Gość ciupu Napisano Kwiecień 2, 2005 Zgłoszenie Share Napisano Kwiecień 2, 2005 zainstalwoałem mplayera - tak mi sie wydaje , amoze tylko jego cześć ? instalowąło sie długo ... po wpisaniuw konsoli"mplayer" wyskakuje takie cos: [ciupu@localhost ~]$ mplayer MPlayer 1.0pre6-RPM-3.3.2 © 2000-2004 MPlayer Team CPU: Intel Celeron A Mendocino/Pentium II Dixon (Family: 6, Stepping: 5) Detected cache-line size is 32 bytes CPUflags: MMX: 1 MMX2: 0 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0 Compiled with runtime CPU detection - WARNING - this is not optimal! To get best performance, recompile MPlayer with --disable-runtime-cpudetection. Warning unknown option cache_min at line 144 Warning unknown option cache_prefill at line 147 Usage: mplayer [options] [url|path/]filename Basic options: (complete list in the man page) -vo <drv[:dev]> select video output driver & device ('-vo help' for a list) -ao <drv[:dev]> select audio output driver & device ('-ao help' for a list) vcd://<trackno> play (S)VCD (Super Video CD) track (raw device, no mount) dvd://<titleno> play DVD title from device instead of plain file -alang/-slang select DVD audio/subtitle language (by 2-char country code) -ss <timepos> seek to given (seconds or hh:mm:ss) position -nosound do not play sound -fs fullscreen playback (or -vm, -zoom, details in the man page) -x <x> -y <y> set display resolution (for use with -vm or -zoom) -sub <file> specify subtitle file to use (also see -subfps, -subdelay) -playlist <file> specify playlist file -vid x -aid y select video (x) and audio (y) stream to play -fps x -srate y change video (x fps) and audio (y Hz) rate -pp <quality> enable postprocessing filter (details in the man page) -framedrop enable frame dropping (for slow machines) Basic keys: (complete list in the man page, also check input.conf) <- or -> seek backward/forward 10 seconds up or down seek backward/forward 1 minute pgup or pgdown seek backward/forward 10 minutes < or > step backward/forward in playlist p or SPACE pause movie (press any key to continue) q or ESC stop playing and quit program + or - adjust audio delay by +/- 0.1 second o cycle OSD mode: none / seekbar / seekbar + timer * or / increase or decrease PCM volume z or x adjust subtitle delay by +/- 0.1 second r or t adjust subtitle position up/down, also see -vf expand * * * SEE THE MAN PAGE FOR DETAILS, FURTHER (ADVANCED) OPTIONS AND KEYS * * * wyjasnicie mi gdzie mplayer ?? Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Raven Napisano Kwiecień 2, 2005 Zgłoszenie Share Napisano Kwiecień 2, 2005 To jest MPlayer. Tyle, że bez nakładki graficznej. Tę uruchamia się przez "gmplayer". Oczywiście, jeśli zainstalowałeś pakiet mplayer-gui (jeśli nie to "yum install mplayer"). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Koksik1986 Napisano Kwiecień 2, 2005 Zgłoszenie Share Napisano Kwiecień 2, 2005 Zainstaluj MPlayera ktorego znajdziesz tutaj.Jednym skryptem zainstalujesz wszystko.Przeczytaj opis dokladnie (tam jest) i sciagnij pliki.To jest latwe i dziala na 100%. I uzywaj opcji szukaj bo pisze juz o tym chyba z 30 raz.Ciagle podaje ta strone ale nie wiem czy ktos korzysta.Ja polecam. Tutaj link http://oceanic.wsisiz.edu.pl/~slabosz/index.php?page=art5 Pozdrawiam. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
blazejwiecha Napisano Kwiecień 2, 2005 Zgłoszenie Share Napisano Kwiecień 2, 2005 po częsci skorzystałem bo nie miałem gui i nie wiedziałem dlaczego nie działa ;d Ale już śmiga Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
