Toni Napisano Grudzień 22, 2018 Zgłoszenie Share Napisano Grudzień 22, 2018 Gdy próbuję wyczyścić dane przeglądania w Chrome to okienko nie chce się zamknąć a proces trwa bez końca, tak to wygląda w journalctl -f [dawid@localhost ~]$ journalctl -f -- Logs begin at Sun 2018-11-25 09:24:48 CET. -- gru 22 15:19:18 localhost.localdomain dleyna-renderer-service[12057]: Enabled : F gru 22 15:19:18 localhost.localdomain dleyna-renderer-service[12057]: Entries: (null) gru 22 15:19:18 localhost.localdomain dbus-daemon[1524]: [session uid=1000 pid=1524] Successfully activated service 'com.intel.dleyna-renderer' gru 22 15:19:18 localhost.localdomain dleyna-renderer-service[12057]: Calling GetRenderers method gru 22 15:19:18 localhost.localdomain dleyna-renderer-service[12057]: Client :1.267 lost gru 22 15:19:19 localhost.localdomain dleyna-renderer-service[12027]: dLeyna: Exit gru 22 15:19:19 localhost.localdomain org.gnome.Terminal.desktop[1812]: # watch_fast: "/org/gnome/terminal/legacy/" (establishing: 0, active: 0) gru 22 15:19:19 localhost.localdomain org.gnome.Terminal.desktop[1812]: # unwatch_fast: "/org/gnome/terminal/legacy/" (active: 0, establishing: 1) gru 22 15:19:19 localhost.localdomain org.gnome.Terminal.desktop[1812]: # watch_established: "/org/gnome/terminal/legacy/" (establishing: 0) gru 22 15:19:20 localhost.localdomain dleyna-renderer-service[12057]: dLeyna: Exit gru 22 15:19:31 localhost.localdomain google-chrome.desktop[1812]: [12112:12112:1222/151931.746900:ERROR:x11_input_method_context_impl_gtk.cc(144)] Not implemented reached in virtual void libgtkui::X11InputMethodContextImplGtk::SetSurroundingText(const base::string16 &, const gfx::Range &) gru 22 15:19:31 localhost.localdomain gnome-keyring-daemon[1520]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered gru 22 15:19:32 localhost.localdomain gnome-keyring-daemon[1520]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered gru 22 15:19:37 localhost.localdomain google-chrome.desktop[1812]: [12112:12146:1222/151937.929113:ERROR:simple_version_upgrade.cc(159)] File structure does not match the disk cache backend. gru 22 15:19:37 localhost.localdomain google-chrome.desktop[1812]: [12112:12146:1222/151937.929130:ERROR:simple_backend_impl.cc(724)] Simple Cache Backend: wrong file structure on disk: 3 path: /home/dawid/.config/google-chrome/Default/Service Worker/CacheStorage/4cffe5d0b59926c8d8069ad00d0f24a3d5b507ed/6aff40b7-f583-46af-9c16-ce6b54a84768 gru 22 15:19:37 localhost.localdomain google-chrome.desktop[1812]: [12112:12134:1222/151937.929812:ERROR:disk_cache.cc(184)] Unable to create cache gru 22 15:19:43 localhost.localdomain dbus-daemon[783]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fredro Napisano Grudzień 22, 2018 Zgłoszenie Share Napisano Grudzień 22, 2018 Używanie Chrome na Linux, to jak używanie konia trojańskiego w TrueCrypt. Są lepsze przeglądarki Chromium, SlimJet, Opera, Vivaldi, Brave które prawidłowo wszystko usuwają. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Toni Napisano Grudzień 22, 2018 Autor Zgłoszenie Share Napisano Grudzień 22, 2018 Chroma używam bardzo rzadko, do tej pory zawsze wszystko usuwał, nie było problemów. Problem zaczął się jak zainstalowałem xfce i kde. Na początku tylko w tych środowiskach. Teraz tez na Gnome. A u ciebie/was też nie zamyka okna gdy próbujesz/ecie wymazać dane? Chciałbym wiedzieć czy tylko u mnie tak jest. EDIT Chrome usuwa te dane ale dziwne jest to że nie potrafi zamknąć okienka na sygnał że to już zrobił.. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fredro Napisano Grudzień 26, 2018 Zgłoszenie Share Napisano Grudzień 26, 2018 Chrome nie jest w repozytorium Fedory, więc odpowiedzialni za błędy są developerzy tej przeglądarki lub twórcy danego repozytorium z tą przeglądarką. Na moje oko oni dostosowują tylko Chrome do Ubuntu i Gnome, więc w Xfce jest zbyt stara wersja GTK, a w KDE już QT. Spróbuj usunąć katalog Chrome w /home i ponownie zainstalować najnowszą wersje. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Toni Napisano Grudzień 29, 2018 Autor Zgłoszenie Share Napisano Grudzień 29, 2018 Wszystko już działa dobrze, dzięki za podpowiedź.. Czyli uważasz, że używanie Chrome naprawdę źle wpływa na bezpieczeństwo? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
