Instalacja Sterowników Ati
Other
Witam.
Zainstalowałem sterowniki z repo Livny. Mam Radeona X1600 Mobility w laptopie ACER 5112 WLMi.
Oto co otrzymałem:
fglrxinfo:
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: ATI Mobility Radeon X1600
OpenGL version string: 2.1.7281 Release
glxgears:
12804 frames in 5.0 seconds = 2560.689 FPS
14245 frames in 5.0 seconds = 2848.936 FPS
13633 frames in 5.0 seconds = 2726.431 FPS
13727 frames in 5.0 seconds = 2745.161 FPS
12169 frames in 5.0 seconds = 2433.688 FPS
11122 frames in 5.0 seconds = 2224.366 FPS
13734 frames in 5.0 seconds = 2746.694 FPS
10885 frames in 5.0 seconds = 2176.961 FPS
14797 frames in 5.0 seconds = 2959.354 FPS
14331 frames in 5.0 seconds = 2866.186 FPS
14504 frames in 5.0 seconds = 2900.685 FPS
14674 frames in 5.0 seconds = 2934.788 FPS
14674 frames in 5.0 seconds = 2934.676 FPS
14120 frames in 5.0 seconds = 2823.819 FPS
13810 frames in 5.0 seconds = 2761.960 FPS
14132 frames in 5.0 seconds = 2826.286 FPS
14506 frames in 5.0 seconds = 2901.188 FPS
13485 frames in 5.0 seconds = 2696.883 FPS
13194 frames in 5.0 seconds = 2638.715 FPS
14254 frames in 5.0 seconds = 2850.706 FPS
13687 frames in 5.0 seconds = 2737.321 FPS
13453 frames in 5.0 seconds = 2690.482 FPS
Czy te wyniki można uznać za satysfakcjonujące dla tego modelu?
  • 1 month later...
  • Odpowiedzi 213
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
Witam mam problem z instalacją sterowników ATI x1100
Oto co mi wyświetla
[booss@localhost ~]$ su -
Hasło:
[root@localhost ~]# yum -y install kmod-fglrx
Loading "priorities" plugin
adobe                     100% |=========================|  951 B    00:00
livna                     100% |=========================| 2.1 kB    00:00
fedora                    100% |=========================| 2.1 kB    00:00
kde-redhat-all            100% |=========================|  951 B    00:00
kde-redhat                100% |=========================| 1.1 kB    00:00
updates                   100% |=========================| 2.3 kB    00:00
freshrpms                 100% |=========================| 2.1 kB    00:00
122 packages excluded due to repository priority protections
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package kmod-fglrx.i686 0:8.476-3.8.04.lvn8 set to be updated
--> Processing Dependency: kmod-fglrx-2.6.24.7-92.fc8 = 8.476-3.8.04.lvn8 for package: kmod-fglrx
---> Package kmod-fglrx-2.6.24.7-92.fc8.i686 0:8.476-3.8.04.lvn8 set to be updated
--> Processing Dependency: fglrx-kmod-common >= 8.476 for package: kmod-fglrx-2.6.24.7-92.fc8
---> Package xorg-x11-drv-fglrx.i386 0:8.476-1.8.04.lvn8 set to be updated
--> Processing Dependency: libfglrx_gamma.so.1 for package: xorg-x11-drv-fglrx
--> Processing Dependency: livna-config-display >= 0.0.18 for package: xorg-x11-drv-fglrx
--> Processing Dependency: libstdc++.so.5(GLIBCPP_3.2) for package: xorg-x11-drv-fglrx
--> Processing Dependency: /usr/lib/fglrx/libGL.so.1.2 for package: xorg-x11-drv-fglrx
--> Processing Dependency: libstdc++.so.5 for package: xorg-x11-drv-fglrx
--> Processing Dependency: libstdc++.so.5(CXXABI_1.2) for package: xorg-x11-drv-fglrx
--> Processing Dependency: xorg-x11-drv-fglrx-libs = 8.476-1.8.04.lvn8 for package: xorg-x11-drv-fglrx
--> Processing Dependency: livna-config-display for package: xorg-x11-drv-fglrx
---> Package compat-libstdc++-33.i386 0:3.2.3-62 set to be updated
---> Package ati-x11-drv.i386 0:8.40.4-2.fc7 set to be updated
--> Processing Dependency: dkms for package: ati-x11-drv
---> Package livna-config-display.noarch 0:0.0.20-1.lvn8 set to be updated
---> Package xorg-x11-drv-fglrx-libs.i386 0:8.476-1.8.04.lvn8 set to be updated
---> Package dkms.noarch 0:2.0.17.5-1.fc8 set to be updated
--> Processing Conflict: ati-x11-drv conflicts xorg-x11-drv-fglrx
--> Finished Dependency Resolution
Error: ati-x11-drv conflicts with xorg-x11-drv-fglrx
co z tym powinienem zrobić??
Ja bym odinstalował stare i zainstalował od nowa.
[EDIT]tylko bez opcji "-y" przy odinstalowaniu - warto przejrzeć wcześniej listę tego co ma być usunięte i świadomie wcisnąć "y" lub "N" (w przypadku F9 "t" lub "N" ;) )
Masz tam niezly b****l ;)
... a to prawdopodobnie dla tego, ze wymieszales niekompatybilne repozytoria i/lub instalowales cos z palca (rpm -Uvh ... --force ... --nofiles ... --nodeps ...)
Nie wiem jak jest teraz z repo kde-*, ale livna i freshrpms jednoczesnie to na pewno bardzo zly pomysl...
Nie wiem takze jak bardzo namieszales (czyt.: napsules) juz sobie w systemie, ale wylacz freshrpms i postepuj zgodnie z tym co Ci napisal WalDo ...
Powodzenia
  • 2 weeks later...
i jak tu livne zainstalować??
A ja mam inne pytanie. W ilu postach chcesz jeszcze o tę Livnę pytać? Może zamiast pytać to należy przejrzeć forum, zapytać w Googlach, wejść na stronę rpm.livna.org a dopiero jak to nie pomoże to pytać.
GOOGLE!
Ten temat jest poruszany n-ty raz na tym forum!
NVIDIA i ATI nie wydali sterów do Xorga którego ma Fedora 9 i NIE MA STERÓW!
No to chyba bardzo wazna uwaga, a wlasnie mialem sciagac fedore i sie na nie przesiasc ale wczesniej chcialm spawdzic jak z ati
mam taki mały delikatny problem:/ z racji ze jestem swieżo upieczonym linuxowcem nie bardzo jeszcze sie oriętuje mimo ze juz siedze od czasu F7
mianowicie mam juz F9 i mam standardowo problem ze sterami do ATI Radeona 9550 :/
we wczesniejszych jakoś mi sie udawało ruszyć je, ale w F9 nie idzie sie uporać :/
instalowałem na dwa sposoby, poprzez sciągniecie z oficialnej strony ATI sterów jak i opisany tu sposób... przy obu sposobach po zrestartowaniu kompa wywala mi X-y :/ czyli dopuki nie wstukam
aticonfig -initial
to moge normalnie odpalic KDE jak i GNOME a tak to stoi mi w konsoli....:/
moja konfig kompa:
Athlon XP 2000+
AtiRadeon 9550 128Mb
512 ramu
monitorek 19"
wiecej chyba nie trzeba....
  • 5 weeks later...
witam
mam podobny problem jak kolega kilka postów wcześniej, tzn instaluje zgodnie z http://forums.fedoraforum.org/showthread.php?t=155503, wszystko instaluje się ok, po podaniu "service fglrx restart" mam odpowiedz:
checking for module fglrx.ko: ok
Enabling the fglrx driver: Driver already enabled ok
potem wpisuje: "fglrx-config-display enable" i odpowiedz: "Driver already enabled ok"
zgodnie ze wskazówkami edytuje xorga, potem ctrl+alt+backspace no i restart iksa i jasny ekran, przy restarcie kompa tak samo, kiedy już się ma załadować okno logowania jasny ekran, odpaliłem na starszym jądrze(po zainstalowaniu fc8 zrobiłem aktualizacje) włącza się i co dziwne jest rozdziałka mojego monitora 1400x900(fglrx nie wchodzi, na logikę biorąc niby ok bo jest zainstalowany dla nowej wersji jądra). Próbowałem zmienić kilka opcji w xorg np composite na disabled ale to nie przynosi skutku. Proszę o jakieś wskazówki, aha mam x1950 ale z tego co widzę to jest obsługiwany.
pozdrawiam
  • 2 months later...
Instalacja sterownika ATI Catalyst nie działa, wyświetla mi brak paczki w repozytorium.
Wczytane wtyczki: fastestmirror, fedorakmod, kernel-module, refresh-packagekit
Loading mirror speeds from cached hostfile
* livna: ftp-stud.fht-esslingen.de
* skype: download.skype.com
* fedora: sunsite.icm.edu.pl
* adobe-linux-i386: linuxdownload.adobe.com
* updates: ftp.wsisiz.edu.pl
Ustawianie procesu instalacji
Analizowanie argumentów instalacji pakietów
Nie ma pakietu kmod-fglrx.
Nie ma niczego do zrobienia
Sterownik nie występuje także w repozytorium pod nazwą kmod-catalyst .
