Conky Lm-Sensors [Solved]
alkion
Conky lm-sensors jak tu się instaluje dawałem tak:
yum install lm-sensors
yum install sensors
Dalem też tak:
yum search sensors
I dostałem to:
ksensors.i686 : KDE frontend to lm_sensors
mate-sensors-applet.i686 : MATE panel applet for hardware sensors
qt5-qtsensors.i686 : Qt5 - Sensors component
xsensors.i686 : An X11 interface to lm_sensors
collectd-sensors.i686 : Libsensors module for collectd
lm_sensors.i686 : Hardware monitoring tools
lm_sensors-devel.i686 : Development files for programs which will use lm_sensors
lm_sensors-libs.i686 : Lm_sensors core libraries
mate-sensors-applet-devel.i686 : Development files for mate-sensors-applet
mingw32-qt5-qtsensors.noarch : Qt5 for Windows - QtSensors component
mingw64-qt5-qtsensors.noarch : Qt5 for Windows - QtSensors component
nagios-plugins-sensors.i686 : Nagios Plugin - check_sensors
qt-mobility-sensors.i686 : QtSensors support
qt5-qtsensors-devel.i686 : Development files for qt5-qtsensors
qt5-qtsensors-doc.noarch : API documentation for qt5-qtsensors
qt5-qtsensors-examples.i686 : Programming examples for qt5-qtsensors
sensors-lxpanel-plugin.i686 : Monitor temperature/voltages/fan speeds in LXDE through lm-sensors
xfce4-sensors-plugin.i686 : Sensors plugin for the Xfce panel
xfce4-sensors-plugin-devel.i686 : Development files for xfce4-sensors-plugin
digitemp.i686 : Dallas Semiconductor 1-wire device reading console application
gearbox.i686 : A collection of usable peer-reviewed robotics-related libraries
lm_sensors-sensord.i686 : Daemon that periodically logs sensor readings
mosquitto.i686 : An Open Source MQTT v3.1 Broker
player.i686 : Cross-platform robot device interface and server
Coś z tego wybrać czy jakieś repo dodać dodawałem to RPmfusion i Russian Fedora
Chodzi mi o temperaturę hdd w moim cudownym skrypciku hddtemp instalnełem w conky ścieżkę zmieniłem ale w:
/etc/sysconfig/hddtemp jakoś pusto:
# hddtemp(8) daemon options.  If no disks are specified here, the service
# will try to autodetect and start monitoring all of them.
HDDTEMP_OPTIONS="-l 127.0.0.1"
