Zmiana Rozmiaru Parycji
grs_84pl
Pierw wkleje co mi wywalił yum
[root@localhost grs]# yum update
Setting up Update Process
Setting up repositories
livna                     100% |=========================|  951 B    00:00
macromedia                100% |=========================|  903 B    00:00
extras                    100% |=========================| 1.1 kB    00:00
updates-released          100% |=========================|  951 B    00:00
base                      100% |=========================| 1.1 kB    00:00
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package glib2.i386 0:2.6.6-1 set to be updated
---> Package firefox.i386 0:1.0.6-1.2.fc4 set to be updated
---> Package kdenetwork.i386 7:3.4.2-0.fc4.1 set to be updated
---> Package netpbm-devel.i386 0:10.28-1.FC4.2 set to be updated
---> Package mozilla.i386 37:1.7.10-1.5.2 set to be updated
                                             itd...
xorg-x11-xauth          i386       6.8.2-37.FC4.45  updates-released  100 k
xorg-x11-xdm            i386       6.8.2-37.FC4.45  updates-released  168 k
xorg-x11-xfs            i386       6.8.2-37.FC4.45  updates-released  138 k
xpdf                    i386       1:3.01-0.FC4.1   updates-released  4.3 M
yelp                    i386       2.10.0-1.4.1     updates-released  302 k
zlib                    i386       1.2.2.2-5.fc4    updates-released   48 k
zlib-devel              i386       1.2.2.2-5.fc4    updates-released   98 k
Installing for dependencies:
python-numeric          i386       23.7-2           base              679 k
Transaction Summary
Install      1 Package(s)
Update     224 Package(s)
Remove       0 Package(s)
Total download size: 502 M
Is this ok [y/N]: y
Downloading Packages:
a póżniej miedzy inymi coś takiego:
file /usr/share/doc/HTML/en/common/web-docbottom.png conflicts between attempted installs of kdelibs-3.4.2-0.fc4.1 and kde-i18n-Polish-3.4.2-0.fc4.1
 file /usr/share/doc/HTML/en/common/web-doctop.png conflicts between attempted installs of kdelibs-3.4.2-0.fc4.1 and kde-i18n-Polish-3.4.2-0.fc4.1
 file /usr/share/doc/HTML/en/common/x11-license.html conflicts between attempted installs of kdelibs-3.4.2-0.fc4.1 and kde-i18n-Polish-3.4.2-0.fc4.1
 file /usr/share/doc/HTML/en/common/xml.dcl conflicts between attempted installs of kdelibs-3.4.2-0.fc4.1 and kde-i18n-Polish-3.4.2-0.fc4.1
 installing package kdelibs-3.4.2-0.fc4.1 needs 5MB on the / filesystem
 installing package openmotif-2.2.3-10.FC4.1 needs 5MB on the / filesystem
 installing package libstdc++-4.0.1-4.fc4 needs 6MB on the / filesystem
 installing package vnc-server-4.1.1-10.1 needs 5MB on the / filesystem
 installing package lockdev-devel-1.0.1-7.1 needs 5MB on the / filesystem
 installing package kdesdk-3.4.2-0.fc4.1 needs 8MB on the / filesystem
 installing package openoffice.org-math-1.9.125-1.1.0.fc4 needs 11MB on the / filesystem
 installing package arts-1.4.2-0.fc4.1 needs 7MB on the / filesystem
 installing package gcc-4.0.1-4.fc4 needs 12MB on the / filesystem
installing package pam-0.79-9.5 needs 65MB on the / filesystem
 installing package libraw1394-1.2.0-1.fc4 needs 65MB on the / filesystem
Oprócz tych konfliktów wnioskuje ze mu miejsca brakuje bo nic poza wywalenim tych komunikatów nie robi.
Na "/" zostalo mi 500MB wolnego
Moge mu "oddać" z partycji "/home" 1,5GB na "/" ale nie wiem jak tego dokonać :(
Moge sie bawić partition magic ale szczerze sie boje. Wkońcu to windows :P
Pomoże ktoś zmienić rozmiar jednej i drugiej partycji zeby wszytko było "cycuś" ??
Ps.
FC4 kernel z końcówką 1447 (pierwsza FC w życiu)
i miałem wcześniej problemy z "Naruszeniem ochrony pamięci" moze to od tego??
Napiszcie czy z tym walczyć, czy zrobić dla św spokoju reinstall i od pocztątku skonfigurować FC bez popełniania błędów typu: instalacja sterów od nVidii ze strony nvidia.com itp. ????????
Do partycji użyj partition magic o ile go masz. Nawet na windzie to musi wypalić. Później odpal kompa w trybie rescue ale się nie chrootuj do /mnt/sysimage tylko
e2fsck -p /dev/partycja
Później wejdź na fedorę,wywal to co ci powoduje konflikty i zapuść yuma-a na nowo. Mam to samo jądro co ty i nie mam konfliktów
masz za malo miejsca na dysku
instaluj kolejno odp updaty yumem nie wszyskto na raz i kasuj stare to nie bedize porblemu z miejscem na dysku
nie powinno byc pozniej konfliktow
pigeon
Witam.
Mi przyszedl do glowy taki pomysl, zeby skasowac katalog /var/cache/yum a w jego miajsce wstawic link symboliczny do jakiegos katalogu na innej partycji. Wczesniej trzebaby tam skopiowac zawartosc /var/cache/yum
Oczywiscie na tamtej partycji musi byc wystarczajaco duzo miejsca i powinna byc zamontowana z parametrem exec.
Jednak to rozwiazanie jest raczej prowizoryczne, niz nadajace sie do szerszego korzystania.
Bardzo zły pomysł, lepiej tego nie rób. Cache yuma czyści się inaczej, ale to już sam znajdź :P
CYTAT
<ciach> file /usr/share/doc/HTML/en/common/xml.dcl conflicts between attempted installs of kdelibs-3.4.2-0.fc4.1 and kde-i18n-Polish-3.4.2-0.fc4.1 <ciach>
Niedawno dwukrotnie wałkowany temat, niestety nie mam siły szukać za Ciebie dry.gif
Nie chodziło mi o konflikty miedzy plikami bo bym sobie poszukał ale dzięki za pomoc. :)
perl  napisano 13.09.2005 - 22:11
  o zmianie wielkosci partycji tez bylo juz na forum, wpisz 'resize' w 'szukaj'
Próbowałem po polsku i nic nie znalazło dlatego napisałem nowy toppic
:rolleyes:
wiem, wiem: man yum :)
ps. postanowiłem po długim namyśle i tak trzasnąć nową instalke. Zmienie rozmiary partycji, zmniejsze sobie swap (z 400MB na 100Mb, w systemie i tak mam 768MB), nie będe sie bawił w instalke gnome jak i tak siedze na KDE.
A przede wszytkim zanim cokolwiek zrobie na systemie przeczytam pierw o tym na forum. Nawyki z Mandrivy juz i tak za duzo złego zrobiły....
Witam ponownie.
Nie mialem na mysli czyszczenia cache'u w yumie, tylko raczej pewne obejscie problemu braku miejsca. Chodzilo mi o przeniesienie tego katalogu na partycje na ktorej jest wiecej miejsca i zatuszowanie tej operacji linkiem symbolicznym. Wtedy nie trzebaby bylo zmieniac rozmiarow partycji. A ze pomysl jest kiepski i raczej tymczasowy, wspomnialem juz wczesniej.
Sam sie zastanawiałem czemu niby to zły pomysł..... i prawde powiedziawszy nie wiem czemu to miałoby być kiepskim pomyslem ??????????
z punktu widzenia sys operacyjnego to nic sie nie zmienia.... pakiety dalej ma w /var/cache/yum a że znajdują sie ma innym dysku ?? Najwyzej nie bedzie mógł robić dowiązań sztywnych.
Heh ale juz mam nowiutką fedore i jest fajnie :) Nie bede juz nic cfaniakował :P
Pozdrawiam !
