Fedora21X86 Mate Yum Update Critical:yum.main: Error: Rpmdb Failed Release Provides. Try: Rpm --Rebuilddb
komp2015
Dzień dobry
Znów mam problem.
Próbowałem zainstalować program netbeans i wyskoczyły mi błędy i teraz nic nie mnoge instalować
nie działa yum update
[root@aa com1]# yum update
CRITICAL:yum.main:
Error: rpmdb failed release provides. Try: rpm --rebuilddb
nie działa sudo yum clear
[root@aa com1]#
CRITICAL:yum.main:
nie działa yum install *openjdk*
[root@aa com1]# yum install *openjdk*
CRITICAL:yum.main:
nie działa instalacja
[root@aa com1]# chmod +x netbeans-7.4-linux.sh
[root@aa com1]# ./netbeans-7.4-linux.sh
Configuring the installer...
Searching for JVM on the system...
Extracting installation data...
Running the installer wizard...
(java:3898): Gdk-CRITICAL **: IA__gdk_threads_set_lock_functions: assertion 'gdk_threads_lock == NULL && gdk_threads_unlock == NULL' failed
** (java:3898): WARNING **:
 *** jaw_impl_find_instance: jaw_impl == NULL ***
 *** component_removed_handler: jaw_impl == NULL ***
(java:3898): GLib-GObject-WARNING **: cannot register existing type 'JawImpl_2'
(java:3898): GLib-GObject-CRITICAL **: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(java:3898): GLib-GObject-CRITICAL **: g_object_new: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
 *** jaw_impl_get_instance: jaw_impl == NULL ***
 *** window_open_handler: jaw_impl == NULL ***
** (java:3898): CRITICAL **: atk_object_get_role: assertion 'ATK_IS_OBJECT (accessible)' failed
** (java:3898): CRITICAL **: atk_object_get_name: assertion 'ATK_IS_OBJECT (accessible)' failed
(java:3898): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(java:3898): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(java:3898): GLib-GObject-CRITICAL **: g_signal_emit_valist: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
 *** window_activate_handler: jaw_impl == NULL ***
(java:3898): GLib-GObject-WARNING **: invalid uninstantiatable type '(null)' in cast to 'AtkObject'
 *** window_close_handler: jaw_impl == NULL ***
 *** signal_emit_handler: jaw_impl == NULL ***
./netbeans-7.4-linux.sh: linia 1634:  3898 Przerwane               (zrzut pamięci) /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.45-38.b14.fc21.i386/jre/bin/java -Xmx256m -Xms64m -Dnetbeans.default_userdir_root="/root/.netbeans" -Dnetbeans.default_cachedir_root="/root/.cache/netbeans" -Djava.io.tmpdir=/tmp -classpath /tmp/.nbi-5052339.tmp/bundle.jar org.netbeans.installer.Installer
[root@aa com1]#
error netbeans
error netbeans
the installer lock file exists at /root/.nbi/.nbilock
Proszę jeszcze raz o pomoc
dziękuje
