luklow Napisano Maj 22, 2005 Zgłoszenie Share Napisano Maj 22, 2005 (edytowane) nie mogę używać yum-a, nie wiem czemu, wywala mi coś takiego, pokazane jest kilka różnych prób... [root@localhost etc]# yum install xmms-mp3 Repository livna-stable already added, not adding again You have enabled checking of packages via GPG keys. This is a good thing. However, you do not have any GPG public keys installed. You need to download the keys for packages you wish to install and install them. You can do that by running the command: rpm --import public.gpg.key For more information contact your distribution or package provider. [root@localhost etc]# yum generate-rss Repository livna-stable already added, not adding again Traceback (most recent call last): File "/usr/bin/yum", line 8, in ? yummain.main(sys.argv[1:]) File "/usr/share/yum-cli/yummain.py", line 51, in main base.getOptionsConfig(args) File "/usr/share/yum-cli/cli.py", line 245, in getOptionsConfig self.parseCommands() # before we exit check over the base command + args File "/usr/share/yum-cli/cli.py", line 340, in parseCommands self.extcmds[0] = 'recent' IndexError: list assignment index out of range [root@localhost etc]# rpm --import public.gpg.key błąd: public.gpg.key: read przy imporcie nie powiodło się. [root@localhost etc]# su - [root@localhost ~]# rpm --import public.gpg.key błąd: public.gpg.key: read przy imporcie nie powiodło się. [root@localhost ~]# yum update yum Repository livna-stable already added, not adding again You have enabled checking of packages via GPG keys. This is a good thing. However, you do not have any GPG public keys installed. You need to download the keys for packages you wish to install and install them. You can do that by running the command: rpm --import public.gpg.key For more information contact your distribution or package provider. co mam zrobić?? Edytowane Maj 22, 2005 przez _PaT Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Maj 22, 2005 Zgłoszenie Share Napisano Maj 22, 2005 FAQ nie gryzie. Dziękuj gajownikowi Zawsze możesz w plikach z repozytoriami yum pozamieniać wpisy na: gpgcheck=0 ale tak jak masz napisane w tym, co wkleiłeś to tylko częściowe rozwiązanie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Arial Napisano Maj 23, 2005 Zgłoszenie Share Napisano Maj 23, 2005 Hmm mam ten sam problem, podmienilem gpgchech z 1 na 0, ale ciagle wyskakuje ten sam blad: You have enabled checking of packages via GPG keys. This is a good thing. However, you do not have any GPG public keys installed. You need to download the keys for packages you wish to install and install them. You can do that by running the command: rpm --import public.gpg.key For more information contact your distribution or package provider. Moze wie ktos, gdzie wkleic ten nieszczesny GPG key ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Raven Napisano Maj 23, 2005 Zgłoszenie Share Napisano Maj 23, 2005 Zobacz link podany przez _PaTa. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
