Problem Podczas Kompilacji Sterowników
DePrimota
Witam Mój problem polega na tym iz podczas kompilacji poleceniem make install ze zródla wyskakuje blad.
make install
./set_revision.sh
make -C /lib/modules/3.3.2-6.fc16.x86_64/build CONFIG_LINE6_USB=m SUBDIRS=/root/line6usb modules
make[1]: Entering directory `/usr/src/kernels/3.3.2-6.fc16.x86_64'
 CC [M]  /root/line6usb/audio.o
/root/line6usb/audio.c: In function ‘line6_init_audio’:
/root/line6usb/audio.c:30:57: error: ‘THIS_MODULE’ undeclared (first use in this function)
/root/line6usb/audio.c:30:57: note: each undeclared identifier is reported only once for each function it appears in
make[2]: *** [/root/line6usb/audio.o] Error 1
make[1]: *** [_module_/root/line6usb] Error 2
make[1]: Leaving directory `/usr/src/kernels/3.3.2-6.fc16.x86_64'
make: *** [default] Error 2
dolaczam takze kod pliku w którym chyba wystepuje problem:
#include <sound/core.h="">
#include <sound/initval.h="">
#include "driver.h"
#include "audio.h"
static int line6_index[sNDRV_CARDS] = SNDRV_DEFAULT_IDX;
static char *line6_id[sNDRV_CARDS] = SNDRV_DEFAULT_STR;
	Initialize the Line6 USB audio system.
int line6_init_audio(struct usb_line6 *line6)
	static int dev;
	struct snd_card *card;
	int err;
	err = snd_card_create(line6_index[dev], line6_id[dev], THIS_MODULE, 0,
						  &card);
	if (err < 0)
			return err;
   line6->card = card;
	strcpy(card->id, line6->properties->id);
	strcpy(card->driver, DRIVER_NAME);
	strcpy(card->shortname, line6->properties->name);
	/* longname is 80 chars - see asound.h */
	sprintf(card->longname, "Line6 %s at USB %s", line6->properties->name,
			dev_name(line6->ifcdev));
	return 0;
	Register the Line6 USB audio system.
int line6_register_audio(struct usb_line6 *line6)
	int err;
	err = snd_card_register(line6->card);
  if (err < 0)
			return err;
	return 0;
	Cleanup the Line6 USB audio system.
void line6_cleanup_audio(struct usb_line6 *line6)
	struct snd_card *card = line6->card;
	if (card == NULL)
			return;
	snd_card_disconnect(card);
	snd_card_free(card);
	line6->card = NULL;
Wie ktos jak temu zaradzic?
Edytowane przez WalDo
edycja znaczników
  • Downvote 1
Andrew: Pobralem najnowsza paczke która trzeba skompilowac.
Miszcz: Line6 POD Studio UX2
Juz sobie poradzilem z tym problemem. Nowe jadro potrzebuje potrzebuje naglówka "#include <linux/export.h>" w pliku "audio.c". Tylko szkoda, ze nie wszystko dziala na tym sterowniku tak jak powinno, pozostaje tylko czekac na finalna wersje.
