Ripper Mp3
Shaer
Czym najlepiej zgrywać muzykę z płyt na mp3(czym (_wogóle_ → w ogóle) ORT)?
a co jeżeli chcę z mpc zrobić mp3 albo inny format? interesuje mnie np. nagranie audio cd z mpc. k3b tego nie umie.
kodeki mac mam zainstalowane.
btw sounconverter chyba tego nie obsługuje? zresztą wywala mi takie komunikaty:
(SoundConverter:5702): libglade-WARNING **: unknown property `urgency_hint' for class `GtkWindow'
(SoundConverter:5702): libglade-WARNING **: unknown property `pack_direction' for class `GtkMenuBar'
(SoundConverter:5702): libglade-WARNING **: unknown property `child_pack_direction' for class `GtkMenuBar'
art_render_invoke: no image source given
(SoundConverter:5702): libglade-WARNING **: unknown property `urgency_hint' for class `GtkDialog'
(SoundConverter:5702): libglade-WARNING **: unknown property `do_overwrite_confirmation' for class `GtkFileChooserDialog'
(SoundConverter:5702): libglade-WARNING **: unknown property `urgency_hint' for class `GtkFileChooserDialog'
/usr/bin/soundconverter:1597: GtkDeprecationWarning: gtk.TRUE is deprecated, use True instead
gtk.main()
k3b-mpc-0.12.2-1.xcyb.fc3 100% |=========================| 12 kB 00:00
---> Package k3b-mpc.x86_64 0:0.12.2-1.xcyb set to be updated
--> Running transaction check
--> Processing Dependency: libmusepack.so.2()(64bit) for package: k3b-mpc
--> Processing Dependency: k3b = 0:0.12.4a for package: k3b-mpc
--> Processing Dependency: k3b = 0:0.12.2 for package: k3b-mpc
--> Processing Dependency: libk3b.so.1 for package: k3b-mpc
--> Processing Dependency: libk3b.so.1()(64bit) for package: k3b-mpc
--> Processing Dependency: libk3bdevice.so.2 for package: k3b-mpc
--> Processing Dependency: libmusepack.so.2 for package: k3b-mpc
--> Restarting Dependency Resolution with new changes.
--> Populating transaction set with selected packages. Please wait.
---> Package k3b.x86_64 0:0.12.2-1.xcyb set to be updated
---> Downloading header for libmusepack to pack into transaction set.
libmusepack-1.1-1.xcyb.fc 100% |=========================| 3.1 kB 00:00
---> Package libmusepack.i386 0:1.1-1.xcyb set to be updated
---> Package libmusepack.x86_64 0:1.1-1.xcyb set to be updated
---> Downloading header for k3b to pack into transaction set.
k3b-0.12.4a-1.xcyb.fc3.i3 100% |=========================| 74 kB 00:05
---> Package k3b.i386 0:0.12.4a-1.xcyb set to be updated
--> Processing Dependency: libFLAC++.so.2()(64bit) for package: k3b
--> Processing Dependency: libFLAC++.so.2 for package: k3b
--> Processing Dependency: libFLAC.so.4 for package: k3b
--> Processing Dependency: libFLAC.so.4()(64bit) for package: k3b
--> Processing Dependency: libk3bcore.so.2()(64bit) for package: k3b-mp3
--> Processing Dependency: libmad.so.0 for package: k3b
--> Processing Dependency: libtag.so.1 for package: k3b
--> Processing Dependency: libk3bplugin.so.2()(64bit) for package: k3b-mp3
--> Processing Dependency: libmusicbrainz.so.2 for package: k3b
--> Processing Dependency: libmusicbrainz.so.2()(64bit) for package: k3b
--> Finished Dependency Resolution
Error: Missing Dependency: libFLAC++.so.2()(64bit) is needed by package k3b
Error: Missing Dependency: libFLAC++.so.2 is needed by package k3b
Error: Missing Dependency: libFLAC.so.4 is needed by package k3b
Error: Missing Dependency: libFLAC.so.4()(64bit) is needed by package k3b
Error: Missing Dependency: libk3bcore.so.2()(64bit) is needed by package k3b-mp3
Error: Missing Dependency: libmad.so.0 is needed by package k3b
Error: Missing Dependency: libtag.so.1 is needed by package k3b
Error: Missing Dependency: libk3bplugin.so.2()(64bit) is needed by package k3b-mp3
Error: Missing Dependency: libmusicbrainz.so.2 is needed by package k3b
Error: Missing Dependency: libmusicbrainz.so.2()(64bit) is needed by package k3b
czy mam ściągnąć rpm-y i zainstalować nodeps? te bibliotrki mam w systemie.
  • 4 weeks later...
Q. 6: I'm upgrading and I get "Error: Missing Dependency:" messages like "Error: Missing Dependency: libgcj.so.5 is needed by package junit" and then yum quits. What should I do?
A. yum is trying to tell you that some packages that are being replaced or obsoleted are needed by an installed package, so yum can't do it's work. To interpret the example, the installed junit package requires libgcj.so.5 and libgcj.so.5 is being updated or obsoleted so junit would no longer work if yum updated the libgcj.so.5 package.
One relatively easy way to fix this is to remove whatever package "needs" the packages that are about to be upgraded/obsoleted and then reinstall that package after you have upgraded everything else. In the example, remove junit, upgrade, then reinstall junit.
Another solution is to find a repository that provides an upgraded of the package that "needs" the old packages and add it to your yum configuration. Hopefully the new version of that package will have dependencies on the upgraded package, in our case libgcj.so.5, and yum will take care of everything.
For more details, see [WWW] this post by Garrick Staples
może komuś pomoże ... jest to wypis z faq dotyczącego (_yum'a_ → yuma) ORT znajdującego się na http://wiki.linux.duke.edu/YumFaq ... u mnie z angielskim jest marnie więc nic więcej nie pomogę ... może jak coś rozszyfruję to dam znać ...
