orzeszko Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 Updateowałem dzisiaj yumem: May 03 13:56:42 Updated: openoffice.org-core.i386 1:2.0.2-5.9.2 May 03 13:57:09 Updated: bind-libs.i386 30:9.3.2-20.FC5 May 03 13:57:31 Updated: ghostscript.i386 8.15.2-1.1 May 03 13:57:34 Updated: libgdiplus.i386 1.1.13.6-1.fc5.1 May 03 13:57:49 Updated: mono-core.i386 1.1.13.7-1.fc5.1 May 03 13:57:54 Updated: mono-data.i386 1.1.13.7-1.fc5.1 May 03 13:58:03 Updated: mono-web.i386 1.1.13.7-1.fc5.1 May 03 13:58:19 Updated: system-config-printer.i386 0.6.151.4-1 May 03 13:58:26 Updated: bind.i386 30:9.3.2-20.FC5 May 03 13:58:39 Updated: openoffice.org-calc.i386 1:2.0.2-5.9.2 May 03 13:59:13 Updated: mozilla.i386 37:1.7.13-1.1.fc5 May 03 14:00:53 Updated: kdebase.i386 6:3.5.2-0.3.fc5 May 03 14:01:08 Updated: xorg-x11-server-Xorg.i386 1.0.1-9.fc5.1.1 May 03 14:01:30 Updated: thunderbird.i386 1.5.0.2-1.1.fc5 May 03 14:01:35 Updated: system-config-printer-gui.i386 0.6.151.4-1 May 03 14:01:41 Updated: openoffice.org-base.i386 1:2.0.2-5.9.2 May 03 14:01:50 Updated: anacron.i386 2.3-38.FC5 May 03 14:01:53 Updated: bind-utils.i386 30:9.3.2-20.FC5 May 03 14:02:02 Updated: openoffice.org-impress.i386 1:2.0.2-5.9.2 May 03 14:02:18 Updated: openoffice.org-langpack-pl_PL.i386 1:2.0.2-5.9.2 May 03 14:02:21 Updated: openoffice.org-xsltfilter.i386 1:2.0.2-5.9.2 May 03 14:02:58 Installed: kernel.i686 2.6.16-1.2107_FC5 May 03 14:03:05 Updated: nfs-utils.i386 1.0.8.rc2-5.FC5 May 03 14:03:12 Updated: openoffice.org-writer.i386 1:2.0.2-5.9.2 May 03 14:03:18 Updated: openoffice.org-draw.i386 1:2.0.2-5.9.2 May 03 14:03:21 Updated: dhcdbd.i386 1.14-1.FC5 May 03 14:03:26 Updated: bind-config.i386 30:9.3.2-20.FC5 May 03 14:03:28 Updated: mono-data-sqlite.i386 1.1.13.7-1.fc5.1 May 03 14:03:31 Updated: xterm.i386 212-1.FC5 May 03 14:03:35 Updated: openoffice.org-graphicfilter.i386 1:2.0.2-5.9.2 May 03 14:03:43 Updated: openoffice.org-math.i386 1:2.0.2-5.9.2 May 03 14:04:23 Installed: kernel-devel.i686 2.6.16-1.2107_FC5 i po aktualizacji system uruchamia mi się do czarnego ekranu z kursorem "x" - tak wisi. Na wcześniejszym jądrze wstaje bez zająknięcia. Przy init:3 też wstaje, X-y mozna uruchomić za pomocą startx. Tylko nie są wstanie się podnieść przy init:5. Czemu? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 A to nie jakieś problemy z nvidia? Bo chyba nie ma jeszcze modułu do kernela 2.6.16-1.2107_FC5 Pozdr, W. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Andrzej Orkan Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 MIAŁEM DOKŁADNIE TO SAMO a nie mam karty nVidii. To jest jakiś bug w nowym jądrze. Zakomentowałem w grub.conf nowy wpis i korzystam z poprzedniego jądra. A z miejsca, w którym masz tylko czarny x możesz wyjść naciskając kombinację klawiszy CTRL + SHIFT + BACKSPACE czyli zabijając X-y. Wtedy ładowanie systemu ci się dokończy ale z błędami (mi np nie rozpoznał NTFSa). Trzeba zrestartować ze starego jądra. Orkan Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 Przeoczyłem - oczywiście są nowe moduły nvidia. Właśnie zaktualizowałem, odpaliłem - bez problemów. Może to coś ze sprzętem, jakis błąd dla określonych kart albo monitorów? Pozdr, W. P.S.Ja mam starą GeForce2 MX400 64MB i SyncMaster 753DFX. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Rasp Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 Przeoczyłem - oczywiście są nowe moduły nvidia hmm możliwe że są... ale na razie update u mnie kuleje.... Pan yum mówi mi tak: Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package kmod-nvidia.i686 0:1.0.8756-2.2.6.16_1.2107_FC5 set to be installed ---> Package kmod-ntfs.i686 0:2.1.26-5.2.6.16_1.2107_FC5 set to be installed --> Running transaction check --> Processing Dependency: kernel-i686 = 2.6.16-1.2107_FC5 for package: kmod-ntfs --> Processing Dependency: kernel-i686 = 2.6.16-1.2107_FC5 for package: kmod-nvidia --> Finished Dependency Resolution Error: Missing Dependency: kernel-i686 = 2.6.16-1.2107_FC5 is needed by package kmod-ntfs Error: Missing Dependency: kernel-i686 = 2.6.16-1.2107_FC5 is needed by package kmod-nvidia Muszę poczekać na zależności... P.S.Ja mam starą GeForce2 MX400 64MB Ja też... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 Rasp, no się nie wygłupiaj. Na jakie zależności chcesz czekać ? Musisz przecież kernela zainstalować odpowiedniego. A może ty robisz update modułów na starym jajku? Ja zrobiłem: yum install kernel kmod-nvidia kmod-ntfs i weszła najnowsza wersja kernela i odpowiednie dla niej moduły. No i install był a nie update Pozdr, W. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Stef Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 Usunięcie/wyłączenie rhgb również czasem pomaga. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Rasp Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 Rasp, no się nie wygłupiaj..... No właśnie zrobiłem ładnie yum clean all a następnie yum install kernel niestety efekt taki sam jak przy yum install kernel-2.6.16-1.2107_FC5 Nie wiem czemu nie łapie mi z repo kernela... :/ Ktoś wie co jest temu winne.... Co do rhgb to niechcę narazie usuwać.. WalDo kiedy robiłeś update? Pozdrawiam Rasp.. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
orzeszko Napisano Maj 3, 2006 Autor Zgłoszenie Share Napisano Maj 3, 2006 ja nie mam nVidii, mam ATi ... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 Update dzisiaj, tak jak pisalem powyżej. Czyli musiało być przed 15.00. Było trochę problemów z extras - muliło, ale przeszło w końcu. Ale kernel to przecież nie z extras idzie. Pozdr, W. P.S.Na aktualizacji thunderbirda wymiękłem - miało trwać ponad 1,5h Poczekam, aż będzie transfer lepszy Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
orzeszko Napisano Maj 3, 2006 Autor Zgłoszenie Share Napisano Maj 3, 2006 (edytowane) są nowe fglrx-y, zainstalowałem - pupa: dalej to samo ... Edit: Zdecydowanie jest to problem rhgb - po wywaleniu działa bez problemu! Czekać czy zgłosić problem (gdzie)? Edytowane Maj 3, 2006 przez orzeszko Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Maj 3, 2006 Zgłoszenie Share Napisano Maj 3, 2006 Czekać czy zgłosić problem (gdzie)? Problem już został zgłoszony: https://bugzilla.redhat.com/bugzilla/show_b...g.cgi?id=190575 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
orzeszko Napisano Maj 4, 2006 Autor Zgłoszenie Share Napisano Maj 4, 2006 No widze problem poważniejszy Ale mam jedno pytanie niejako związane ze sprawą - dzisiaj aktualizuję FC5 w pracy i nie pojawia mi się kernel 2107 do update - mam rozumiem, że chwilowo jest "wstrzymany" właśnie z powodu rhgb? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Maj 4, 2006 Zgłoszenie Share Napisano Maj 4, 2006 No widze problem poważniejszy Ale mam jedno pytanie niejako związane ze sprawą - dzisiaj aktualizuję FC5 w pracy i nie pojawia mi się kernel 2107 do update - mam rozumiem, że chwilowo jest "wstrzymany" właśnie z powodu rhgb? Nowy kernel nadal jest w updates i pewnie tam pozostanie. Być może mirrory, z których korzystasz jeszcze go nie zassały (większość ma sync co 24h). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
orzeszko Napisano Maj 4, 2006 Autor Zgłoszenie Share Napisano Maj 4, 2006 (edytowane) hmmm... i w pracy i w domu używam tych samych, m.in. livny ... Updateowałem przed chwileczką, robiłem nawet przedtym clean all i nie ma - dalej jadę na 2096 ... Edit: Wiem gdzie może leżec problem - w pracy mam system updateowany z FC4 na FC5, natomiast w domu mam FC5 stawianą od zera... Edytowane Maj 4, 2006 przez orzeszko Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
