Fc8 Problem Z Necikiem
slackmaster
Witam moj problem jest nastepujący mam karte radiowa pod pci do internetu(atheros) fedpra automatycznie ja wykwrywa gdy wpise swoje ip bramy maski itp to podczas restartu system staje i pise:
podnoszenie interfejsu wlan0: SIOCSIFLAGS operation not suportet
./ifup wireless: line 60: 1683 naruszenie ochrony pamięci iwconfig $DEVICE channel $CHANNEL
prosze o pomoc
zgóry dziuekuje za wszelkie podpowiedzi
prosze lspci.
[root@dhcppc2 HANS]# /sbin/lspci
00:00.0 Host bridge: ATI Technologies Inc Unknown device 5a31 (rev 01)
00:01.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
00:04.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
00:05.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
00:06.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
00:07.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA
00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0)
00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1)
00:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2)
00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3)
00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4)
00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI)
00:14.0 SMBus: ATI Technologies Inc SB600 SMBus (rev 13)
00:14.1 IDE interface: ATI Technologies Inc SB600 IDE
00:14.2 Audio device: ATI Technologies Inc SB600 Azalia
00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
00:14.4 PCI bridge: ATI Technologies Inc SB600 PCI to PCI Bridge
01:05.0 VGA compatible controller: ATI Technologies Inc RC410 [Radeon Xpress 200M]
02:00.0 Ethernet controller: Atheros Communications, Inc. AR5006EG 802.11 b/g Wireless PCI Express Adapter (rev 01)
08:01.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev b3)
08:01.1 Generic system peripheral [0805]: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 17)
08:01.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 08)
08:07.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
jak ktoś może mi pomóc co zrobić to będę wdzięczny a siostra chyba jeszcze bardziej (od kogoś kabel musiałem zabrać do neta :P)
Umnie problem okazał się dość złożony, ale po miesiącu (!) walki odpaliłem Atherosa.
U mnie działa pod madwifi, ale okazało się, że jest haczyk.
Najpierw spróbuj tu:
http://madwifi.org/ticket/1679
Być może masz kartę 5007EG która przez (_linuxa_ → Linuksa) ORT jest rozpoznawana niestety jako 5006EG (ile zdrowia kosztował mnie ten błąd w rozpoznaniu!).
ndiswrapper u mnie nie zadziałał.
I jeszcze jedno. Musisz robić krok po kroku i b. dokładnie tak jak w opisie. U mnie zadziałało po 3 chyba razie. Teraz działa bez problemów. Do wykrywania i logowania używam
Wireless Assistant.
Tylko z tym karta mi odpala.
