 2.2 kB 00:00 russianfedora-nonfree | 3.6 kB 00:00 russianfedora-nonfree/primary_db | 30 kB 00:00 russianfedora-nonfree/group_gz | 1.6 kB 00:00 russianfedora-nonfree-updates | 3.6 kB 00:00 russianfedora-nonfree-updates/primary_db | 32 kB 00:01 russianfedora-nonfree-updates/group_gz | 1.6 kB 00:00 updates/metalink | 25 kB 00:01 updates | 4.5 kB 00:00 updates/primary_db | 4.0 MB 02:52 updates/group_gz | 431 kB 00:08 adobe-linux-i386 17/17 adobe-linux-x86_64 2/2 repo id repo name status adobe-linux-i386 Adobe Systems Incorporated 17 adobe-linux-x86_64 Adobe Systems Incorporated 2 fedora Fedora 16 - i386 20,176 freshrpms Fedora Core 16 - i386 - Freshrpms 0 google-chrome google-chrome 0 livna rpm.livna.org for 16 - i386 0 russianfedora-free Russian Fedora for Fedora 16 - Free 0 russianfedora-free-updates Russian Fedora for Fedora 16 - Free - Updates 0 russianfedora-nonfree Russian Fedora for Fedora 16 - Nonfree 0 russianfedora-nonfree-updates Russian Fedora for Fedora 16 - Nonfree - Updates 0 updates Fedora 16 - i386 - Updates 0 repolist: 20,195 Gdy staram sie to samo zrobic pod rootem jak juz sie to zakonczy na userze to wysakuje mi jakby ktos jeszcze korzystal z yum co jest niemozliwe Another app is currently holding the yum lock; waiting for it to exit... The other application is: PackageKit Memory : 30 M RSS ( 53 MB VSZ) Started: Sun Feb 26 17:20:12 2012 - 07:00 ago State : Sleeping, pid: 2060 Edytowane Luty 26, 2012 przez WalDo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Luty 26, 2012 Zgłoszenie Share Napisano Luty 26, 2012 Repozytoria livna i fresrpms są przestarzałe i do wywalenia. Jeśli instalowałeś je za pomocą paczek, to, np. dla livna: rpm -qa | grep livna rpm -e wynik_wyszukiwania #będzie coś w stylu livna-release, freshrpms-release Jeśli rpm nie znajdzie żadnych pakietów, to usuń po prostu odpowiednie pliki *.repo. W russian-fedora jest flash, opera, itp. jeśli korzystałeś to zostaw, ale wtedy raczej usunąłbym repozytoria Adobe, które masz dla obu architektur. Jak dla mnie najprostsza droga do uporządkowania tego bałaganu to zostawić tylko repozytoria fedora*.repo, dodać rpmfusion - http://rpmfusion.org/Configuration/ i resztę dodawać w razie potrzeby. Komunikat o blokowaniu yuma oznacza że masz zainstalowany Packagekit, który sprawdza dostępność aktualizacji i w razie potrzeby poinformuje o nich stosownym "dymkiem". Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 26, 2012 Zgłoszenie Share Napisano Luty 26, 2012 [...] i w razie potrzeby poinformuje o nich stosownym "dymkiem".Albo instaluje bez gadania i stad komunikat o braku aktualizacji z postu #1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
