ncpa Napisano Czerwiec 19, 2018 Zgłoszenie Share Napisano Czerwiec 19, 2018 So I have a fresh install of Fedora 28 Server Edition and the first thing I tried to do was start cockpit, and I got this massege: Quote Failed to start cockpit.service: Unit cockpit.service not found. Google gives me no results over this error (?) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SeeM Napisano Czerwiec 21, 2018 Zgłoszenie Share Napisano Czerwiec 21, 2018 Is cockpit installed by default? If yes,You want a service and a socket: systemctl enable cockpit.socket systemctl enable cockpit systemctl start cockpit systemctl defaults to service, if "extension" isn't provided. More details are here: https://cockpit-project.org/running#fedora Next You'll have to add rules to your firewall. If You are using iptables, I strongly encourage to specify ip, or ip range of permitted clients. If You prefer firewalld, specify zone when opening ports. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
