Serwer Plików Sftp
cook
Witam mam problem z serwerem sftp nie mogę się połączyć
Plik: ssh_config
# This is the ssh client system-wide configuration file. See
# ssh_config(5) for more information. This file provides defaults for
# users, and the values can be changed in per-user configuration files
# or on the command line.
# Configuration data is parsed as follows:
# 1. command line options
# 2. user-specific file
# 3. system-wide file
# Any configuration value is only changed the first time it is set.
# Thus, host-specific definitions should be at the beginning of the
# configuration file, and defaults at the end.
# Site-wide defaults for some commonly used options. For a comprehensive
# list of available options, their meanings and defaults, please see the
# ssh_config(5) man page.
Host *
# ForwardAgent no
# ForwardX11 no
# ForwardX11Trusted yes
# RhostsRSAAuthentication no
# RSAAuthentication yes
# PasswordAuthentication yes
# HostbasedAuthentication no
# GSSAPIAuthentication no
# GSSAPIDelegateCredentials no
# GSSAPIKeyExchange no
# GSSAPITrustDNS no
# BatchMode no
# CheckHostIP yes
# AddressFamily any
# ConnectTimeout 0
# StrictHostKeyChecking ask
# IdentityFile ~/.ssh/identity
# IdentityFile ~/.ssh/id_rsa
# IdentityFile ~/.ssh/id_dsa
# Port 2122
# Protocol 2,1
# Cipher 3des
# Ciphers aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cb$
# MACs hmac-md5,hmac-sha1,[email protected],hmac-ripemd160
# EscapeChar ~
# Tunnel no
# TunnelDevice any:any
# PermitLocalCommand no
# VisualHostKey no
# ProxyCommand ssh -q -W %h:%p gateway.example.com
# RekeyLimit 1G 1h
SendEnv LANG LC_*
HashKnownHosts yes
GSSAPIAuthentication yes
Plik: sshd_config
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
Port 2122
# Use these options to restrict which interfaces/protocols sshd will bind $
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
HostKey /etc/ssh/ssh_host_ed25519_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 1024
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin without-password
StrictModes yes
ServerKeyBits 1024
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
StrictModes yes
PubkeyAuthentication yes
#AuthorizedKeysFile %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
# similar for protocol version 2
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthenticat$
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
IgnoreRhosts yes
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
#PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
# Kerberos options
# GSSAPI options
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication. Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
Status: Łączenie z 192.168.1.21:2122...
Odpowiedź fzSftp started
Polecenie: open "[email protected]" 2122
Polecenie: Ufaj nowemu kluczowi hosta: Raz
Polecenie: Pass: *********
Status: Connected to 192.168.1.21
Błąd: Connection closed by server with exitcode 1
Błąd: Nie można połączyć się z serwerem
Status: Oczekiwanie na ponowienie...
Postawiłem system i serwer sftp na nowo bo chyba coś namieszałem a łatwiej postawić system niż szukać błędu. Serwer działa dobrze tylko teraz pytanie jak zamknąć użytkownika w swoim katalogu dodałem bin/false do  /etc/shells oraz /etc/passwd  user:x:1001:1001:,,,:/home/user:/bin/false. Ale teraz za to nie chce się połączyć
Dobra może zrobimy inaczej  na spokojnie postawiłem na nowo system zrobiłem serwer ftp przy pomocy prodtpd zrobiłem konfigurację i śmiga dobrze. Ale że przydał by mi się zdalny dostęp to zainstalowałem ssh a dokładnie zainstalowały mi się dwa pakiety openssh-server oraz openssh-sftp-server. Również przeprowadziłem konfigurację i ssh śmiga dobrze. Tylko teraz mam problem z tym sftp nie moge go zablokować tylko cały czas się łączy z serwerem ftp. A tak najlepiej to bym go usunął albo w ogóle nie instalował jak się da  bo od ftp mam proftpd. Oczywiście wszystkie usługi chodzą na różnych portach tak proty są odblokowane itp.
Problem jest chyba gdzie indziej niż ci się wydaje. Nie wiem skąd wytrzasnąłeś ten pakiet: openssh-sftp-server i po co go instalujesz kiedy domyślny pakiet ssh czyli openssh-server zawiera już protokół sftp w sobie i działa on dobrze bez żadnej dodatkowej konfiguracji, z każdym klientem jakiego znam. Także coś niepotrzebnie mieszasz.
