kazkra Napisano Lipiec 7 Zgłoszenie Share Napisano Lipiec 7 Dzień dobry! Fedora 40, Plazma 6.1. Próbowałem dzisiaj zaktualizować fedorę używając komendy: "dnf upgrade", ale dostaję taki komunikat: root@fedora:~# dnf upgrade Fedora 40 - x86_64 - Updates 44 kB/s | 27 kB 00:00 Fedora 40 - x86_64 - Updates 1.0 MB/s | 1.9 MB 00:01 Errors during downloading metadata for repository 'updates': - Status code: 416 for http://mirror.i3d.net/pub/fedora/linux/updates/40/Everything/x86_64/repodata/3b530a1ce7f5651260a8b3da74bdbb034f25515938fbe4ead2f58608429830ef-updateinfo.xml.zck (IP: 109.200.196.213) - Status code: 416 for https://mirror.i3d.net/pub/fedora/linux/updates/40/Everything/x86_64/repodata/3b530a1ce7f5651260a8b3da74bdbb034f25515938fbe4ead2f58608429830ef-updateinfo.xml.zck (IP: 109.200.196.213) - Curl error (23): Failed writing received data to disk/application for http://www.nic.funet.fi/pub/mirrors/fedora.redhat.com/pub/fedora/linux/updates/40/Everything/x86_64/repodata/384c6f8664f4c1b389fbd35f872bad5b1a1cc66018d2bd5eef61ce3784d94dcd-primary.xm l.zck [Failure writing output to destination] - Status code: 416 for http://mirror.i3d.net/pub/fedora/linux/updates/40/Everything/x86_64/repodata/384c6f8664f4c1b389fbd35f872bad5b1a1cc66018d2bd5eef61ce3784d94dcd-primary.xml.zck (IP: 109.200.196.213) - Status code: 416 for https://mirror.i3d.net/pub/fedora/linux/updates/40/Everything/x86_64/repodata/384c6f8664f4c1b389fbd35f872bad5b1a1cc66018d2bd5eef61ce3784d94dcd-primary.xml.zck (IP: 109.200.196.213) - Curl error (23): Failed writing received data to disk/application for http://www.nic.funet.fi/pub/mirrors/fedora.redhat.com/pub/fedora/linux/updates/40/Everything/x86_64/repodata/3b530a1ce7f5651260a8b3da74bdbb034f25515938fbe4ead2f58608429830ef-updateinfo .xml.zck [Failure writing output to destination] Error: Failed to download metadata for repo 'updates': Yum repo downloading error: Downloading error(s): repodata/384c6f8664f4c1b389fbd35f872bad5b1a1cc66018d2bd5eef61ce3784d94dcd-primary.xml.zck - Download failed: Curl error (23): Failed writing received dat a to disk/application for http://www.nic.funet.fi/pub/mirrors/fedora.redhat.com/pub/fedora/linux/updates/40/Everything/x86_64/repodata/384c6f8664f4c1b389fbd35f872bad5b1a1cc66018d2bd5eef61ce3784d94dcd-primary.xml.zck [Failure writing output to destination]; r epodata/3b530a1ce7f5651260a8b3da74bdbb034f25515938fbe4ead2f58608429830ef-updateinfo.xml.zck - Download failed: Curl error (23): Failed writing received data to disk/application for http://www.nic.funet.fi/pub/mirrors/fedora.redhat.com/pub/fedora/linux/update s/40/Everything/x86_64/repodata/3b530a1ce7f5651260a8b3da74bdbb034f25515938fbe4ead2f58608429830ef-updateinfo.xml.zck [Failure writing output to destination] root@fedora:~# Rozumiem, że jest jakiś problem z aplikacją curl i że nie może zapisać otrzymanych pakietów. Jak mógłbym naprawić ten błąd? Pozdrawiam, KKrauze Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Lipiec 7 Zgłoszenie Share Napisano Lipiec 7 Spróbuj polecenia dnf upgrade --refresh prawdopodobnie to jakieś przejściowe problemy z mirrorem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
kazkra Napisano Lipiec 7 Autor Zgłoszenie Share Napisano Lipiec 7 Dziękuję, przypomniałem sobie, że w /etc/dnf/dnf.conf dodałem "fastestmirror", usunąłem i już działa. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
