Neostrada (speedtouch330)
raffk
Witam, od kilku dni probuje zainstalowac neostrade (na swoim pierwszym linuksie FC4)..
.. probowalem zrobic to skryptem z tej stronki:
http://www.neo.waw.pl/pliki/linux4.html
ale po potwierdzeniu danych pojawia sie:
Configuring SpeedTouch Driver...
Software Configuration - SUCCESS
Building SpeedTouch Driver...
Software Build - FAILED
Please check /tmp/speedtouch.make.txt for errors
[root@localhost speedtouchconf-10-Nov-2004]#
jesli sie nie pomylilem to plik z tmp to:
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking whether make sets $(MAKE)... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for unistd.h... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for stdlib.h... (cached) yes
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking for string.h... (cached) yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking for sys/types.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking for pid_t... yes
checking for size_t... yes
checking for an ANSI C-conforming const... yes
checking return type of signal handlers... void
checking for alarm... yes
checking for gettimeofday... yes
checking for memmove... yes
checking for memset... yes
checking for mkfifo... yes
checking for select... yes
checking for strdup... yes
checking for strerror... yes
checking for pthread_create in -lpthread... yes
checking for rpm... /usr/src/redhat
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/speedtouch-setup
config.status: creating src/speedtouch-start
config.status: creating src/speedtouch-stop
config.status: creating hotplug/Makefile
config.status: creating hotplug/speedtouch
config.status: creating doc-linux/Makefile
config.status: creating doc-bsd/Makefile
config.status: creating speedtouch.spec
probowalem tez instrukcja z http://www.webconexion.net/speedtouch/spee...uch_330_usb.php jednak:
Compile and install the speedtouch-1.2-beta1.tar.gz source as follows:
tar -xzvf speedtouch-1.2-beta1.tar.gz
cd speedtouch-1.2-beta1
./configure
make
make install
To confirm this has been installed correctly, type the following:
whereis speedtouch.conf
You should receive a response that shows /etc/speedtouch.confas well as other locations, although the others are not relevant in this document.
speedtouch.conf <- nie znajduje tego pliku, i nie ma go w zadnym z folderow
Dziś znalazłem na forum link do tutoriala na http://newbie.linux.pl/?id=article&kategor...&show=277&kom=1
niestety nie mialem na plycie instalacyjnej podanych tam plikow.. sciagnalem je z internetu.. ale..
[root@localhost here]# tar -xzf $ speedtouch-1.2-beta3.tar.gz -C /tmp
tar: $: Nie można open: Nie ma takiego pliku ani katalogu
tar: Błąd nie do naprawienia: koniec
tar: Child returned status 2
tar: speedtouch-1.2-beta3.tar.gz: Nie znalazłem w archiwum
tar: Zakończenie z błędem z powodu uprzednich błędów
[root@localhost here]# tar -xzf $ speedtouch-1.2-beta3 -C /tmp
tar: speedtouch-1.2-beta3: Nie znalazłem w archiwum
Bylbym bardzo wdzieczny jesli ktos pomogl mi zainstalowac ten mode i neostrada..
wiem ze ten temat pojawial sie na forum juz wielokrotnie, ale nie wiem juz co mam robic..
mam FC4, modem speedtouch 330..
Przy rozpakowaniu w nazwie pliku zrobiłeś spację:
nie oddzielaj $ od $speedtouch-1.2-beta3.tar.gz napisz to razem.
Błąd wynika z braku istnienia pliku $ bo plik do rozpakowania to $speedtouch-1.2-beta3.tar.gz
sorry mój błąd już poprawiłem przeczytaj jeszcze raz chodzi o wpisanie bez spacji : $speedtouch-1.2-beta3.tar.gz
na poczatku probowalem wpisywac bez spacji, ale mimo to pojawial sie ten sam napis.. ale sprobuje jeszcze raz
Moja porada zrób to tak jak tu pisze: http://forum.fedora.pl/index.php?showtopic=6475 Mi działa bezproblemowo
Moge skorzystac z tego postu jesli mam neostrade, a nie Net24?
W skrócie problemy napotykane przy instalacji usługi net24 biorą się z tego, że netia używa protokołu ATM - PPPoE w przeciwieństwie do tpsy która posługuje się protokołem ATM - PPPoA
Mam ten modem od ponad roku, nie jestem pewnien czy to akurat wersja 4.
sprobowalem jeszcze raz i ciagle jest tak samo.. jesli pisze razem, to nie dziala nawet dopelnienie, sprobowalem tez bez $, ale wtedy nic sie nie dzieje.. sad.gif
Sprobuje tutorialem entera..
edit:
ale nie wiem jaka jest pelna sciezka tych plikow:
http://prdownloads.sourceforge.net/Linux-a...86.rpm?download
http://Linux-usb.sourceforge.net/SpeedTouc...0226-1.i386.rpm
  • 4 weeks later...
