Centos Haldaemon Nie Startuje
Juve
Witam!
System w zasadzie 'nowy'. Postawiony serwer dhcpd, ssh i apache + squid. Z działaniem nie mam żadnego problemu.
Nic w plikach konfiguracyjnych systemu nie było grzebane oprócz ustawień kart sieciowych.
Po reboocie przestała odpowiadać klawiatura i myszka.
Ręczny start daje 'failed'
[root@ log]# cat boot.log
udevd[87]: worker [187] unexpectedly returned with status 0x0100
udevd[87]: worker [187] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:02/device:03'
udevd[87]: worker [188] unexpectedly returned with status 0x0100
udevd[87]: worker [188] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:02/device:08'
udevd[87]: worker [189] unexpectedly returned with status 0x0100
udevd[87]: worker [189] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:0a/device:0b'
udevd[87]: worker [190] unexpectedly returned with status 0x0100
udevd[87]: worker [190] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/IBM3737:00'
udevd[87]: worker [192] unexpectedly returned with status 0x0100
udevd[87]: worker [192] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0100:00'
udevd[87]: worker [196] unexpectedly returned with status 0x0100
udevd[87]: worker [196] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0800:00'
udevd[87]: worker [198] unexpectedly returned with status 0x0100
udevd[87]: worker [198] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0B00:00'
udevd[87]: worker [199] unexpectedly returned with status 0x0100
udevd[87]: worker [199] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0C02:00'
udevd[87]: worker [200] unexpectedly returned with status 0x0100
udevd[87]: worker [200] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0C04:00'
udevd[87]: worker [204] unexpectedly returned with status 0x0100
udevd[87]: worker [204] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0A05:00/PNP0401:00'
udevd[87]: worker [206] unexpectedly returned with status 0x0100
udevd[87]: worker [206] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0A05:00/PNP0501:00'
udevd[87]: worker [197] unexpectedly returned with status 0x0100
udevd[87]: worker [197] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0A05:00/PNP0303:00'
udevd[87]: worker [211] unexpectedly returned with status 0x0100
udevd[87]: worker [211] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0A05:00/PNP0501:01'
udevd[87]: worker [212] unexpectedly returned with status 0x0100
udevd[87]: worker [212] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0A05:00/PNP0700:00'
udevd[87]: worker [216] unexpectedly returned with status 0x0100
udevd[87]: worker [216] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0A05:00/PNP0F13:00'
udevd[87]: worker [191] unexpectedly returned with status 0x0100
udevd[87]: worker [191] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0000:00'
udevd[87]: worker [194] unexpectedly returned with status 0x0100
udevd[87]: worker [194] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:12/PNP0200:00'
udevd[87]: worker [201] unexpectedly returned with status 0x0100
udevd[87]: worker [201] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:13/device:14'
udevd[87]: worker [202] unexpectedly returned with status 0x0100
udevd[87]: worker [202] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:13/device:17'
udevd[87]: worker [207] unexpectedly returned with status 0x0100
udevd[87]: worker [207] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:1a/MGMT201:00'
udevd[87]: worker [208] unexpectedly returned with status 0x0100
udevd[87]: worker [208] failed while handling '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:1a/MGMT201:01'
                Welcome to CentOS
Starting udev:                                             [  OK  ]
Setting hostname                      [  OK  ]
Setting up Logical Volume Management:   No volume groups found
                                                           [  OK  ]
Checking filesystems
_CentOS-6.4-i386: clean, 83258/966656 files, 622961/3840000 blocks
/dev/sda1: clean, 46/51200 files, 55479/204800 blocks
/dev/sda2: clean, 33094/2949120 files, 531676/11776000 blocks
                                                           [  OK  ]
Remounting root filesystem in read-write mode:             [  OK  ]
Mounting local filesystems:                                [  OK  ]
Enabling local filesystem quotas:                          [  OK  ]
Enabling /etc/fstab swaps:                                 [  OK  ]
Entering non-interactive startup
Calling the system activity data collector (sadc):
iptables: Applying firewall rules:                         [  OK  ]
Starting portreserve:                                      [  OK  ]
Starting system logger:                                    [  OK  ]
Enabling p4-clockmod driver (passive cooling only):        [  OK  ]
Starting irqbalance:                                       [  OK  ]
Starting rpcbind:                                          [  OK  ]
Starting lldpad:                                           [  OK  ]
Starting FCoE initiator service:                           [  OK  ]
Starting system message bus:                               [  OK  ]
Setting network parameters...                              [  OK  ]
Starting NetworkManager daemon:                            [  OK  ]
Starting NFS statd:                                        [  OK  ]
Initializing OpenCT smart card terminals:                  [  OK  ]
Starting RPC idmapd:                                       [  OK  ]
Starting cups:                                             [  OK  ]
Starting acpi daemon:                                      [  OK  ]
Starting HAL daemon:                                       [FAILED]
Retrigger failed udev events                               [  OK  ]
Starting PC/SC smart card daemon (pcscd):                  [  OK  ]
Loading autofs4:                                           [  OK  ]
Starting automount:                                        [  OK  ]
Starting sshd:                                             [  OK  ]
Starting mysqld:                                           [  OK  ]
Starting dhcpd:                                            [FAILED]
Starting postfix:                                          [  OK  ]
Starting httpd:                                            [  OK  ]
Starting radiusd:                                          [  OK  ]
Starting crond:                                            [  OK  ]
Starting squid: .                                          [  OK  ]
Starting VNC server: no displays configured                [FAILED]
Starting atd:                                              [  OK  ]
Gdzie znajdują jakieś bardziej szczegółowe logi hala?
Jeśli zmieniłeś coś z sieciówką, to mogły się pomieszać nazwy plików urządzeń, mają teraz inne numery i stąd zamieszanie. Ja bym nie wnikając w nature problemu zrobił:
udevadm control --reload-rules
udevadm trigger
i się "powinno naprawić". A jeśli wolisz najpierw sprawdzić co psuje start systemu:
udevadm --export-db >> /jakiś/plik.txt
i znajdź urządzenia, o których mówią błędy.
