dextroyer Napisano Styczeń 5, 2006 Zgłoszenie Share Napisano Styczeń 5, 2006 Witam wiem ze jest juz kilka tematow o ATI. Chodzi o to ze zrobilem tak : [root@localhost dex]# yum install kernel-module-fglrx-$(uname -r) Setting up Install Process Setting up repositories livna 100% |=========================| 951 B 00:00 updates-released 100% |=========================| 951 B 00:00 extras 100% |=========================| 1.1 kB 00:00 base 100% |=========================| 1.1 kB 00:00 kadu 100% |=========================| 951 B 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 225 kB 00:08 livna : ################################################## 749/749 Added 749 new packages, deleted 0 old in 4.90 seconds Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Downloading header for kernel-module-fglrx-2.6.11-1.1369_FC4 to pack into transaction set. kernel-module-fglrx-2.6.1 100% |=========================| 9.4 kB 00:00 ---> Package kernel-module-fglrx-2.6.11-1.1369_FC4.i686 0:8.14.13.1-0.lvn.5.4 set to be updated --> Running transaction check --> Processing Dependency: ati-fglrx >= 0:8.14.13.1-0.lvn.1 for package: kernel-module-fglrx-2.6.11-1.1369_FC4 --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Downloading header for ati-fglrx to pack into transaction set. ati-fglrx-8.20.8.1-0.lvn. 100% |=========================| 22 kB 00:00 ---> Package ati-fglrx.i386 0:8.20.8.1-0.lvn.2.4 set to be updated --> Running transaction check --> Processing Dependency: libstdc++.so.5 for package: ati-fglrx --> Processing Dependency: libstdc++.so.5(CXXABI_1.2) for package: ati-fglrx --> Processing Dependency: libstdc++.so.5(GLIBCPP_3.2) for package: ati-fglrx --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Downloading header for compat-libstdc++-33 to pack into transaction set. compat-libstdc%2B%2B-33-3 100% |=========================| 2.7 kB 00:00 ---> Package compat-libstdc++-33.i386 0:3.2.3-47.fc4 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: kernel-module-fglrx-2.6.11-1.1369_FC4 i686 8.14.13.1-0.lvn.5.4 livna 113 k Installing for dependencies: ati-fglrx i386 8.20.8.1-0.lvn.2.4 livna 6.6 M compat-libstdc++-33 i386 3.2.3-47.fc4 base 228 k Transaction Summary ============================================================================= Install 3 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 7.0 M Is this ok [y/N]: y Downloading Packages: (1/3): kernel-module-fglr 100% |=========================| 113 kB 00:03 (2/3): compat-libstdc++-3 100% |=========================| 228 kB 00:10 (3/3): ati-fglrx-8.20.8.1 100% |=========================| 6.6 MB 05:13 warning: rpmts_HdrFromFdno: Header V3 DSA signature: NOKEY, key ID a109b1ec public key not available for kernel-module-fglrx-2.6.11-1.1369_FC4-8.14.13.1-0.lvn.5.4.i686.rpm Retrieving GPG key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-livna Importing GPG key 0xA109B1EC "Livna.org rpms <[email protected]>" Is this ok [y/N]: y Key imported successfully Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: compat-libstdc++-33 ######################### [1/3] Installing: ati-fglrx ######################### [2/3] Installing: kernel-module-fglrx-2.6.11-1 ######################### [3/3] Installed: kernel-module-fglrx-2.6.11-1.1369_FC4.i686 0:8.14.13.1-0.lvn.5.4 Dependency Installed: ati-fglrx.i386 0:8.20.8.1-0.lvn.2.4 compat-libstdc++-33.i386 0:3.2.3-47.fc4 Complete! I chyba wszystko powinno grac a nie gra, bo po udanej instalacji enemy teritorry gra nie działa i według tego co wskazuje konsola z porownaniem inncyh postow to mam blad w sterownikach. Prosze o pomoc zaznaczam ze juz tydzien czytam w google i fedora.pl i innych lugach i braklo mi sily. dodam do tego ze po wpisaniu glxinfo linijka direct rendering: No chyba nie wskazuje nic dobrego pomozcie radami co zrobic bo to ATI mnie wykonczy [root@localhost dex]# glxinfo name of display: :0.0 Xlib: extension "XFree86-DRI" missing on display ":0.0". display: :0 screen: 0 direct rendering: No server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig client glx vendor string: ATI client glx version string: 1.3 client glx extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float, GLX_ATI_render_texture GLX extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_multisample OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.2 (1.5 Mesa 6.2.1) OpenGL extensions: GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias glu version: 1.3 glu extensions: GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x23 24 tc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 1 0 None 0x24 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 1 0 None 0x25 24 tc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x26 24 tc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x27 24 dc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 1 0 None 0x28 24 dc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 1 0 None 0x29 24 dc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x2a 24 dc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 1 0 None Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
smopi Napisano Styczeń 6, 2006 Zgłoszenie Share Napisano Styczeń 6, 2006 Witaj! U mnie było to samo - niby wszystko się udawało ale nie było grafiki 3D. Jak sądzę uruchamiasz instalację z X'ów? U mnie pomogło jak zrobiłem najpierw init 3 i dopiero później instalacja sterów. Odinstaluj sterowniki, przejdź na poziom 3 i zainstaluj ponownie. Daj znać czy pomogło? Pozdrawiam, Piotr PS. Widzę, że system masz bez aktualizacji? Warto jeszcze zrobić yum update Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Byku Napisano Styczeń 6, 2006 Zgłoszenie Share Napisano Styczeń 6, 2006 Meczylem sie przez tydzien z instalacja sterownikow (zarowno te ATI jak i livna) pod jajkiem 2.6.11 i mi sie nie udalo. Pod 2.6.14 poszlo za pierwszym razem... Enemy territory smiga bez najmniejszego przycięcia Widocznie te stare wersje sterow pod starsze kernele sa jakies niedopracowane Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gryhild Napisano Styczeń 6, 2006 Zgłoszenie Share Napisano Styczeń 6, 2006 Zacznij moze od aktualizacji jajka jakos do 2.6.14.x i po tem sterów do 8.20.x I jak zainstalujesz i nie będzie działąć, to pisz tutaj wtedy Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dextroyer Napisano Styczeń 6, 2006 Autor Zgłoszenie Share Napisano Styczeń 6, 2006 witam jako zielony (_urzytkownik_ → użytkownik) ORT po wpisaniu "su -" zalogowalem sie na pelnoprawnego roota wpisalem init 3 i po 15 minutach patrzenia na czarny ekran zaniepokoilem sie i ruszylem mysza. Pojawily sie 3-4 linijki zakonczone [ OK ] pisalo przynich pcmci i tym podobne i tak stalo i stalo po 30 minutach restart ponow probe i ta sama akcja. pozatym nie wiem jaki pakiet mam odinstalwoac i jaka komenda rpm -e nazwa ?? ale jak instalowalem stery z lviny przez yuma to nie wiem jaka nazwa pakietu byla jak to sprawdzic karta ati radeon 9550 wykrywany jako 9600 a 3d nadal nie dziala po tym co napisalem u samej gory problem z yumem tez jest chcialem zrobic yum update ale ten problem poruszylem w innym poscie pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
smopi Napisano Styczeń 6, 2006 Zgłoszenie Share Napisano Styczeń 6, 2006 Ok, a więc powoli: 1. otwierasz terminal i wydajesz polecenie su - podajesz hasło użytkownika root, 2. init 3 i po chwili masz system na poziomie 3 - wciśnij Alt + F1 (przykładowo) i zaloguj się na konto usera "root", 3. yum remove ati-fglrx - usuwasz sterowniki ATI a następnie yum install ati-fglrx kernel-module-fglrx-$(uname -r) 4. i ostatecznie restartujesz system: init 6 . Mam nadzieję, że teraz pójdzie lepiej a ja nigdzie się nie walnąłem Powodzenia i daj znać czy stery poszły! Piotr Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gryhild Napisano Styczeń 6, 2006 Zgłoszenie Share Napisano Styczeń 6, 2006 Po wpisaniu init 3 powinna sie pokazac konsola ze znakem zachety, jak tak się nie dzieje, to wciścnij enter. Powinno być oko. Masz na forum sto instrukcji instalacji sterów, wykorzystaj którąś a po tem ewentualnie pisz co CI nie działa Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dextroyer Napisano Styczeń 6, 2006 Autor Zgłoszenie Share Napisano Styczeń 6, 2006 Gryhild wiem ze jest 100 instrukji sterow i czytalem je po kilka razy, korzystajac z nich udalo mi sie zrob to co dotychczas zrobilem , gdybym nie potrzebowal pomocy nie prosilbym o nia. Nie mam pretensji ale duza czesc poczatkujacyc mozesz w ten sposob odstraszyc ja naszczescie sie nie boje bo juz nie pierwszy raz zasiadam przy (_linuxie_ → Linuksie) ORT ale mam nadzieje ze tym razem nie ustapie po paru tygodniach. wracajac do tematu narazie robie yum update jak sie skonczy to zrobie te stery pod tym 3 poziomem. Pozdrawiam i dzieki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gryhild Napisano Styczeń 7, 2006 Zgłoszenie Share Napisano Styczeń 7, 2006 Ja chętnie pomogę, tylko nie chce mi się pisać po raz n'ty to samo, co ktoś już zrobił kiedyś. A kopiuje, wklej to bezsensu. Spróbuje je zainstalować a jak nie zadziałą to będziemy myśleć, jakieś logi wrzucisz, czy wyniki kilku poleceń i pewnie się coś znajdze A pytanie jak zainstalować stery to tak jak zapytać się jak zainstalowć linuksa, chyba wiesz o co mi chodzi:) Pozdrawiam i powodzenia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Byku Napisano Styczeń 7, 2006 Zgłoszenie Share Napisano Styczeń 7, 2006 hmm mam takie pytanie przy okazji: koniecznie trzeba wchodzi w to init3? Ja nie wchodzilem, po prostu odpalilem konsole pod kde i zainstalowalem wszystko i wszystko chodzi jak nalezy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Styczeń 7, 2006 Zgłoszenie Share Napisano Styczeń 7, 2006 koniecznie trzeba wchodzi w to init3? Ja nie wchodzilem, po prostu odpalilem konsole pod kde i zainstalowalem wszystko i wszystko chodzi jak nalezy. Jeśli instalujesz paczki z livna, to nie trzeba. Zainstalowane sterowniki zaczną działać po restarcie X-ów (jesli nie, to wystarczy ręcznie załadować moduł jądra). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dextroyer Napisano Styczeń 7, 2006 Autor Zgłoszenie Share Napisano Styczeń 7, 2006 gajownik no ja wlasnie robilem te z lviny i po restarcie nie chodzily, wlasnie konczy mi sie yum update robic i teraz (_sprubuje_ → spróbuję) ORT jeszcze raz, jak nic nie pomoze to wrzuce kod z konsoli i moze cos jeszcze Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
smopi Napisano Styczeń 7, 2006 Zgłoszenie Share Napisano Styczeń 7, 2006 Byku: U mnie trzeba - jak instalowałem sterowniki z Livny z poziomu X'ów to niby wszystko się udawało ale nawet po restarcie systemu akceleracji nie było. Pomogło init 3 (zresztą na jakimś forum znalazłem opis instalacji gdzie zalecano robienie tego właśnie na poziomie 3). W sumie wydaje się to dziwne ale u mnie tak jest. Pozdrawiam, Piotr Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dextroyer Napisano Styczeń 7, 2006 Autor Zgłoszenie Share Napisano Styczeń 7, 2006 No dobra zrobilem update, odpalilem init 3 wpisalem yo yum remove ati-fglrx odinstalowalo dwa pakiety : Ati-fglrx i kernel-module cos tam Wzialem yum install ati-fglrx kernel-module-fglrx-$(uname -r) znalazlo tylko lik ati-fglrx i instalacja complete ale jest jeszcze takie cos ze brakuje kernela [dex@localhost ~]$ su - Password: [root@localhost ~]# yum install ati-fglrx kernel-module-fglrx-$(uname -r) Setting up Install Process Setting up repositories livna 100% |=========================| 951 B 00:00 base 100% |=========================| 1.1 kB 00:00 kadu 100% |=========================| 951 B 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 203 kB 00:05 livna : ################################################## 735/735 Added 8 new packages, deleted 22 old in 1.23 seconds Parsing package install arguments No Match for argument: kernel-module-fglrx-2.6.14-1.1656_FC4 Nothing to do [root@localhost ~]# Co teraz? Moze poprostu chwilowo go nie wyszukalo i za jakias godzinke sprubowac ?? (_wogole_ → w ogóle) ORT to teraz zauwazylem ze chyba mi jakis repozytoriow brakuje zobacze co da sie zrobic Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
smopi Napisano Styczeń 7, 2006 Zgłoszenie Share Napisano Styczeń 7, 2006 Ty to masz normalnie pecha Bodajże wczorej pojawił się nowy kernel i pewnie na livnie nie ma jeszcze przygotowanej paczki dla niego. Poczekaj aż pojawi się kernel-module dla tego jajka i wtedy powtórz instalacje. Chyba, że można zainstalować kernel-module ze starszego kernela ale to już muszą wypowiedzieć się bardziej doświadczeni Powodzenia! Piotr PS. Wczoraj robiłem yum update dla swojego systemu ale specjalnie zrobiłem to z pominięciem nowego kernela. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
