dex99 Napisano Kwiecień 7, 2012 Zgłoszenie Share Napisano Kwiecień 7, 2012 Miałem Fedorę 15 z KDE. Po przejściu na Gnome 3 pojawił się dziwny problem z yumem. Kiedy chcę zainstalować jakiś program to leci mi taki oto error Traceback (most recent call last): File "/usr/bin/yum", line 29, in <module> yummain.user_main(sys.argv[1:], exit_code=True) File "/usr/share/yum-cli/yummain.py", line 267, in user_main errcode = main(args) File "/usr/share/yum-cli/yummain.py", line 161, in main (result, resultmsgs) = base.buildTransaction() File "/usr/lib/python2.7/site-packages/yum/__init__.py", line 951, in buildTransaction (rescode, restring) = self.resolveDeps() File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 753, in resolveDeps for po, dep in self._checkFileRequires(): File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 1007, in _checkFileRequires self.installedFileProviders = self.rpmdb.fileRequiresData() File "/usr/lib/python2.7/site-packages/yum/rpmsack.py", line 892, in fileRequiresData rpmdbv = self.simpleVersion(main_only=True)[0] File "/usr/lib/python2.7/site-packages/yum/rpmsack.py", line 1122, in simpleVersion if 'checksum_type' in ydbi and 'checksum_data' in ydbi: File "/usr/lib/python2.7/site-packages/yum/rpmsack.py", line 1833, in __contains__ x = self.get(attr) File "/usr/lib/python2.7/site-packages/yum/rpmsack.py", line 1863, in get res = self._read(attr) File "/usr/lib/python2.7/site-packages/yum/rpmsack.py", line 1780, in _read info = misc.stat_f(fn) File "/usr/lib/python2.7/site-packages/yum/misc.py", line 943, in stat_f return os.stat(filename) OSError: [Errno 20] Nie jest katalogiem: '/var/lib/yum/yumdb/x/31dd12988362e2bfc522bb0f5168d938fcb804d5-xpp2-2.1.10-9.3.fc15-noarch/checksum_type' Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Kwiecień 7, 2012 Zgłoszenie Share Napisano Kwiecień 7, 2012 Mocno watpie, ze jest to zwiazane z przelaczeniem na inny desktop Zacznij od wyczyszczenia cache'a yum clean all Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dex99 Napisano Kwiecień 7, 2012 Autor Zgłoszenie Share Napisano Kwiecień 7, 2012 Tez mam watpliwosci, ale ten error sie pojawil dokladnie kiedy pierwszy raz uzylem yuma na gnome 3 stad ten wniosek. Clean all oczywiscie próbowalem juz wczesniej, nic nie dalo. --edit-- Chyba wystarczylo usunac plik /var/lib/yum/yumdb/x/31dd12988362e2bfc522bb0f5168d938fcb804d5-xpp2-2.1.10-9.3.fc15-noarch bo po tej operacji yum juz dziala Przepraszam za niepotrzebne zawracanie glowy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
