Instalacja Sterownikow Nvidia
Krajan
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri May 14 22:11:11 2004
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall              : false
  driver info            : false
  no precompiled interface: false
  no ncurses color        : false
  query latest driver ver : false
  OpenGL header files    : false
  no questions            : false
  silent                  : false
  XFree86 install prefix  : /usr/X11R6
  OpenGL install prefix  : /usr
  Installer install prefix: /usr
  kernel include path    : (not specified)
  kernel install path    : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp site                : ftp://download.nvidia.com
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
  ke the installer to attempt to download a kernel interface for your kernel f
  rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
  that the installer will need to compile a new kernel interface.
-> Kernel include path: '/lib/modules/2.4.22-1.2115.nptl/build/include'
-> Cleaning kernel module build directory.
  executing: 'cd ./usr/src/nv; make clean'...
  rm -f nv.o os-agp.o os-interface.o os-registry.o  nv-linux.o nv_compiler.h *
  .d NVdriver nvidia.o
-> Building kernel module:
  executing: 'cd ./usr/src/nv; make nvidia.o SYSINCLUDE=/lib/modules/2.4.22-1.
  2115.nptl/build/include'...
  You appear to be compiling the NVIDIA kernel module with
  a compiler different from the one that was used to compile
  the running kernel. This may be perfectly fine, but there
  are cases where this can lead to unexpected behaviour and
  system crashes.
  If you know what you are doing and want to override this
  check, you can do so by setting IGNORE_CC_MISMATCH.
  In any other case, set the CC environment variable to the
  name of the compiler that was used to compile the kernel.
  [1;31m*** Failed cc sanity check. Bailing out! ***
  [0mmake: *** [gcc-check] Błąd 1
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed.  Please see the file
      '/var/log/nvidia-installer.log' for details.  You may find suggestions
      on fixing installation problems in the README available on the Linux
      driver download page at www.nvidia.com.
[ciach]
  the running kernel.
Instalator widział źródłą :-) Tak jak napisałem wcześniej - trzeba ustawić kompilator taki jaki był używany do budowy jądra (gcc32).
Ponieważ instaltor nadpisuje niektóre pliki należące do XFree86-Mesa-libGL, warto zainstalować sterowniki z paczki RPM. Albo znajdź w necie jakąś pasującą do Twojego jądra (BTW nie używasz oficjalnego kernela, tylko tego z http://atrpms.net/), albo samemu przebuduj - ja używałem tego:
http://rpm.livna.org/fedora/1/i386/SRPMS.s...lvn.3.1.src.rpm
Hmm... Czy jak wpiszesz w konsli
CC="gcc32" sh NVIDIA-Linux-x86-coś_tam
to się już dobrze instaluje? (tak tylko zgaduję, bo nie mam pojęcia dlaczego nie chce się skompilować)
"CC=gcc32" - bez tego instaluje się już normalnie instaluje - problem był z pierwszymi jądrami
Chyba że o czymś nie wiem :(
juz wszystko namieszalem :P nauczylem sie jaderko instalowac nowe i teraz mam tak :)
[krajan@localhost krajan]$ uname -r
2.4.22-1.2188.nptl_48.rhfc1.atsmp
to teraz te najnowsze ? :D
Oficjalne jest 2.4.22-1.2188.nptl
Z dopiskami typu "48.rhfc1.atsmp" to na własne ryzyko.
at - jest z http://ATrpms.net, a smp oznacza, że jest przeznaczone do maszyn wieloprocesorowych
