cygii Napisano Styczeń 17, 2006 Zgłoszenie Share Napisano Styczeń 17, 2006 Siedze pol dnia nad zainstalowaniem sterow Nvidia. Mam GF4MX440. Robilem jak w FAQ ( konfiguracja yuma , a pozniej kody) zrobilem nawet yum update, pozniej dalej yum install kernel-module-nvidia-$(rpm -q --queryformat="%{v ersion}-%{release}\n" kernel | tail -n 1) i wyszlo cos takiego Setting up Install Process Setting up repositories livna 100% |=========================| 951 B 00:00 updates-released 100% |=========================| 951 B 00:00 base 100% |=========================| 1.1 kB 00:00 extras 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 381 kB 02:47 updates-re: ################################################## 1115/1115 Added 61 new packages, deleted 25 old in 5.08 seconds Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package kernel-module-nvidia-2.6.11-1.1369_FC4.i686 0:1.0.7174-0.lvn.4.4 se t to be updated --> Running transaction check --> Processing Dependency: /usr/sbin/nvidia-config-display for package: kernel-m odule-nvidia-2.6.11-1.1369_FC4 --> Processing Dependency: nvidia-glx = 0:1.0.7174 for package: kernel-module-nv idia-2.6.11-1.1369_FC4 --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package nvidia-glx.i386 0:1.0.8178-0.lvn.1.4 set to be updated --> Running transaction check --> Processing Dependency: kernel-module-nvidia = 1.0.8178-0.lvn.1.4 for package : nvidia-glx --> Processing Dependency: nvidia-glx = 0:1.0.7174 for package: kernel-module-nv idia-2.6.11-1.1369_FC4 --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kernel-module-nvidia-2.6.14-1.1653_FC4.i686 0:1.0.8178-0.lvn.1.4 se t to be updated --> Running transaction check --> Processing Dependency: nvidia-glx = 0:1.0.7174 for package: kernel-module-nv idia-2.6.11-1.1369_FC4 --> Processing Dependency: /boot/vmlinuz-2.6.14-1.1653_FC4 for package: kernel-m odule-nvidia-2.6.14-1.1653_FC4 Importing Additional filelist information for dependency resolution filelists.xml.gz 100% |=========================| 3.0 MB 03:29 updates-re: ################################################## 1115/1115 Added 61 new packages, deleted 25 old in 18.81 seconds --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i686 0:2.6.14-1.1653_FC4 set to be installed --> Running transaction check --> Processing Dependency: nvidia-glx = 0:1.0.7174 for package: kernel-module-nv idia-2.6.11-1.1369_FC4 --> Finished Dependency Resolution Error: Missing Dependency: nvidia-glx = 0:1.0.7174 is needed by package kernel-m odule-nvidia-2.6.11-1.1369_FC4 ja juz nie wiem. Fedore Core 4 mam od 2 dni. Nie czaje jeszcze nic Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
wojtekjs Napisano Styczeń 17, 2006 Zgłoszenie Share Napisano Styczeń 17, 2006 Zainstaluj najpierw pakiet nvidia-glx, a dopiero potem sterowniki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cygii Napisano Styczeń 17, 2006 Autor Zgłoszenie Share Napisano Styczeń 17, 2006 A jest jakies polecenie do tego pakietu ?? jakas komenda yuma ?? Bo np jak daje yum install nvidia-glx = 0:1.0.7174 Setting up Install Process Setting up repositories livna 100% |=========================| 951 B 00:00 updates-released 100% |=========================| 951 B 00:00 base 100% |=========================| 1.1 kB 00:00 extras 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 377 kB 00:03 updates-re: ################################################## 1079/1079 Added 25 new packages, deleted 61 old in 5.45 seconds Parsing package install arguments Traceback (most recent call last): File "/usr/bin/yum", line 15, in ? yummain.main(sys.argv[1:]) File "/usr/share/yum-cli/yummain.py", line 72, in main result, resultmsgs = do() File "/usr/share/yum-cli/cli.py", line 412, in doCommands return self.installPkgs() File "/usr/share/yum-cli/cli.py", line 779, in installPkgs mypkg = self.returnPackageByDep(arg) File "__init__.py", line 1217, in returnPackageByDep ValueError: need more than 1 value to unpack to wychodzi cos takiego Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Styczeń 17, 2006 Zgłoszenie Share Napisano Styczeń 17, 2006 yum update odpalasz system na najnowszym kernelu yum install nvidia-glx kernel-module-nvidia-$(uname -r) ewentyualnie jezeli jezdzisz na starym jadrze i chcesz od razu miec nowe dozbrojone to yum install nvidia-glx kernel-module-nvidia-$(rpm -q --queryformat="%{version}-%{release}\n" kernel | tail -n 1) tak czy siak jak pomyslisz to w 5 minut to rozwiarzesz, slowo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cygii Napisano Styczeń 17, 2006 Autor Zgłoszenie Share Napisano Styczeń 17, 2006 Ani to ani to drugie ;] Dalej to samo. Poddaje sie. Odinstalowuje chyba tego FC ;] Aha moze od poczatku. Zaczalem instalowanie od Nvidia ..... ..... . .... .run przez telinit 3 itp ale wywalilo mi ze musze skompilowac kernela (czy cos takiego ) no to skonczylem. Installowalem tez przedtem TuxRacera i on wywalil mi blad o MESAie. Posciagalem te pliczki. Moze cos z tym jest zwiazane Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Możliwe, że zainstalowałeś więc spróbuj odinstalować w taki sposób jak instalowałeś tyle że dodając na końcu: --uninstall No i jeszcze mnie jedna rzecz ciekawi weź wpisz w konsoli, pod rootem takie coś: rpm -qa |grep nvidia i powiedz co wyrzuciłom. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cygii Napisano Styczeń 18, 2006 Autor Zgłoszenie Share Napisano Styczeń 18, 2006 Wpisalem rpm -qa |grep nvidia i nic sie nie dzieje. Przechodzi dalej yum install nvidia-glx kernel-module-nvidia-$(uname -r)--uninstall Setting up Install Process Setting up repositories livna 100% |=========================| 951 B 00:00 updates-released 100% |=========================| 951 B 00:00 base 100% |=========================| 1.1 kB 00:00 extras 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files Parsing package install arguments No Match for argument: kernel-module-nvidia-2.6.11-1.1369_FC4--uninstall Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package nvidia-glx.i386 0:1.0.8178-0.lvn.1.4 set to be updated --> Running transaction check --> Processing Dependency: kernel-module-nvidia = 1.0.8178-0.lvn.1.4 for package: nvidia-glx --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kernel-module-nvidia-2.6.14-1.1653_FC4.i686 0:1.0.8178-0.lvn.1.4 set to be updated --> Running transaction check --> Processing Dependency: /boot/vmlinuz-2.6.14-1.1653_FC4 for package: kernel-module-nvidia-2.6.14-1.1653_FC4 Importing Additional filelist information for dependency resolution --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i686 0:2.6.14-1.1653_FC4 set to be installed --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: nvidia-glx i386 1.0.8178-0.lvn.1.4 livna 3.9 M Installing for dependencies: kernel i686 2.6.14-1.1653_FC4 updates-released 14 M kernel-module-nvidia-2.6.14-1.1653_FC4 i686 1.0.8178-0.lvn.1.4 livna 1.5 M Transaction Summary ============================================================================= Install 3 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 20 M Is this ok [y/N]: y Downloading Packages: (1/3): kernel-2.6.14-1.16 100% |=========================| 14 MB 04:15 (2/3): kernel-module-nvid 100% |=========================| 1.5 MB 00:38 (3/3): nvidia-glx-1.0.817 100% |=========================| 3.9 MB 00:35 warning: rpmts_HdrFromFdno: Header V3 DSA signature: NOKEY, key ID a109b1ec public key not available for kernel-module-nvidia-2.6.14-1.1653_FC4-1.0.8178-0.lvn.1.4.i686.rpm Retrieving GPG key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-livna Importing GPG key 0xA109B1EC "Livna.org rpms <[email protected]>" Is this ok [y/N]: y Key imported successfully Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: kernel ######################### [1/3] Installing: nvidia-glx ######################### [2/3] Installing: kernel-module-nvidia-2.6.14- ######################### [3/3] Installed: nvidia-glx.i386 0:1.0.8178-0.lvn.1.4 Dependency Installed: kernel.i686 0:2.6.14-1.1653_FC4 kernel-module-nvidia-2.6.14-1.1653_FC4.i686 0:1.0.8178-0.lvn.1.4 Complete! No nareszcie tylko dziwne ze zainstalowalo mi przez polecenie uninstall Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
neo_fox Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Wpisalem rpm -qa |grep nvidia i nic sie nie dzieje. Przechodzi dalej Znaczy się nic nie znalazł Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 --uninstall masz wpisac po komendzie z nvidia......... .run Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cygii Napisano Styczeń 19, 2006 Autor Zgłoszenie Share Napisano Styczeń 19, 2006 No to juz nie wiem ja wpisalem tak jak przedtem i w koncu jest Complete. Z tym ze teraz mam 2 kernele. Jak usunac jeden z nich ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 Jak usunac jeden z nich ? rpm -qa |grep kernel rpm -e <kernel_numerki> Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
