slabypingwin Napisano Sierpień 2, 2017 Zgłoszenie Share Napisano Sierpień 2, 2017 Graficzne narzędzie ; system - administracja - languages - nie uruchamia się a w konsoli pokazuje taki błąd ; Z najwyższymi uprawnieniami roota wygląda to tak ; Quote [root@pc2 ~]# /usr/bin/system-config-language Starting graphical mode failed. Starting text mode instead. Traceback (most recent call last): File "/usr/share/system-config-language/system-config-language.py", line 67, in run if os.environ['DISPLAY'] != None: File "/usr/lib64/python3.6/os.py", line 669, in __getitem__ raise KeyError(key) from None KeyError: 'DISPLAY' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/share/system-config-language/system-config-language.py", line 76, in <module> scl.run() File "/usr/share/system-config-language/system-config-language.py", line 72, in run self.use_text_mode() File "/usr/share/system-config-language/system-config-language.py", line 39, in use_text_mode import language_tui File "/usr/share/system-config-language/language_tui.py", line 22, in <module> import snack ModuleNotFoundError: No module named 'snack' [root@pc2 ~]# Proszę o pomoc .... Quote [darecki@pc2 ~]$ sudo language sudo: language: command not found [darecki@pc2 ~]$ /usr/bin/system-config-language No protocol specified Unable to init server: Could not connect: Connection refused No protocol specified Unable to init server: Could not connect: Connection refused No protocol specified Unable to init server: Could not connect: Connection refused (system-config-language.py:2930): Gtk-WARNING **: cannot open display: :0 [darecki@pc2 ~]$ sudo /usr/bin/system-config-language No protocol specified Unable to init server: Could not connect: Connection refused No protocol specified Unable to init server: Could not connect: Connection refused No protocol specified Unable to init server: Could not connect: Connection refused (system-config-language.py:4149): Gtk-WARNING **: cannot open display: :0 [darecki@pc2 ~]$ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Fedoras Napisano Sierpień 4, 2017 Zgłoszenie Share Napisano Sierpień 4, 2017 https://bugzilla.redhat.com/show_bug.cgi?id=1384671 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
slabypingwin Napisano Sierpień 8, 2017 Autor Zgłoszenie Share Napisano Sierpień 8, 2017 Quote xhost +si:localuser:root Rzeczywiście ; po wykonaniu tego polecenia w konsoli - graficzne narzędzie do zarządzania językiem systemu uruchomiło się Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
