deepblu Napisano Lipiec 18, 2012 Zgłoszenie Share Napisano Lipiec 18, 2012 Nagrałem płytę dvd F17 i upgradowałem z niej F16 do F17. Poszło ok. Następnie yum upgrade i tu miałem mnóstwo kłopotów z którymi sobie poradziłem, ale jest problem z którym nie wiem co zrobić. yum upgrade i teraz dostaję Resolving Dependencies --> Running transaction check ---> Package kmod.x86_64 0:7-1.fc17 will be updated ---> Package kmod.x86_64 0:7-2.fc17 will be an update --> Processing Dependency: /sbin/depmod for package: 1:kmod-nvidia-3.4.2-1.fc16.x86_64-295.59-1.fc16.1.x86_64 Package module-init-tools-3.16-5.fc17.x86_64 is obsoleted by kmod-7-1.fc17.x86_64 which is already installed --> Processing Dependency: /sbin/depmod for package: 1:kmod-nvidia-3.4.2-1.fc16.x86_64-295.59-1.fc16.1.x86_64 Package module-init-tools-3.16-5.fc17.x86_64 is obsoleted by kmod-7-1.fc17.x86_64 which is already installed --> Processing Dependency: /sbin/depmod for package: 1:kmod-nvidia-3.4.4-4.fc16.x86_64-295.59-1.fc16.3.x86_64 Package module-init-tools-3.16-5.fc17.x86_64 is obsoleted by kmod-7-1.fc17.x86_64 which is already installed --> Processing Dependency: /sbin/depmod for package: 1:kmod-nvidia-3.4.4-4.fc16.x86_64-295.59-1.fc16.3.x86_64 Package module-init-tools-3.16-5.fc17.x86_64 is obsoleted by kmod-7-1.fc17.x86_64 which is already installed --> Finished Dependency Resolution Error: Package: 1:kmod-nvidia-3.4.4-4.fc16.x86_64-295.59-1.fc16.3.x86_64 (@rpmfusion-nonfree-updates/16) Requires: /sbin/depmod Removing: kmod-7-1.fc17.x86_64 (@fedora) Not found Updated By: kmod-7-2.fc17.x86_64 (updates) Not found Available: module-init-tools-3.16-5.fc17.x86_64 (fedora) Not found Error: Package: 1:kmod-nvidia-3.4.2-1.fc16.x86_64-295.59-1.fc16.1.x86_64 (@rpmfusion-nonfree-updates/16) Requires: /sbin/depmod Removing: kmod-7-1.fc17.x86_64 (@fedora) Not found Updated By: kmod-7-2.fc17.x86_64 (updates) Not found Available: module-init-tools-3.16-5.fc17.x86_64 (fedora) Not found You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest Więc próbuję: sudo yum upgrade kmod z takim samym skutkiem. Próbuję dalej: yum uprade module-init-tools i dalej to samo. Więc próbuję: yum reinstall module-init-tools Reinstall 1 Package Total download size: 66 k Installed size: 128 k Is this ok [y/N]: y Downloading Packages: kmod-7-1.fc17.x86_64.rpm | 66 kB 00:03 Running Transaction Check Running Transaction Test Transaction Test Succeeded Running Transaction Installing : kmod-7-1.fc17.x86_64 1/1 Verifying : kmod-7-1.fc17.x86_64 1/1 Installed: kmod.x86_64 0:7-1.fc17 Complete! i dalej yum reinstall kmod Reinstall 1 Package Total download size: 66 k Installed size: 128 k Is this ok [y/N]: y Downloading Packages: kmod-7-1.fc17.x86_64.rpm | 66 kB 00:00 Running Transaction Check Running Transaction Test Transaction Test Succeeded Running Transaction Installing : kmod-7-1.fc17.x86_64 1/1 Verifying : kmod-7-1.fc17.x86_64 1/1 Installed: kmod.x86_64 0:7-1.fc17 Complete! Ale kiedy próbuję ponownie upgradeować "yum upgrade" to znowu wywala mi ten sam błąd. ------------------ Pomocy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Lipiec 18, 2012 Zgłoszenie Share Napisano Lipiec 18, 2012 Oczysc sobie pole dzialania Odinstaluj na razie kmod-nvidia i jesli instalowales akmod-nvidia to tez wywal, restart, zaktualizuj system i zainstaluj na nowo kmod-nvidia. 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
deepblu Napisano Lipiec 20, 2012 Autor Zgłoszenie Share Napisano Lipiec 20, 2012 Super, dzieki :-) Odinstalowalem: - akmod-nvidia, - wszystkie kmod-nvidia Potem yum upgrade I potem zainstalowalem akmod-nvidia i kmod-nvidia. Dziala :-) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
