Ana Napisano Kwiecień 28, 2007 Zgłoszenie Share Napisano Kwiecień 28, 2007 Mam fedorę 6, dukarkę - jw. Próbowałam uczciwie szukać rozwiązania na forach i zastosować się. Przed rokiem znalazłam tu ten temat, jest tam o pliku hp1020.img jw rozpakowanym katalogu foo2zjs. Ja też go nie mam. Czy ktoś może go przysłać i pomóc? Już instalowałam wg opisu na stronie http://foo2zjs.rkkda.com/ i nic.. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Kwiecień 28, 2007 Zgłoszenie Share Napisano Kwiecień 28, 2007 FedoraCore3(or later)/CentOS4(RHEL4?): ====================================== You need to use foo2zjs as mentioned above, however the firmware that foo2zjs current provides is old and has problems printing more than a few pages, and also with certain complex pages. The site mentioned above ( support.ideainformatica.com) no longer seems to offer the firmware, so what I did was to "borrow" it from windows: 1) Using a Windows system, download the driver from www.hp.com. 2) Install the driver. 3) In "C:\Program Files\Hewlett-Packard\LaserJet 1020-1022 Drivers\", copy the file hp1020.img. Now get into Linux as root, and do the following: 1. wget http://foo2zjs.rkkda.com/foo2zjs.tar.gz 2. tar xzvf foo2zjs.tar.gz 3. cd foo2zjs 4. make 5. (copy the hp1020.img into this folder as sihp1020.img) 6. make install 7. make install-hotplug Switch off-and-on the printer, you should see something like this in your /var/log/messages: kernel: usb 1-1: new high speed USB device using ehci_hcd and address 9 kernel: drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 9 if 0 alt 0 proto 2 vid 0x03F0 pid 0x2B17 /etc/hotplug/usb/hplj1020: loading HP LaserJet 1020 firmware /usr/share/foo2zjs/firmware/sihp1020.dl to /dev/usb/lp0 ... /etc/hotplug/usb/hplj1020: ... download successful. Then set up your printer queue by running system-config-printer-gui: 1. click New, and Forward. 2. Enter a name and description. 3. Queue-type: Locally Connected, /dev/usb/lp0 4. Choose HP LaserJet 1020 5. Finish, and print a test page! Zrodlo -> http://www.linuxprinting.org/show_printer....P-LaserJet_1020 Jak u Ciebie z angielskim? Sciagnij stery windowsowe, rozpakuj/zainstaluj, pozycz sobie (skopiuj) ze sterow windowsowych hp1020.img... Gdybys nadal miala problemy to pisz. Powodzenia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotreek23 Napisano Kwiecień 28, 2007 Zgłoszenie Share Napisano Kwiecień 28, 2007 A HPLIP ten co jest domyślnie Fedorce jej nie chwyci? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ana Napisano Kwiecień 29, 2007 Autor Zgłoszenie Share Napisano Kwiecień 29, 2007 Zrodlo -> http://www.linuxprinting.org/show_printer....P-LaserJet_1020 Jak u Ciebie z angielskim? Sciagnij stery windowsowe, rozpakuj/zainstaluj, pozycz sobie (skopiuj) ze sterow windowsowych hp1020.img... Gdybys nadal miala problemy to pisz. Powodzenia Wielkie dzięki, ale nie mam tu na razie Windowsa. Muszę zaczekać... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ana Napisano Kwiecień 30, 2007 Autor Zgłoszenie Share Napisano Kwiecień 30, 2007 Zrodlo -> http://www.linuxprinting.org/show_printer....P-LaserJet_1020 Jak u Ciebie z angielskim? Sciagnij stery windowsowe, rozpakuj/zainstaluj, pozycz sobie (skopiuj) ze sterow windowsowych hp1020.img... Gdybys nadal miala problemy to pisz. Powodzenia Nie do wiary!!! Drukarka działa! Baaardzo dziękuję. Zachęciłam się do forum, ale następne pytanie muszę chyba umieścić w innym dziale... Podrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ana Napisano Czerwiec 4, 2007 Autor Zgłoszenie Share Napisano Czerwiec 4, 2007 Zrodlo -> http://www.linuxprinting.org/show_printer....P-LaserJet_1020 Jak u Ciebie z angielskim? Sciagnij stery windowsowe, rozpakuj/zainstaluj, pozycz sobie (skopiuj) ze sterow windowsowych hp1020.img... Gdybys nadal miala problemy to pisz. Powodzenia Kontynuuję ten temat, bo chociaż rozwiązał się w fedorze 6, to teraz w fedorze 7 mam powtórkę z tą drukarką. Postępowałam według wskazówek i niestety w var/log/messages nie pojawił się oczekiwany wpis, ale jak poniżej i jeszcze więcej. W każdym razie drukarka znów nie działa. Proszę o pomoc. Jun 4 22:21:24 localhost setroubleshoot: SELinux is preventing hplj1020 (udev_t) "getattr" to /usr/share/foo2zjs/firmware/sihp1020.dl (usr_t). For complete SELinux messages. run sealert -l 1bddc5d7-748d-4d60-a394-77b5137292ad Jun 4 22:21:37 localhost kernel: usb 2-4: USB disconnect, address 5 Jun 4 22:21:37 localhost kernel: drivers/usb/class/usblp.c: usblp0: removed Jun 4 22:21:39 localhost kernel: usb 2-4: new high speed USB device using ehci_hcd and address 6 Jun 4 22:21:39 localhost kernel: usb 2-4: configuration #1 chosen from 1 choice Jun 4 22:21:39 localhost kernel: drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 6 if 0 alt 0 proto 2 vid 0x03F0 pid 0x2B17 Jun 4 22:21:39 localhost udevd-event[3569]: udev_rules_apply_format: unknown format char 'e' Jun 4 22:21:39 localhost /etc/hotplug/usb/hplj1020: foo2zjs: Missing HP LaserJet 1020 firmware file /usr/share/foo2zjs/firmware/sihp1020.dl Jun 4 22:21:39 localhost /etc/hotplug/usb/hplj1020: foo2zjs: ...read foo2zjs installation instructions and run ./getweb 1020 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ana Napisano Czerwiec 5, 2007 Autor Zgłoszenie Share Napisano Czerwiec 5, 2007 Ośmielam się jeszcze raz wzywać pomocy, by zrozumieć treść messages: Jun 5 11:17:36 localhost kernel: usb 2-4: USB disconnect, address 8 Jun 5 11:17:36 localhost kernel: drivers/usb/class/usblp.c: usblp0: removed Jun 5 11:17:38 localhost kernel: usb 2-4: new high speed USB device using ehci_hcd and address 9 Jun 5 11:17:38 localhost kernel: usb 2-4: configuration #1 chosen from 1 choice Jun 5 11:17:38 localhost kernel: drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 9 if 0 alt 0 proto 2 vid 0x03F0 pid 0x2B17 Jun 5 11:17:38 localhost udevd-event[4566]: udev_rules_apply_format: unknown format char 'e' Jun 5 11:17:38 localhost /etc/hotplug/usb/hplj1020: foo2zjs: Missing HP LaserJet 1020 firmware file /usr/share/foo2zjs/firmware/sihp1020.dl Jun 5 11:17:38 localhost /etc/hotplug/usb/hplj1020: foo2zjs: ...read foo2zjs installation instructions and run ./getweb 1020 Jun 5 11:17:38 localhost udevd-event[4566]: udev_rules_apply_format: unknown format char 'e' Jun 5 11:17:42 localhost setroubleshoot: SELinux is preventing hplj1020 (udev_t) "getattr" to /usr/share/foo2zjs/firmware/sihp1020.dl (usr_t). For complete SELinux messages. run sealert -l 1bddc5d7-748d-4d60-a394-77b5137292ad Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
jjj Napisano Czerwiec 5, 2007 Zgłoszenie Share Napisano Czerwiec 5, 2007 z szybkiego oglądu wynika, że selinux blokuje. Dla testów możesz wgo wyłączyć: w /etc/selinux/config zastąpić enforcing przez permissive, przeładować i zobaczyć czy problem minął. Jak minął, to trzeba włączyć selinux z powrotem i nadać odpowiedni selinuksowy kontekst bezpieczeństwa plikowi sterownika. Zobacz czy w poczcie dla roota nie ma obszerniejszej diagnostyki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ana Napisano Czerwiec 5, 2007 Autor Zgłoszenie Share Napisano Czerwiec 5, 2007 z szybkiego oglądu wynika, że selinux blokuje. Dla testów możesz wgo wyłączyć: w /etc/selinux/config zastąpić enforcing przez permissive, przeładować i zobaczyć czy problem minął. Jak minął, to trzeba włączyć selinux z powrotem i nadać odpowiedni selinuksowy kontekst bezpieczeństwa plikowi sterownika. Zobacz czy w poczcie dla roota nie ma obszerniejszej diagnostyki. Dziękuję bardzo. W trybie SElinuxa permissive pojawił się pomyślny (myślę) komunikat: Jun 5 18:15:43 localhost kernel: usb 2-4: USB disconnect, address 6 Jun 5 18:15:43 localhost kernel: drivers/usb/class/usblp.c: usblp0: removed Jun 5 18:15:49 localhost kernel: usb 2-4: new high speed USB device using ehci_hcd and address 7 Jun 5 18:15:49 localhost kernel: usb 2-4: configuration #1 chosen from 1 choice Jun 5 18:15:49 localhost kernel: drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 7 if 0 alt 0 proto 2 vid 0x03F0 pid 0x2B17 Jun 5 18:15:49 localhost udevd-event[5242]: udev_rules_apply_format: unknown format char 'e' Jun 5 18:15:49 localhost /etc/hotplug/usb/hplj1020: foo2zjs: loading HP LaserJet 1020 firmware /usr/share/foo2zjs/firmware/sihp1020.dl to /dev/usb/lp0 ... Jun 5 18:15:49 localhost /etc/hotplug/usb/hplj1020: foo2zjs: ... download successful. Jednakże drukarka nadal nie drukuje ... Niestety nie bardzo też wiem, gdzie szukać poczty dla roota ?! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dzikiws Napisano Czerwiec 5, 2007 Zgłoszenie Share Napisano Czerwiec 5, 2007 Jestem na F7 i386 - mam drukarkę HP1020 - błąd w działaniu drukarki jest spowodowany automatycznym wpisem w Centrum Sterowania - należy go usunąć - stworzyć nową konfigurację w centrum sterowania - urządzenia peryferyjne - drukarki - przejść całą konfigurację. Ale najpierw należy : 1. ściągnąć plik foo2zjs - rozpakować - oraz make i make install. 2. umieścić skrypt wywołujący i wgrywający do ramu bios drukarki np. w kat. "opt" 2. skopiować do katalogu /usr/lib/ katalog "hp" w którym znajduje się firmware drukarki - hp1020.img następnie restart linuksa - drukarka działa bezbłędnie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Laikusss Napisano Lipiec 7, 2007 Zgłoszenie Share Napisano Lipiec 7, 2007 Tak, ale czy po restarcie drukarki - drukarka dalej bedzie działała? Mam tą samą drukarkę i tak własnie się zachowuje. Po wyłączeniu drukarki przestaje działać. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dzikiws Napisano Lipiec 8, 2007 Zgłoszenie Share Napisano Lipiec 8, 2007 Zasadą uruchomienia drukarki HP1020 na linuksie jest przed drukowaniem uruchomienie przy włączonej drukarce skryptu uruchomienia firmware drukarki - efekt - migają diody drukarki kilka sekund, miganie diod ustaje i drukarka jest gotowa do działania. Na linuksie trzeba tak robić przed każdym (nowym po włączeniu drukarki) drukowaniem, w windzie plik z firmware drukarki uruchamia się automatycznie po włączeniu drukarki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SNIPER.PL Napisano Grudzień 4, 2008 Zgłoszenie Share Napisano Grudzień 4, 2008 z szybkiego oglądu wynika, że selinux blokuje. Dla testów możesz wgo wyłączyć: w /etc/selinux/config zastąpić enforcing przez permissive, przeładować i zobaczyć czy problem minął. Jak minął, to trzeba włączyć selinux z powrotem i nadać odpowiedni selinuksowy kontekst bezpieczeństwa plikowi sterownika. Zobacz czy w poczcie dla roota nie ma obszerniejszej diagnostyki. Mam również problem z drukarką, SElinux blokuje. Jak dodać do niego opcję, by drukarkę zostawił w spokoju? Zazwyczaj na chwilę wyłączam SElinux do drukowania, ale to trochę kłopotliwe. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Grudzień 4, 2008 Zgłoszenie Share Napisano Grudzień 4, 2008 (...) SElinux blokuje.I nie pisze co mu przeszkadza? Żadnych komunikatów, "gwiazdy szeryfa" na pasku zadań? Nic? Skąd wiesz, że to SElinux? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SNIPER.PL Napisano Grudzień 4, 2008 Zgłoszenie Share Napisano Grudzień 4, 2008 Była, była, mój błąd - nie dołączyłem. Podsumowanie: SELinux powstrzymuje hp (hplip_t) "search" do ./dbus (system_dbusd_var_run_t). Szczegółowy opis: SELinux odmówił hp żądania dostępu. Ten dostęp nie jest konieczny dla hp i może sygnalizować próbę włamania. Jest także możliwe, że określona wersja lub konfiguracja aplikacji powoduje, że wymaga ona tego dostępu. Zezwalanie na dostęp: Problemy z nadawaniem etykiet mogą czasem powodować odmowy SELinuksa. Możesz spróbować przywrócić domyślny kontekst plikom systemowym dla ./dbus, restorecon -v "./dbus" Jeśli nie działa, obecnie nie ma automatycznego sposobu na pozwolenie na ten dostęp. Zamiast tego możesz utworzyć lokalny moduł polityki, aby pozwolić na ten dostęp - zobacz FAQ (http://fedora.redhat.com/docs/selinux-faq-fc5/#id2961385) Możesz też wyłączyć ochronę SELinuksa. Wyłączenie jej nie jest zalecane. Zgłoś raport błędu (http://bugzilla.redhat.com/bugzilla/enter_bug.cgi) o tym pakiecie. Dodatkowe informacje: Kontekst źródłowy system_u:system_r:hplip_t:s0-s0:c0.c1023 Kontekst docelowy system_u:object_r:system_dbusd_var_run_t:s0 Obiekty docelowe ./dbus [ dir ] Źródło hp Ścieżka źródłowa /usr/lib/cups/backend/hp Port <Nieznane> Komputer localhost.localdomain Źródłowe pakiety RPM hplip-2.8.2-2.fc9 Docelowe pakiety RPM RPM polityki selinux-policy-3.3.1-111.fc9 SELinux jest włączony True Typ polityki targeted MLS jest włączone True Tryb wymuszania Enforcing Nazwa wtyczki catchall_file Nazwa komputera localhost.localdomain Platforma Linux localhost.localdomain 2.6.27.5-41.fc9.i686 #1 SMP Thu Nov 13 20:52:14 EST 2008 i686 i686 Licznik alarmów 50 Po raz pierwszy wto, 9 wrz 2008, 21:24:03 Po raz ostatni czw, 4 gru 2008, 18:35:08 Lokalny identyfikator 7c7de211-f0f7-4fd0-aefc-51cf7799b9e8 Liczba wierszy Surowe komunikaty audytu node=localhost.localdomain type=AVC msg=audit(1228412108.656:18): avc: denied { search } for pid=4155 comm="hp" name="dbus" dev=sda3 ino=311425 scontext=system_u:system_r:hplip_t:s0-s0:c0.c1023 tcontext=system_u:object_r:system_dbusd_var_run_t:s0 tclass=dir node=localhost.localdomain type=SYSCALL msg=audit(1228412108.656:18): arch=40000003 syscall=102 success=no exit=-13 a0=3 a1=bfba7aa0 a2=2adff4 a3=1f items=0 ppid=2426 pid=4155 auid=4294967295 uid=4 gid=7 euid=4 suid=4 fsuid=4 egid=7 sgid=7 fsgid=7 tty=(none) ses=4294967295 comm="hp" exe="/usr/lib/cups/backend/hp" subj=system_u:system_r:hplip_t:s0-s0:c0.c1023 key=(null) Od razu zaznaczam, że patrzyłem tę stronę Fedory, ale nie wiem dokładnie jak to zrobić, a wolę sam nie ryzykować. Do tej pory zawsze wyłączałem SElinuxa na czas drukowania, ale w końcu chcę to jakoś lepiej rozwiązać. Ta komenda: restorecon -v "./dbus" nie działa. Próbowałem i z rootem i bez. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
