Automatyczne przełączenie dźwięku na HDMI
fraktal15
spa-acp-tool list
card 0: profiles:7 devices:7 ports:5
    profile 0: name:"off" prio:0 (available: yes)
  * profile 1: name:"output:analog-stereo+input:analog-stereo" prio:6565 (available: yes)
    profile 2: name:"output:analog-stereo" prio:6500 (available: yes)
    profile 3: name:"output:iec958-stereo+input:analog-stereo" prio:5565 (available: yes)
    profile 4: name:"output:iec958-stereo" prio:5500 (available: yes)
    profile 5: name:"input:analog-stereo" prio:65 (available: yes)
    profile 6: name:"pro-audio" prio:1 (available: unknown)
  * port 0: name:"analog-input-internal-mic" direction:capture prio:8900 (available: unknown)
    port 1: name:"analog-input-mic" direction:capture prio:8700 (available: no)
  * port 2: name:"analog-output-speaker" direction:playback prio:10000 (available: unknown)
    port 3: name:"analog-output-headphones" direction:playback prio:9900 (available: no)
    port 4: name:"iec958-stereo-output" direction:playback prio:0 (available: unknown)
  * device 0: direction:capture name:"analog-stereo" prio:65 flags:00000007 devices: "front:%f"
    device 1: direction:playback name:"pro-output-0" prio:0 flags:00000000 devices: "hw:0,0"
    device 2: direction:playback name:"pro-output-1" prio:0 flags:00000000 devices: "hw:0,1"
    device 3: direction:playback name:"pro-output-3" prio:0 flags:00000000 devices: "hw:0,3"
    device 4: direction:capture name:"pro-input-0" prio:0 flags:00000000 devices: "hw:0,0"
  * device 5: direction:playback name:"analog-stereo" prio:65 flags:00000007 devices: "front:%f"
    device 6: direction:playback name:"iec958-stereo" prio:55 flags:00000010 devices: "iec958:%f"
przy włączonym:
spa-acp-tool list
przy wyłączonym:
spa-acp-tool list
  • 3 weeks later...
na podłączonym HDMI:
spa-acp-tool list
card 0: profiles:9 devices:8 ports:6
    profile 3: name:"output:hdmi-stereo+input:analog-stereo" prio:5965 (available: yes)
    profile 4: name:"output:hdmi-stereo" prio:5900 (available: yes)
    profile 5: name:"output:iec958-stereo+input:analog-stereo" prio:5565 (available: yes)
    profile 6: name:"output:iec958-stereo" prio:5500 (available: yes)
    profile 7: name:"input:analog-stereo" prio:65 (available: yes)
    profile 8: name:"pro-audio" prio:1 (available: unknown)
    port 5: name:"hdmi-output-0" direction:playback prio:5900 (available: yes)
    device 7: direction:playback name:"hdmi-stereo" prio:59 flags:00000010 devices: "hdmi:%f"
spa-acp-tool list
I teraz spróbuj przełączyć porty lub cały profil na hdmi i z powrotem na głośniki
dla portów
przełączenie na hdmi
spa-acp-tool set-port 5
przełączenie na głośniki
spa-acp-tool set-port 2
dla profili
spa-acp-tool set-profile 3
spa-acp-tool set-profile 1
dla portów - wyrzuca błąd
dla profili - jest ok, ale dźwięk nadal gra tylko z laptopa
[root@fedora ~]# spa-acp-tool set-port 5
arguments: <device_id> <port_id> missing
error: Invalid argument
[root@fedora ~]# spa-acp-tool set-port 2
[root@fedora ~]# spa-acp-tool set-profile 3
[root@fedora ~]# spa-acp-tool set-profile 1
[root@fedora ~]#
Wygląda, że trzeba podać jeszcze device
Zapewne będzie coś takiego.
spa-acp-tool set-port 7 5
spa-acp-tool set-port 5 2
Niestety dokumentacja jest dość uboga.
  • Upvote 1
[panekadamek@fedora ~]$ spa-acp-tool set-port 7 5
[panekadamek@fedora ~]$ spa-acp-tool set-port 5 2
'm' failed at ../spa/plugins/alsa/acp/alsa-mixer.c:1422 pa_alsa_path_select()
Przerwane (zrzut pamięci)
10 minut temu, fraktal15 napisał:
[panekadamek@fedora ~]$ pactl load-module module-switch-on-connect 262150 [panekadamek@fedora ~]$ pactl load-module module-switch-on-connect 262151 [panekadamek@fedora ~]$ pactl load-module module-switch-on-connect 262152
Wystarczy raz :)
Jak już masz załadowany moduł to podłącz do HDMI, wątpię żeby pomogło, ale kto wie.
