loloo Napisano Grudzień 2, 2013 Zgłoszenie Share Napisano Grudzień 2, 2013 Mam mały problem z instalacją programu z archiwum tar.gz wypakowałem zawartość poleceniem tar -xvzf VisualBoyAdvance-src-1.7.2.tar.gz następnie wchodzę do folderu wpisuję ./configure i pokazuje mi się następujący komunikat checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu checking target system type... x86_64-unknown-linux-gnu checking for a BSD-compatible install... /bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking for bison... bison -y checking for flex... flex checking for yywrap in -lfl... no checking for yywrap in -ll... no checking lex output file root... lex.yy checking whether yytext is a pointer... no checking for g++... no checking for c++... no checking for gpp... no checking for aCC... no checking for CC... no checking for cxx... no checking for cc++... no checking for cl... no checking for FCC... no checking for KCC... no checking for RCC... no checking for xlC_r... no checking for xlC... no checking whether we are using the GNU C++ compiler... no checking whether g++ accepts -g... no checking dependency style of g++... none checking for ranlib... ranlib checking for nasm... /bin/nasm checking for gzopen in -lz... yes checking for png_create_write_struct in -lpng... no configure: error: *** Cannot compile without libpng. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jusko Napisano Grudzień 2, 2013 Zgłoszenie Share Napisano Grudzień 2, 2013 Paczka, którą ściągnąłeś jest przeznaczona do kompilacji programu. Jeśli nie kompilowałeś niczego wcześniej, proces może być dla Ciebie obcy, a do samej kompilacji potrzebujesz odpowiednich pakietów developerskich (devel), dla każdej aplikacji będą to inne, indywidualne, zależne od użytych bibliotek do napisania programu, ale pakiety takie są w repo. W repo znajduje się także emulator GBA, VBAM, to bardziej dobracowany fork VisualBoyAdvance (mówię teraz z pomocą Wikipedii, bo sam nie używałem od lat emulatorów GBA). Zainstaluj i sprawdź, powinien spełnić oczekiwania, szczególnie jako fork VBA. yum install vbam-gtk Ewentualnie odnajdź VBAM poprzez graficzny manager pakietów. Miłej gry. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Grudzień 2, 2013 Zgłoszenie Share Napisano Grudzień 2, 2013 libpng-devel Pewnie trzeba będzie jeszcze kilka(naście?dziesiąt?) innych *-devel. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
