Rtl8187B - Wifi Nie Działa
deepblu
Fedora 16.
Tosioba satelite L40-170.
lsusb:
Bus 001 Device 002: ID 0bda:8197 Realtek Semiconductor Corp. RTL8187B Wireless Adapter
lsmod:
rtl8187 56132 0
mac80211 427444 1 rtl8187
cfg80211 169437 2 rtl8187,mac80211
eeprom_93cx6 12952 1 rtl8187
ifconfig -a:
wlan0 Link encap:Ethernet HWaddr 00:16:44:A1:31:B8
BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b ) TX bytes:0 (0.0 b )
Mimo to nie moge wlaczyc wif.
Jest jakas szansa na uruchomienie wifi ???
Podkreslam: to nie jest RTL8187 tylko RTL8187B.
  • 4 months later...
Moze to? http://askubuntu.com/questions/62166/siocsifflags-operation-not-possible-due-to-rf-kill
No i po prostu poszukaj komunikatu bledu moze cos Ci przyjdzie do glowy https://www.google.pl/search?q=SIOCSIFFLAGS%3A+Operation+not+possible+due+to+RF-kill&sugexp=chrome,mod=9&sourceid=chrome&ie=UTF-8
[EDIT & OFFTOPIC] :)
W tym tempie to juz w okolicach Fedory 22-23 bedzie rozwiazany temat.
lshw -class network
 *-network
   description: Ethernet interface
   product: RTL-8139/8139C/8139C+
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 7
   bus info: pci@0000:05:07.0
   logical name: em1
   version: 10
   serial: 00:1e:8c:e8:ef:98
   capacity: 100Mbit/s
   width: 32 bits
   clock: 33MHz
   capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=full ip=192.168.1.100 latency=64 link=yes maxlatency=64 mingnt=32 multicast=yes port=MII speed=100Mbit/s
   resources: irq:16 ioport:c800(size=256) memory:fe6ffc00-fe6ffcff
 *-network DISABLED
   description: Wireless interface
   physical id: 1
   bus info: usb@1:2
   logical name: wlan0
   serial: 00:16:44:a1:31:b8
   capabilities: ethernet physical wireless
   configuration: broadcast=yes driver=rtl8187 driverversion=3.4.9-2.fc16.i686.PAE firmware=N/A link=no multicast=yes wireless=IEEE 802.11bg
rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
Co to moze oznaczac: Hard blocked: yes ?
Jak klikam klawisz funkcyjny i klawisz wifi to Soft blocked mi sie zmienia z "no" na "yes" i z powrotem, ale Hard blocked dalej jest: yes.
A jeszcze:
 lshw -businfo
usb@1:2		   wlan0	   network	 Wireless interface
Nie mam pojecia, ale zdobywanie wiedzy zaczalbym od https://www.google.pl/search?q=rfkill+Hard+blocked%3A+yes&sugexp=chrome,mod=9&sourceid=chrome&ie=UTF-8
Oczywiscie pamietajac, ze nie wszystko co sprawdza sie pod Ubuntu musi zadzialac pod Fedora, ale w tym wypadku nie powinno byc duzych róznic.
A tak w ogóle, to masz to przed czy po wykonaniu tego odblokowania, o którym pisza?
A sprawdzales czy dziala czy od razu zaczales myslec czemu masz hard block: yes? Oczywiscie sprawdzenie przy soft block: no. Jest troche mozliwosci, wiec po prostu musisz systematycznie sprawdzac kolejne kombinacje (nie bedzie ich w koncu tak duzo).
Zajrzalbym tez na bugzille - moze ktos mial podobny problem i go zglosil.
[OFFTOPIC]
Co do czekania na F22...
Czekales 5 miesiecy z kolejnym postem i jak widac nic sie nie zmienilo :) Problemy odlozone na pólke na ogól nie znikaja.
Mozesz oczywiscie czekac liczac, ze pojawi sie ktos kto ma dokladnie ten sam sprzet i udalo mu sie okielznac taki problem, ale nie musi to byc wcale uzytkownik tego forum.
Mozesz sie równiez poddac. Biorac pod uwage czestotliwosc wykorzystania sprzetu, to nie bedzie jakis dramat :D
