Aktualizacja Z 21 Do 22 Warning
elson44
Witam!
Mam problem. Przy próbie aktualizaji z F21 do F22 wyskakuje mi taki warning:
warning: /var/cache/system-upgrade/rpmfusion-nonfree/packages/rpmfusion-nonfree-release-22-1.noarch.rpm: Header V4 RSA/SHA1 Signature, key ID a6708da3: NOKEY
Importowanie GPG klucza 0xA6708DA3:
 Identyfikator użytkownika: "RPM Fusion nonfree repository for Fedora (22) <[email protected]>"
 Odcisk palca             :
 Pakiet                   : rpmfusion-nonfree-release-21-1.noarch (@/rpmfusion-nonfree-release-21.noarch/21)
 Z                        : /etc/pki/rpm-gpg/RPM-GPG-KEY-rpmfusion-nonfree-fedora-22
  File "/usr/bin/fedup", line 291, in <module>
    main(args)
  File "/usr/bin/fedup", line 201, in main
    pkgs = download_packages(f, add_install=args.add_install)
  File "/usr/bin/fedup", line 85, in download_packages
    f.download_packages(updates, callback=output.DownloadCallback())
  File "/usr/lib/python2.7/site-packages/fedup/download.py", line 358, in download_packages
    self._checkSignatures(updates, callback)
  File "/usr/lib/python2.7/site-packages/fedup/download.py", line 495, in _checkSignatures
    self.getKeyForPackage(po, fullaskcb=keycheck)
  File "/usr/lib/python2.7/site-packages/yum/__init__.py", line 6192, in getKeyForPackage
    "timestamp": info['timestamp']})
  File "/usr/lib/python2.7/site-packages/fedup/download.py", line 494, in <lambda>
    keycheck = lambda info: self._GPGKeyCheck(info, callback)
  File "/usr/lib/python2.7/site-packages/fedup/download.py", line 513, in _GPGKeyCheck
    return callback.userconfirm()
  File "/usr/lib/python2.7/site-packages/fedup/textoutput.py", line 136, in userconfirm
    return YumOutput().userconfirm()
  File "/usr/share/yum-cli/output.py", line 980, in userconfirm
    choice = raw_input(prompt)
UnicodeEncodeError: 'ascii' codec can't encode character u'\u0105' in position 6: ordinal not in range(128)
Proszę o pomoc. Nie muszę chyba nadmieniać, iż jestem zielony :P
