Problem Z Yum
tedew
witam
jak wpisze yum install nazwa_czegos
to wywala :
You have enabled checking of packages via GPG keys. This is a good thing.
However, you do not have any GPG public keys installed. You need to download
the keys for packages you wish to install and install them.
You can do that by running the command:
rpm --import public.gpg.key
For more information contact your distribution or package provider.
po wywolaniu:
dostaje taka odp:
error : public.gpg.key : import read falied
podro
error
witam
to wywala :
po wywolaniu:
dostaje taka odp:
podro
error
You need to download the keys for packages you wish to install and install them - tu masz napisane , zeby najpierw sciagnac klcz publiczny , a dopiero potem rpt --imprt ....
Gość
