dextroyer Napisano Styczeń 7, 2006 Autor Zgłoszenie Share Napisano Styczeń 7, 2006 pecha to ja mam od zawsze trudno poczekam mam nadzieje ze sie szybko pojawi i ze wreszcie zaczeni dzialac No ale kiedys pech sie konczy i przychodz szczescie: [dex@localhost ~]$ glxinfo name of display: :0.0 display: :0 screen: 0 direct rendering: Yes server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig client glx vendor string: ATI client glx version string: 1.3 client glx extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float, GLX_ATI_render_texture GLX extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_multisample OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: RADEON 9550 Generic OpenGL version string: 1.3.5519 (X4.3.0-8.20.8) OpenGL extensions: GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array, GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_multisample, GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix, GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos, GL_ARB_draw_buffers, GL_ATI_draw_buffers, GL_ATI_element_array, GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_map_object_buffer, GL_ATI_separate_stencil, GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_ATI_vertex_array_object, GL_ATI_vertex_attrib_array_object, GL_ATI_vertex_streams, GL_ATIX_texture_env_combine3, GL_ATIX_texture_env_route, GL_ATIX_vertex_shader_output_point_size, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_texgen_reflection, GL_EXT_texture3D, GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_EXT_vertex_shader, GL_HP_occlusion_test, GL_NV_blend_square, GL_NV_occlusion_query, GL_NV_texgen_reflection, GL_SGI_color_matrix, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays glu version: 1.3 glu extensions: GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None 0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None 0x2b 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None 0x2c 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None 0x2d 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x30 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None 0x32 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None 0x33 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None 0x34 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None 0x35 8 pc 1 8 1 c y . 0 0 0 0 0 0 0 0 0 0 0 1 0 None 0x36 8 pc 1 8 1 c . . 0 0 0 0 0 0 0 0 0 0 0 1 0 None 0x37 8 gs 1 8 1 c y . 0 0 0 0 0 0 0 0 0 0 0 1 0 None 0x38 8 gs 1 8 1 c . . 0 0 0 0 0 0 0 0 0 0 0 1 0 None Sami ocencie wychodzi na to ze dziala wystarczylo tylko yum update yum install ati-fglrx yum install kernel-module-fglrx-$(uname -r) na wszelki wypadek restart systemu i juz dodam ze wszystko szlo normalnie z pod init 5 su - Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dalmatyn Napisano Styczeń 31, 2006 Zgłoszenie Share Napisano Styczeń 31, 2006 witam instaluję do mojego kernela: yum install ati-fglrx yum install kernel-module-fglrx-$(uname -r) wszystko idzie ok. następnie wydaje polecenie: [root@localhost dex]# glxinfo name of display: :0.0 Xlib: extension "XFree86-DRI" missing on display ":0.0". jak rozumiem ekran jest zagubiony na 0.0 gdzie i co pozmieniać, aby uruchomić akcelerację Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Styczeń 31, 2006 Zgłoszenie Share Napisano Styczeń 31, 2006 A moze by tak restart (ktorego nie zauwazylem)? ... jesli nie calego systemu, to chociaz X-ow?... Pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Other Napisano Styczeń 31, 2006 Zgłoszenie Share Napisano Styczeń 31, 2006 Proste musisz jeszcze zrobić: # aticonfig --initial Po tym restart kompa i masz akceleracje. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
smopi Napisano Luty 1, 2006 Zgłoszenie Share Napisano Luty 1, 2006 @Other Spójrz TU - zainstalowałem stery 8.18 na najnowszym jądrze i jest SUPER Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dalmatyn Napisano Luty 3, 2006 Zgłoszenie Share Napisano Luty 3, 2006 Proste musisz jeszcze zrobić: # aticonfig --initial Po tym restart kompa i masz akceleracje. Hah, pomogło, dziękuję Dlaczego nie ma o tym mowy w FAQ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
