Problem Z Winecvs Dla Cs Source
Burn112
Chce pograc w CS Source na Steamie. Robie wszystko wedlug http://www.linux-gamers.net/modules/wiwimo...+Steam&back .
Instaluje WIneCVS w wersji Wine DX9 i wywala mi blad:
WineCVS.sh - Progress(u) : Green is current
0 = Uninstall
1 = Cleanup
2 = CVS checkout
3 = Configure
4 = Make depend
5 = Make
6 = Make install
7 = Finish up
Compiling ...
TIP: Useful linux gaming pages:
--------- Error log - file /root/.WineCVS/sources/dx9wine/ErrorLog : ---------
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/ddraw'
make[2]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/x11drv'
make[2]: Nie ma nic do zrobienia w `all'.
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/x11drv'
make[2]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/avifil32'
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/avifil32'
make[2]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/kernel'
make[3]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/kernel/tests'
make[3]: Nie ma nic do zrobienia w `all'.
make[3]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/kernel/tests'
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/kernel'
make[2]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/commdlg'
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/commdlg'
make[2]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/ole32'
make[3]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/ole32/tests'
make[3]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/ole32/tests'
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/ole32'
make[2]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/ctl3d'
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/ctl3d'
make[2]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/user'
make[3]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/user/tests'
make[3]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/user/tests'
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/user'
make[2]: Wejscie do katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/gdi'
gcc -c -I. -I. -I../../include -I../../include -I/usr/include/freetype2 -D__WINESRC__ -D_GDI32_ -D_REENTRANT -fPIC -Wall -pipe -mpreferred-stack-boundary=2 -fno-strict-aliasing -gstabs+ -Wdeclaration-after-statement -Wpointer-arith -g -O2 -o freetype.o freetype.c
freetype.c:106: error: ‘FT_Get_Module’ undeclared here (not in a function)
freetype.c:106: warning: type defaults to ‘int’ in declaration of ‘pFT_Get_Module’
freetype.c: In function ‘WineEngGetFontData’:
freetype.c:3698: error: ‘TT_Face’ undeclared (first use in this function)
freetype.c:3698: error: (Each undeclared identifier is reported only once
freetype.c:3698: error: for each function it appears in.)
freetype.c:3698: error: expected ‘;’ before ‘tt_face’
freetype.c:3699: error: ‘SFNT_Interface’ undeclared (first use in this function)
freetype.c:3699: error: ‘sfnt’ undeclared (first use in this function)
freetype.c:3703: error: expected expression before ‘)’ token
freetype.c:3703: error: ‘tt_face’ undeclared (first use in this function)
freetype.c:3708: error: expected expression before ‘)’ token
freetype.c: In function ‘is_hinting_enabled’:
freetype.c:3776: error: called object ‘pFT_Get_Module’ is not a function
freetype.c:3777: warning: implicit declaration of function ‘FT_DRIVER_HAS_HINTER’
make[2]: *** [freetype.o] Blad 1
make[2]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls/gdi'
make[1]: *** [gdi] Blad 2
make[1]: Opuszczenie katalogu `/root/.WineCVS/sources/dx9wine/wine/dlls'
make: *** [dlls] Blad 2
Error in Make
Try fixing the error based on the output above, and
run the script again, without paramaters (Eg: WineCVS.sh)
Szukalem w necie, ale podobnego bledu jeszcze nie znalazlem... Wydaje mi sie, ze to moze byc jakis problem z freetype, ale zainstalowalem wszystkie dostepne w pakietach...
Ale ten Wine przez yum to sa tylko te pakieciki co potrzebuje, czy caly program WIne?? Bo caly programik to ja juz mam zainstalowany w najnowszej wersji, tylko, ze potrzebuje tych danych wspomagajacych akceleracje (tzn. np. pseudo DirectX).
Troche namieszalem, ale nie wiem jak to nazwac, chyba wiadomo o co mi chodzi ^^
Jak sie dostac do ~/.wine/drive_c/windows/fonts ?? Normalnie jak wchodze do systemu plików to nie ma nigdzie .wine , jedyny sposób na wejscie to przez program WineFile, wejscie tam w folder root i dopiero tam mam tego .wine , ale normalnie jak wchodze w root to nie ma takich folderów, a przez WineFile nie moge przenosic plików...
EDIT: Sorry wielkie, wszedlem przez MC ^^
EDIT2: Udalo mi sie wszystko zainstalowac tak, ze uruchamia mi sie bez problemu Steam. Niestety próbowalem skopiowac pliki CS Source z instalacji na drugim PC (WinXP) i niestety Steam w obecnym stanie nie moze wykryc kopiowanego CS'a, dlatego powiem co i jak jutro jak mi sie pobierze z serwera SteamPowered. Cale szczescie sprawdzilem, czy Wine zachowuje informacje dla Steam dla np. % sciagania plików i zapisanych danych uzytkownika, czemu moge byc pewien, ze Steam sam w sobie jest stabilny i nie sprawia problemów. Niestety z tego co czytalem to dopeiro polowa sukcesu, bo CS Source moze sprawiac lekkie problemy, ale jestem pewien, ze w razie czego moge liczyc na Wasza pomoc.
EDIT3: Niby wszystko dziala, ale strasznie spadl fps. 10fps bez zadnej akcji, podejrzewam, ze to zla konfiguracja czy cos, pobawie sie w ustawieniach i zoabczymy.
Sorry, że post pod postem. Nie bierzcie tego osoboście, ale poprostu nie chcę rozciągać tamtego postu, o kolejne edity.
Po zmniejszeniu detali wszystko się ładnie uruchamia, fps nie jest specjlanie zadowalający (marne 50 fps przy prawie minimum detali i 1280x1024?).
Uruchomiłem gre poprzez komende:
[Fedora@localhost ~]$ #!/bin/bash
[Fedora@localhost ~]$ WINEDEBUG=fixme-all wine C:/Program\ Files/Steam/Steam.exe -fullscreen \
>     -width 1280 -height 1024 -applaunch 240 \
>     -heapsize 512000 +map_background none "$@"
i podczas testowania gry pojawiły mi się takie logi, aż do momentu wyłączenia gry:
err:ole:CoGetClassObject class {9a5ea990-3034-4d6f-9128-01f3c61022bc} not registered
err:ole:CoGetClassObject no class object {9a5ea990-3034-4d6f-9128-01f3c61022bc} could be created for context 0x1
err:ole:CoGetClassObject class {4955dd33-b159-11d0-8fcf-00aa006bcc59} not registered
err:ole:CoGetClassObject no class object {4955dd33-b159-11d0-8fcf-00aa006bcc59} could be created for context 0x1
err:systray:delete_icon invalid tray icon ID specified: 1d
err:mshtml:nsIOService_NewURI Could not get nsIWineURI: 80004002
err:ole:CoGetClassObject class {4590f811-1d3a-11d0-891f-00aa004b2e24} not registered
err:ole:CoGetClassObject no class object {4590f811-1d3a-11d0-891f-00aa004b2e24} could be created for context 0x1
err:x11settings:X11DRV_ChangeDisplaySettingsEx No matching mode found! (XRandR)
err:wave:DSDB_MapBuffer Could not map sound device for direct access (Błąd wejścia/wyjścia)
err:wave:DSDB_MapBuffer Please run winecfg, open "Audio" page and set
"Hardware Acceleration" to "Emulation".
err:dscapture:widDsCreate DirectSoundCapture flag not set
This sound card's driver does not support direct access
The (slower) DirectSound HEL mode will be used instead.
warning: Unknown nb_ctl request:  4
err:mshtml:set_profile SetCurrentProfile failed: 80520015
err:d3d_shader:shader_get_registers_used No texture bound to sampler 4
err:d3d9:IDirect3DDevice9Impl_StretchRect Texture filters not supported yet
err:seh:setup_exception stack overflow 56 bytes in thread 0047 eip 71d521c7 esp 61625fc8 stack 0x61626000-0x61736000
Unable to remove c:\program files\steam\shortcuts.dat!
Shutting down. . .
1err:seh:setup_exception stack overflow 84 bytes in thread 0061 eip 7051c7d4 esp 624e3fac stack 0x624e4000-0x625f4000
Naruszenie ochrony pamięci
Jak widać, głównym problemem jest błąd Direct3D... Ktoś wie co z tym zrobić?? Podejrzewam, że jednak jest wymagany WineCVS. Dodatkowo jest problem z kartą dźwiękową, myślę, że to może być powiązane z Directem.
EDIT: Kolejna porcja błędów tym razem po dłuższej partii w necie. Do tego dochodzą błędu wyglądu wody (woda wygląda jak ściana 2D) i błędy cieni (nie chodzą z postacią!) :
Unable to remove c:\program files\steam\steamapps\derin_91\counter-strike source\cstrike\textwindow_temp.html!
err:seh:setup_exception stack overflow 56 bytes in thread 0047 eip 602bc1c7 esp 73851fc8 stack 0x73852000-0x73962000
wine: Unhandled page fault on read access to 0x00000024 at address 0xd2eb413 (thread 0053), starting debugger...
Unhandled exception: page fault on read access to 0x00000024 in 32-bit code (0x0d2eb413).
Register dump:
CS:0073 SS:007b DS:007b ES:007b FS:0033 GS:003b
EIP:0d2eb413 ESP:0034e5e8 EBP:00000002 EFLAGS:00010212(   - 00      - RIA1)
EAX:00000020 EBX:00000000 ECX:1cbe14e0 EDX:072559c0
ESI:0d2fea18 EDI:00000090
Stack dump:
0x0034e5e8:  0d2fea18 0055386c 0d2eb442 1cbe0002
0x0034e5f8:  0d2fea18 0055386c 0d2fea18 1cbe0006
0x0034e608:  0d2eb7c5 1cbe0006 0d2fea18 1cbe0006
0x0034e618:  0d2fea3c 00000020 0d2fea18 0d2e98ca
0x0034e628:  1cbe0001 ffffffff 00000000 00000009
0x0034e638:  0034ff08 0034e67c 1000753b 00000003
Backtrace:
=>1 0x0d2eb413 in datacache (+0xb413) (0x00000002)
 2 0x00000000 (0x00000000)
0x0d2eb413: movl        0x24(%ebx),%eax
Modules:
Module  Address                 Debug info      Name (211 modules)
PE      350000-386000   Deferred        tier0
PE      390000-3ae000   Deferred        vstdlib
PE      3b0000-3fd000   Deferred        filesystem_steam
PE      400000-41c000   Deferred        hl2
PE      d090000-d18e000 Deferred        datamodel
PE      d2a0000-d2dd000 Deferred        dmserializers
PE      d2e0000-d305000 Export          datacache
PE      d310000-d324000 Deferred        inputsystem
PE      d440000-d4f4000 Deferred        materialsystem
PE      d500000-d516000 Deferred        valve_avi
PE      d520000-d64d000 Deferred        vguimatsurface
PE      d650000-d6c5000 Deferred        vgui2
PE      d6d0000-dd48000 Deferred        engine
PE      dd50000-dd63000 Deferred        steam_api
PE      df90000-dfb9000 Deferred        stdshader_dbg
PE      dfc0000-dff5000 Deferred        stdshader_dx6
PE      e000000-e028000 Deferred        stdshader_dx7
PE      e030000-e073000 Deferred        stdshader_dx8
PE      e080000-e08f000 Deferred        unicode
PE      e090000-e0c6000 Deferred        soundemittersystem
PE      e0d0000-e0eb000 Deferred        scenefilecache
PE      e0f0000-e169000 Deferred        vstdlib_s
PE      e700000-e879000 Deferred        steamclient
PE      e880000-e8c0000 Deferred        tier0_s
PE      eae0000-ed65000 Deferred        gameui
PE      f890000-f8a0000 Deferred        vaudio_miles
PE      f8a0000-f964000 Deferred        friendsui
PE      10000000-10030000       Deferred        launcher
PE      1cc70000-1cd3b000       Deferred        serverbrowser
PE      1cd70000-1cd76000       Deferred        xpcom
PE      1d350000-1d377000       Deferred        vaudio_speex
PE      1d380000-1d3e5000       Deferred        xpcom_core
PE      1d3f0000-1d417000       Deferred        nspr4
PE      1d420000-1d427000       Deferred        plc4
PE      1d430000-1d436000       Deferred        plds4
PE      1e740000-1e74f000       Deferred        jsd3250
PE      1e750000-1e7b9000       Deferred        js3250
PE      1e7c0000-1e7f2000       Deferred        xpc3250
PE      1e800000-1e806000       Deferred        xpistub
PE      1f490000-1f4ab000       Deferred        ssl3
PE      1ff70000-1ffc9000       Deferred        nss3
PE      1ffd0000-1ffe4000       Deferred        xpcom_compat
PE      1fff0000-1fff8000       Deferred        npnul32
PE      20000000-2031d000       Deferred        steam
PE      210f0000-210f7000       Deferred        palmsyncproxy
PE      21100000-21164000       Deferred        mss32
PE      21f40000-21f9a000       Deferred        softokn3
PE      21fa0000-21fda000       Deferred        nssckbi
PE      21fe0000-21ff1000       Deferred        mozz
PE      22000000-22641000       Deferred        server
PE      233f0000-23424000       Deferred        msgbsutl
PE      23430000-2344a000       Deferred        smime3
PE      23450000-23466000       Deferred        gkgfx
PE      23470000-23483000       Deferred        jsj3250
PE      23490000-2350b000       Deferred        necko
PE      23510000-2351c000       Deferred        xppref32
PE      23520000-2354e000       Deferred        i18n
PE      23550000-2356e000       Deferred        embedcomponents
PE      23570000-2357f000       Deferred        caps
PE      23580000-23598000       Deferred        palmsync
PE      235a0000-235ac000       Deferred        typeaheadfind
PE      235b0000-2387d000       Deferred        gklayout
PE      23880000-238a5000       Deferred        imglib2
PE      238b0000-238ca000       Deferred        rdf
PE      238d0000-23909000       Deferred        appcomps
PE      23910000-23920000       Deferred        appshell
PE      23920000-2392e000       Deferred        profile
PE      23930000-23937000       Deferred        xpcom_compat_c
PE      23940000-2394e000       Deferred        webbrwsr
PE      23950000-23975000       Deferred        gkwidget
PE      23980000-239a4000       Deferred        gkgfxwin
PE      239b0000-239dc000       Deferred        docshell
PE      239e0000-239e8000       Deferred        pipboot
PE      239f0000-239fc000       Deferred        oji
PE      23a00000-23abb000       Deferred        uconv
PE      23bd0000-23bd7000       Deferred        perms
PE      23be0000-23be9000       Deferred        cookie
PE      23bf0000-23c00000       Deferred        chrome
PE      23c00000-23c38000       Deferred        gkparser
PE      23c40000-23c4d000       Deferred        jar50
PE      23d60000-23d67000       Deferred        txmgr
PE      23f90000-23fb1000       Deferred        cserhelper
PE      24000000-24507000       Deferred        client
PE      26000000-26138000       Deferred        vphysics
PE      26400000-26439000       Deferred        mssvoice.asi
PE      26f00000-26f2e000       Deferred        mssmp3.asi
PE      2a000000-2a0a8000       Deferred        shaderapidx9
PE      2c000000-2c3e3000       Deferred        studiorender
ELF     4a879000-4a87b000       Deferred        libnvidia-tls.so.1
ELF     4a87d000-4b25e000       Deferred        libglcore.so.1
ELF     4cc00000-4cc1b000       Deferred        ld-linux.so.2
ELF     4cc1d000-4cd5a000       Deferred        libc.so.6
ELF     4cd5c000-4cd83000       Deferred        libm.so.6
ELF     4cd85000-4cd89000       Deferred        libdl.so.2
ELF     4cd8b000-4cd9e000       Deferred        libz.so.1
ELF     4ce40000-4cf42000       Deferred        libx11.so.6
ELF     4cf44000-4cf47000       Deferred        libxau.so.6
ELF     4cf49000-4cf4f000       Deferred        libxdmcp.so.6
ELF     4cf92000-4cfa2000       Deferred        libxext.so.6
ELF     4cfa9000-4cfca000       Deferred        libexpat.so.0
ELF     4cfcc000-4cfe3000       Deferred        libpthread.so.0
ELF     4cfe5000-4d065000       Deferred        libfreetype.so.6
ELF     4d067000-4d096000       Deferred        libfontconfig.so.1
ELF     4d0c0000-4d0c9000       Deferred        libxrender.so.1
ELF     4d116000-4d11b000       Deferred        libxfixes.so.3
ELF     4d11d000-4d127000       Deferred        libxcursor.so.1
ELF     4d1dc000-4d1df000       Deferred        libxinerama.so.1
ELF     4d27f000-4d283000       Deferred        libxrandr.so.2
ELF     4d6ae000-4d6c5000       Deferred        libnsl.so.1
ELF     4d6c7000-4d6da000       Deferred        libresolv.so.2
ELF     4da0c000-4da15000       Deferred        libsm.so.6
ELF     4da9b000-4dab5000       Deferred        libice.so.6
ELF     4db08000-4db14000       Deferred        libgcc_s.so.1
ELF     4e07a000-4e0a8000       Deferred        libcrypt.so.1
ELF     4e121000-4e157000       Deferred        libcups.so.2
ELF     4e231000-4e235000       Deferred        libgpg-error.so.0
ELF     4e237000-4e28c000       Deferred        libgcrypt.so.11
ELF     4e3b0000-4e42d000       Deferred        libgnutls.so.13
ELF     60285000-60321000       Deferred        ntdll<elf>
 \-PE  602a0000-60321000       \               ntdll
ELF     60348000-6047d000       Deferred        kernel32<elf>
 \-PE  60360000-6047d000       \               kernel32
ELF     6047d000-60488000       Deferred        libnss_files.so.2
ELF     60488000-6048c000       Deferred        iso8859-2.so
ELF     6048c000-605d8000       Deferred        user32<elf>
 \-PE  604b0000-605d8000       \               user32
ELF     605d8000-60676000       Deferred        gdi32<elf>
 \-PE  605f0000-60676000       \               gdi32
ELF     60676000-606bf000       Deferred        advapi32<elf>
 \-PE  60680000-606bf000       \               advapi32
ELF     6078f000-60821000       Deferred        winex11<elf>
 \-PE  607a0000-60821000       \               winex11
ELF     61407000-61421000       Deferred        wsock32<elf>
 \-PE  61410000-61421000       \               wsock32
ELF     61421000-61440000       Deferred        iphlpapi<elf>
 \-PE  61430000-61440000       \               iphlpapi
ELF     61453000-614f8000       Deferred        ole32<elf>
 \-PE  61460000-614f8000       \               ole32
ELF     614f8000-615f7000       Deferred        shell32<elf>
 \-PE  61510000-615f7000       \               shell32
ELF     615f7000-61655000       Deferred        shlwapi<elf>
 \-PE  61610000-61655000       \               shlwapi
ELF     61655000-6171a000       Deferred        comctl32<elf>
 \-PE  61660000-6171a000       \               comctl32
ELF     6171a000-61734000       Deferred        version<elf>
 \-PE  61720000-61734000       \               version
ELF     61734000-61748000       Deferred        lz32<elf>
 \-PE  61740000-61748000       \               lz32
ELF     61748000-6177c000       Deferred        uxtheme<elf>
 \-PE  61750000-6177c000       \               uxtheme
ELF     6188d000-61920000       Deferred        winmm<elf>
 \-PE  618a0000-61920000       \               winmm
ELF     61920000-6195d000       Deferred        wineoss<elf>
 \-PE  61930000-6195d000       \               wineoss
ELF     6195d000-61975000       Deferred        msacm32<elf>
 \-PE  61960000-61975000       \               msacm32
ELF     6199d000-619bd000       Deferred        mpr<elf>
 \-PE  619a0000-619bd000       \               mpr
ELF     619bd000-619eb000       Deferred        d3d9<elf>
 \-PE  619c0000-619eb000       \               d3d9
ELF     619eb000-61aaf000       Deferred        wined3d<elf>
 \-PE  61a00000-61aaf000       \               wined3d
ELF     61d37000-61d4b000       Deferred        winejoystick<elf>
 \-PE  61d40000-61d4b000       \               winejoystick
ELF     61e5c000-61e71000       Deferred        psapi<elf>
 \-PE  61e60000-61e71000       \               psapi
ELF     61e71000-61ea6000       Deferred        rsaenh<elf>
 \-PE  61e80000-61ea6000       \               rsaenh
ELF     61ea6000-61ee4000       Deferred        shdocvw<elf>
 \-PE  61eb0000-61ee4000       \               shdocvw
ELF     61ee4000-61f31000       Deferred        dsound<elf>
 \-PE  61ef0000-61f31000       \               dsound
ELF     62153000-6218c000       Deferred        urlmon<elf>
 \-PE  62160000-6218c000       \               urlmon
ELF     6218c000-6220c000       Deferred        mshtml<elf>
 \-PE  621a0000-6220c000       \               mshtml
ELF     6220c000-62276000       Deferred        msvcrt<elf>
 \-PE  62220000-62276000       \               msvcrt
ELF     62276000-622aa000       Deferred        winspool<elf>
 \-PE  62280000-622aa000       \               winspool
ELF     62852000-6289e000       Deferred        dbghelp<elf>
 \-PE  62860000-6289e000       \               dbghelp
PE      628c0000-628d9000       Deferred        parsifal
ELF     661de000-661fb000       Deferred        imm32<elf>
 \-PE  661f0000-661fb000       \               imm32
ELF     66a45000-66a9e000       Deferred        rpcrt4<elf>
 \-PE  66a50000-66a9e000       \               rpcrt4
ELF     691c1000-691d5000       Deferred        mswsock<elf>
 \-PE  691d0000-691d5000       \               mswsock
ELF     69e59000-69e87000       Deferred        ws2_32<elf>
 \-PE  69e60000-69e87000       \               ws2_32
ELF     6bf1e000-6bf70000       Deferred        crypt32<elf>
 \-PE  6bf30000-6bf70000       \               crypt32
ELF     6e2ae000-6e2f7000       Deferred        wininet<elf>
 \-PE  6e2c0000-6e2f7000       \               wininet
ELF     6fe0b000-6fead000       Deferred        comdlg32<elf>
 \-PE  6fe10000-6fead000       \               comdlg32
ELF     734f9000-7350e000       Deferred        midimap<elf>
 \-PE  73500000-7350e000       \               midimap
ELF     7372a000-737cf000       Deferred        oleaut32<elf>
 \-PE  73740000-737cf000       \               oleaut32
ELF     743cf000-743f7000       Deferred        msvfw32<elf>
 \-PE  743e0000-743f7000       \               msvfw32
ELF     74452000-7448f000       Deferred        avifil32<elf>
 \-PE  74460000-7448f000       \               avifil32
ELF     7b79e000-7b7a4000       Deferred        libnss_dns.so.2
ELF     7bf00000-7bf03000       Deferred        <wine-loader>
Threads:
process  tid      prio (all id:s are in hex)
00000052 (D) C:\Program Files\Steam\steamapps\derin_91\counter-strike source\hl2.exe
       0000002c   15
       00000040    0
       00000063    0
       00000062    0
       00000061    0
       0000005b    0
       0000005a   15
       00000058    0
       00000057    0
       00000055    0
       00000054    2
       00000053    0 <==
0000000a
       0000000c    0
       0000000b    0
00000008
       0000002e    1
       00000056    1
       00000051    0
       00000050    0
       0000003f    0
       0000003e    0
       0000003d    1
       0000003c    0
       0000003b    1
       0000003a    0
       00000039    1
       00000038    0
       00000037    1
       00000036    0
       00000035    1
       00000034    0
       00000033    1
       00000032    0
       00000031    1
       00000030    0
       0000002f    1
       0000002b    0
       00000028    0
       00000027    0
       00000026    0
       00000025    0
       00000024    0
       00000020    0
       0000001f    0
       0000001d    0
       0000001c    1
       0000001a    0
       00000019    0
       00000017    0
       00000016    0
       00000015    1
       00000014    0
       00000013    0
       00000012    0
       00000011    0
       00000010    0
       0000000f    0
       0000000e    0
       0000000d    0
       00000009    0
wine client error:53:
Dodatkowo gra bardzo często się p;rzycina i nie jest to spowodowane framerate...
EDIT:
Poprzez dodanie do komendy bootujacej linijlki: -dxlevel90 pozbyłem się problemów z Direct3D i niskim framerate, ale ciągle pozostaje problem z wodą i wine client error:44 i 53:
co powduje natychmiastowe wyłącznie się gry... pojawiają się zazwyczaj (do tej pory tylko 2 razy) przy większej akcji). Ktoś ma jakieś sugestie?
Sorry, że nie na temat, ale dopóki nie umieścisz co trzeba w codebox'ach to raczej nikt Ci nie pomoże, bo niby skąd ludzie mają widzieć co jest zrzutem z logów, a co Twoją wypowiedzią. Popraw to, bo mało czytelne. Pozdrawiam ([*codebox] [/*codebox])
No tym razem pojawil sie Wine error numer 45... Ktos wie co te bledy oznaczaja?
Mozna skads sciagnac "darmowa" cedege? Np. z emule? (wiadomo o co chodzi, ale nie chce warezowac ^^) wystarczy odpowiedz "tak" lub "nie" ^^
Zrobilem tak jak radzili mi koledzy z forum Ubuntu czyli pogrzebalem w Audio Wine, ale teraz to pojechalo po bandzie bo wywalilo mi blad 5d ....
Ehhh. Zaczynam miec tego powoli dosc, próbuje wszystkie ustawienia Wine, ale co najwyzej udalo mi sie opóznic wystapienie bledu do kilku minut... Co jest cholera nie tak?? Czemu u innych Source na Wine dziala dobrze, a ja mam problemy z jego konfiguracja? Dodatkowo wyczytalem, ze blad 44 i 45 to sa bledy sterownika dzwieku... Z nimi uporalem sie konfigurujac Wine, ale ciagle wyskakuja mi nowe bledy... Czemu ta cedega jest taka droga? Przeciez nie bede placil 5EUR miesiecznie po to, zeby pograc od czasu do czasu w jedna gre i to w dodatku najwyzej przez kilka miesiecy bo potem kupuje PS3... (akutalnie PSX i PSP ^^)
