warlock85 Napisano Luty 29, 2008 Zgłoszenie Share Napisano Luty 29, 2008 czesc mam problem z kompilacja amule-cvs moglby ktos rzucic okiem z gory dzieki. pozdrawiam. [root@localhost amule-cvs]# ./configure --enable-kad-compile checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether to enable maintainer-specific portions of Makefiles... no checking for g++... g++ checking for C++ compiler default output file name... a.out checking whether the C++ compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking for style of include used by make... GNU checking dependency style of g++... gcc3 checking how to run the C++ preprocessor... g++ -E checking for gcc... gcc checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking dependency style of gcc... gcc3 checking how to run the C preprocessor... gcc -E checking for gawk... (cached) gawk checking for egrep... grep -E checking whether make sets $(MAKE)... (cached) yes checking for flex... flex checking for yywrap in -lfl... yes checking lex output file root... lex.yy checking whether yytext is a pointer... yes checking for a BSD-compatible install... /usr/bin/install -c checking for ranlib... ranlib checking for bison... bison -y checking for ranlib... (cached) ranlib checking for strip... strip checking for ar... ar checking for ld... ld checking for zlib >= 1.1.4... yes (version 1.2.3) checking for File::Copy... ok checking whether we need the GUI... no checking for exception-handling... yes checking for the --with-toolkit option... will be automatically detected checking for the --with-wxshared option... will be automatically detected checking for the --with-wxdebug option... will be automatically detected checking for the --with-wxversion option... will be automatically detected checking for wx-config... /usr/bin/wx-config checking for wxWidgets version >= 2.8.0 (--unicode=yes)... yes (version 2.8.4) checking for wxWidgets static library... no checking if wxWidgets was built in DEBUG mode... no checking if wxWidgets was built in STATIC mode... no checking which wxWidgets toolkit was selected... gtk2 checking that wxWidgets has support for large files... yes checking for crypto++ version >= 5.1... configure: error: Could not find cryptopp header file "cryptlib.h". Please check if the path "/usr" is valid. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Luty 29, 2008 Zgłoszenie Share Napisano Luty 29, 2008 Czytanie ze zrozumieniem nie boli checking for crypto++ version >= 5.1... configure: error: Could not find cryptopp header file "cryptlib.h". Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Marzec 1, 2008 Zgłoszenie Share Napisano Marzec 1, 2008 A oprócz tego: -nie kompiluje się softu na roocie -gotową paczkę z amule masz w repo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
warlock85 Napisano Marzec 1, 2008 Autor Zgłoszenie Share Napisano Marzec 1, 2008 czytac na szczescie potrafie, problem raczej mam z kompilacja tego. w repo mam amula mam go zainstalowanego problem polega na tym ze nie obsluguje plikow powyzej 4gb, wyczytalem ze podobno ten cvs sobie z tym radzi. jak ktos cos wie to prosze o odpowiedz. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Marzec 1, 2008 Zgłoszenie Share Napisano Marzec 1, 2008 jak ktos cos wie to prosze o odpowiedz.Luzik, wiem co mowię, bo mnie też czasem nosi Stronka w nieczytelnym dla mnie języku, ale polecenia dość oczywiste → http://piuemeno.wordpress.com/2007/12/16/c...mule-su-fedora/ [EDIT]Stronka chyba na temat, bo się wpis pojawia tar xvjf aMule-CVS-20080224.tar.bz2 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
warlock85 Napisano Marzec 1, 2008 Autor Zgłoszenie Share Napisano Marzec 1, 2008 Luzik, wiem co mowię, bo mnie też czasem nosi Stronka w nieczytelnym dla mnie języku, ale polecenia dość oczywiste → http://piuemeno.wordpress.com/2007/12/16/c...mule-su-fedora/ [EDIT]Stronka chyba na temat, bo się wpis pojawia Przemielilo sie i dziala! ogarnia pliki powyzej 4gb. mozna to jakos przerobic i zrobic fajne howto z tego (_napewno_ → na pewno) ORT sie komus przyda. wielki dzieki za pomoc, sam bym nie dal rady. dzieki dzieki i pozdrowki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Marzec 1, 2008 Zgłoszenie Share Napisano Marzec 1, 2008 mozna to jakos przerobic i zrobic fajne howto z tegoPewnie się przyda Jakbyś miał chwilkę wolnego czasu, to może zrób podsumowanie. Pewnie kolejne wersje z CVS będa miały pdobne wymagania. jak będzie coś spójnie opisane to można podpiąć na forum. Pozdrawiam. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
