Kde + Compiz = Restart X'ów
gasnic
Witam.
Mój problem wygląda następująco, korzystając ze środowiska KDE i przy włączonym Compizie kde-window-decorator zgłaszał mi nie jednokrotnie błąd:
Getting all the debuginfos: debuginfo-install compiz-kde
(no debugging symbols found)
Using host libthread_db library "/lib/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread -1209088304 (LWP 2943)]
[KCrash handler]
#6  0x03411970 in QWidget::~QWidget$base ()
  from /usr/lib/qt-3.3/lib/libqt-mt.so.3
#7  0x03477c74 in QButton::~QButton$base ()
#8  0x0011b7d1 in KCommonDecorationButton::~KCommonDecorationButton$base ()
  from /usr/lib/libkdecorations.so.1
#9  0x00334ca5 in KWinPlastik::PlastikButton::~PlastikButton$delete ()
  from /usr/lib/kde3/kwin3_plastik.so
#10 0x0011e414 in KCommonDecoration::~KCommonDecoration$base ()
#11 0x00338048 in KWinPlastik::PlastikClient::~PlastikClient$delete ()
#12 0x0805b384 in ?? ()
#13 0x08052de9 in ?? ()
#14 0x080509e6 in QWidget::setUpdatesEnabled ()
#15 0x033d2cea in QObject::activate_signal ()
#16 0x00487521 in KWinModule::windowRemoved () from /usr/lib/libkdecore.so.4
#17 0x0048c957 in KWinModulePrivate::removeClient ()
#18 0x0047a726 in NETRootInfo::update () from /usr/lib/libkdecore.so.4
#19 0x0047aa95 in NETRootInfo::event () from /usr/lib/libkdecore.so.4
#20 0x0048da44 in KWinModulePrivate::x11Event () from /usr/lib/libkdecore.so.4
#21 0x005547d3 in KApplication::x11EventFilter ()
#22 0x080533fd in ?? ()
#23 0x032ed294 in ?? () from /usr/lib/qt-3.3/lib/libqt-mt.so.3
#24 0x032fe963 in QApplication::x11ProcessEvent ()
#25 0x03310e1b in QEventLoop::processEvents ()
#26 0x03382dc0 in QEventLoop::enterLoop ()
#27 0x03382c76 in QEventLoop::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3
#28 0x0336912f in QApplication::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3
#29 0x080518ff in ?? ()
#30 0x00632390 in __libc_start_main () from /lib/libc.so.6
#31 0x080505f1 in QWidget::setUpdatesEnabled ()
Ponadto nie rzadko podczas włączania nowych okienek zwyczajnie restartował X server. Naprawdę nie wiem co jest grane próbowałem już przeinstalowywać sterowniki do NVIDII i compiz-kde
nic nie pomogło. Samo KDE oczywiście działa bez zarzutów, problem występuje jedynie korzystając z Compiza na KDE, bo na GNOME działa on dobrze.
Mój xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder3)  Thu Dec 13 19:09:35 PST 2007
# Xorg configuration created by livna-config-display
Section "ServerLayout"
   Identifier     "single head configuration"
   Screen      0  "Screen0" 0 0
   InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
   ModulePath      "/usr/lib/xorg/modules"
EndSection
Section "Module"
   Load     "i2c"
   Load     "bitmap"
   Load         "glx"
   Load     "type1"
   Load     "vbe"
   Load         "extmod"
EndSection
Section "ServerFlags"
   Option         "AIGLX" "on"
EndSection
Section "InputDevice"
   # generated from default
   Identifier     "Mouse0"
   Driver         "mouse"
   Option         "Protocol" "auto"
   Option         "Device" "/dev/input/mice"
   Option         "Emulate3Buttons" "no"
   Option         "ZAxisMapping" "4 5"
EndSection
   Identifier     "Keyboard0"
   Driver         "kbd"
   Option         "XkbModel" "pc105"
   Option         "XkbLayout" "pl"
   Option         "XkbOptions" "altwin:super_win"
EndSection
Section "Monitor"
   Identifier     "Monitor0"
   VendorName     "Unknown"
   ModelName      "Unknown"
   HorizSync       30.0 - 110.0
   VertRefresh     50.0 - 150.0
   Option         "DPMS"
EndSection
Section "Device"
   Identifier     "Videocard0"
   Driver         "nvidia"
EndSection
Section "Screen"
   Identifier     "Screen0"
   Device         "Videocard0"
   Monitor        "Monitor0"
   DefaultDepth    24
   Option         "RenderAccel" "True"
   Option         "AddARGBGLXVisuals" "True"
   SubSection     "Display"
       Viewport    0 0
       Depth       24
       Modes      "1280x1024" "1280x960" "1280x800" "1280x720" "1152x864" "1024x768" "800x600" "640x480"
   EndSubSection
Option         "AddARGBGLXVisuals" "true"
Option         "DisableGLXRootClipping" "true"
EndSection
Section "Extensions"
   Option         "Composite" "Enable"
EndSection
NVIDIA Driver: 169.07
Kernel: 2.6.23.15-137.fc8
Miał ktoś może podobny problem??
Z góry dziękuje za pomoc:)
Edytowane przez InIrudeBwoy
Wstawiłem tekst w znaczniki CodeBox, przy większej ilości linijek staraj się ich używać.
Sterowniki instalowałem ze strony NVIDII.
No i tu masz odpowiedź na swoje pytanie :-)
Zanim się zabrałeś ochoczo za instalowanie sterów nvidii z ich strony, trzeba było sobie poczytać np http://faq.fedora.pl , http://www.mjmwired.net/resources/mjm-fedora-f8.html , http://fedoraproject.org/wiki/FAQ bądź choćby to forum.
Spróbuj zmienić sekcję "files" tak aby wyglądała tak:
Section "Files"
    ModulePath   "/usr/lib/xorg/modules/extensions/nvidia"
EndSection
Dodam jeszcze że na F8 problemy miałem ze sterownikami instalowanymi z livny właśnie, natomist te z e strony nvidii od paru miesięcy działają bez zarzutu (mam Gforce 2, więc sterowniki 96xx).
Usunąłem sterowniki i zainstalowałem wg. opisu, problem nadal występuje;/ Próbowałem nawet na nowszym kernelu (2.6.24.3-12) to samo. Dodanie wpisu w sekcji "files" tez nie pomogło. Przy sterownikach "ze strony NVIDII" katalog "/usr/lib/xorg/modules/extensions/nvidia" u mnie nie istniał. Dodałem wpis "/usr/lib/xorg/modules/extensions" i tez nic. Teraz jade na sterownikach z repozytorium livny.
Ogólnie walczę już z tym drugi dzień i czuje się trochę zrezygnowany :(
Ma ktoś jeszcze jakieś pomysły??
Ogólnie rzecz biorąc instalując sterowniki ze strony nvidii zrobiłeś sobie spory burdel, ażeby który usunąć trzeba się trochę namęczyć. Takie uroki kombinowania na własną rękę ;) Zostalo podmienionych kilka plików ważnych systemowych z xorg/mesa (niepamiętam już dokładnie których). Jeśli ni boisz się trochę podziałać w trybie tekstowym i masz dostęp do neta na fedorce, to polecam co następuje:
1. Przechodzimy do trybu tekstowego (z roota)
init 3
2. Wyszukujemy i usuwamy wszystkie pakiety mesy [ niestet trzeba je usunąć metodą "brute-force" ;) ]
rpm -qa |grep -i mesa
rpm -e --nodeps pakiet1 pakiet2 ...
gdzie zamiast "pakiet1 pakiet2" wpisujesz nazwy wszystkich paczek które wcześniej Ci wyświetliło polecenie rpm -qa |grep mesa
3. Wyszukujemy i usuwamy wszystkie pakiety xorg-*
rpm -qa |grep xorg
Jak w p-kcie 2
4. Usuwamy wszystkie paczki z nvidią
rpm -qa |grep nvidia
5. Usuwamy wszelkie pozostałości po plikach nvidii. Nie wpamiętam gdzie zostają one dokładnie, ale polecam poszukać m.in. w następujących katalogach (jeśli ktoś ma dokładniejsze info to dajcie znać):
/usr/lib/nvidia
/usr/lib/xorg
Na chwilę obecną możesz te katalogi usunąć
rm -rf /usr/lib/nvidia /usr/lib/xorg
Teraz mając czysty system bez śmieci z nvidii możesz ponownie zainstalować xorg-* mesa i nvidię z livny
yum install xorg-\* mesa-\* kmod-nvidia --enablerepo=livna
Zamiast xorg-\* i mesa-\* możesz wpisać te nazwy paczek, które ostatnio usunąłeś. Oczywiście bez numerków itd, same nazwy. Chyba że nie przeszkadza Ci parę pakietów w systemie więcej, to możesz zostawić komendę tak jak jest.
Jak już yum ściągnie i poinstaluje wszystkie paczki, możesz przejść z powrotem do trybu graficznego
init 5
I to by było na tyle. Sprawdź też czy w pliku /etc/X11/xorg.conf masz następujące wpisy:
Section "Files"
EndSection
Section "Module"
        Load  "glx"
        Load  "dbe"
        Load  "extmod"
EndSection
        Option      "AIGLX" "on"
EndSection
Section "Device"
        Driver      "nvidia"
EndSection
EndSection
Oczywiście gwarancji nie daję że wszystko po tym będzie pięknie śmigać, ale żeby doprowadzić system do porządku to wywalenie całego xorg/mesa/nvidia jest chyba jednym z lątwiejszych sposobów
Witam ponownie.
Adi1981 wielkie dzięki za opis. Usunąłem wszystkie pakiety mesa/nvidia/xorg i zainstalowałem ponownie. Xorg.conf też skonfigurowałem ale to nie rozwiązało problemu. Compiz nadal wywołuje ten sam problem. Restartuje X'y w czasie pracy bez powodu :blink:
Witam ponownie.
Masz starą wersje compiza, najnowsza to 0.7.3 możesz ją zainstalować z repo fusion:
[fusion]
name=Compiz Fusion repository
mirrorlist=http://www.dfm.uninsubria.it/compiz/mirror-f$releasever-$basearch
baseurl=http://www.dfm.uninsubria.it/compiz/fusion/$basearch/ http://www.lordmorgul.net/pub/compiz/fusion/$basearch/
enabled=1
gpgcheck=0
Odinstaluj compiza z F8 a potem zainstaluj z tego repo. Działa zdecydowanie lepiej i masz więcej bajerów :D
Usunąłem starego Compiza i pliki konfiguracyjne z /home. Zainstalowałem nowszą wersje z repozytorium Compiza. Próbowałem również wyłączać efekty i zmieniać dekoracje okna z centrum sterowania KDE. Problem nadal ten sam. Nawet po wyłączeniu wtyczki window decorator w compizie było to samo.
/var/log/Xorg.0.log
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Fedora 8 Red Hat, Inc.
Current Operating System: Linux host-87-99-5-145.lanet.net.pl 2.6.24.3-12.fc8 #1 SMP Tue Feb 26 14:58:29 EST 2008 i686
Build Date: 12 February 2008
Build ID: xorg-x11-server 1.3.0.0-42.fc8
	Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar  8 19:26:42 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "single head configuration"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Videocard0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(==) FontPath set to:
	catalogue:/etc/X11/fontpath.d,
	built-ins
(==) RgbPath set to "/usr/share/X11/rgb"
(**) ModulePath set to "/usr/lib/xorg/modules/extensions/nvidia,/usr/lib/xorg/modules"
(**) Option "AIGLX" "on"
(**) Extension "Composite" is enabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x820cce0
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.3
	X.Org Video Driver: 1.2
	X.Org XInput driver : 0.7
	X.Org Server Extension : 0.3
	X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
	compiled for 1.3.0, module version = 1.0.0
	ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10de,0369 card 1043,8239 rev a1 class 05,00,00 hdr 00
(II) PCI: 00:01:0: chip 10de,0360 card 1043,8239 rev a2 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,0368 card 1043,8239 rev a2 class 0c,05,00 hdr 80
(II) PCI: 00:01:2: chip 10de,036a card 1043,8239 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:02:0: chip 10de,036c card 1043,8239 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,036d card 1043,8239 rev a2 class 0c,03,20 hdr 80
(II) PCI: 00:04:0: chip 10de,036e card f043,8239 rev a1 class 01,01,8a hdr 00
(II) PCI: 00:05:0: chip 10de,037f card 1043,8239 rev a2 class 01,01,85 hdr 80
(II) PCI: 00:05:1: chip 10de,037f card 1043,8239 rev a2 class 01,01,85 hdr 80
(II) PCI: 00:05:2: chip 10de,037f card 1043,8239 rev a2 class 01,01,85 hdr 80
(II) PCI: 00:06:0: chip 10de,0370 card 0000,0000 rev a2 class 06,04,01 hdr 81
(II) PCI: 00:06:1: chip 10de,0371 card 1043,81f6 rev a2 class 04,03,00 hdr 80
(II) PCI: 00:09:0: chip 10de,0373 card 1043,8239 rev a2 class 06,80,00 hdr 00
(II) PCI: 00:0f:0: chip 10de,0377 card 0000,0000 rev a2 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:0b:0: chip 104c,8023 card 1043,808b rev 00 class 0c,00,10 hdr 00
(II) PCI: 02:00:0: chip 10de,0292 card 0000,0321 rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:6:0), (0,1,1), BCTRL: 0x0a04 (VGA_EN is cleared)
(II) Bus 1 non-prefetchable memory range:
	[0] -1  0	   0xfde00000 - 0xfdefffff (0x100000) MX[b]
(II) PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:15:0), (0,2,2), BCTRL: 0x001c (VGA_EN is set)
(II) Bus 2 I/O range:
	[0] -1  0	   0x0000a000 - 0x0000a0ff (0x100) IX[b]
	[1] -1  0	   0x0000a400 - 0x0000a4ff (0x100) IX[b]
	[2] -1  0	   0x0000a800 - 0x0000a8ff (0x100) IX[b]
	[3] -1  0	   0x0000ac00 - 0x0000acff (0x100) IX[b]
(II) Bus 2 non-prefetchable memory range:
	[0] -1  0	   0xfa000000 - 0xfcffffff (0x3000000) MX[b]
(II) Bus 2 prefetchable memory range:
	[0] -1  0	   0xe0000000 - 0xefffffff (0x10000000) MX[b]
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:24:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1  0	   0x00000000 - 0x0000ffff (0x10000) IX[b]
(II) Bus 0 non-prefetchable memory range:
	[0] -1  0	   0x00000000 - 0xffffffff (0x0) MX[b]
(II) Bus 0 prefetchable memory range:
(--) PCI:*(2:0:0) nVidia Corporation GeForce 7900 GS rev 161, Mem @ 0xfa000000/24, 0xe0000000/28, 0xfb000000/24, I/O @ 0xac00/7, BIOS @ 0xfcfe0000/17
(II) Addressable bus resource ranges are
	[1] -1  0	   0x00000000 - 0x0000ffff (0x10000) IX[b]
(II) OS-reported resource ranges:
	[0] -1  0	   0x00100000 - 0x3fffffff (0x3ff00000) MX[b]E(
	[1] -1  0	   0x000f0000 - 0x000fffff (0x10000) MX[b]
	[2] -1  0	   0x000c0000 - 0x000effff (0x30000) MX[b]
	[3] -1  0	   0x00000000 - 0x0009ffff (0xa0000) MX[b]
	[4] -1  0	   0x0000ffff - 0x0000ffff (0x1) IX[b]
	[5] -1  0	   0x00000000 - 0x000000ff (0x100) IX[b]
(II) Active PCI resource ranges:
	[0] -1  0	   0xfdef8000 - 0xfdefbfff (0x4000) MX[b]
	[1] -1  0	   0xfdeff000 - 0xfdeff7ff (0x800) MX[b]
	[2] -1  0	   0xfe028000 - 0xfe02800f (0x10) MX[b]
	[3] -1  0	   0xfe029000 - 0xfe0290ff (0x100) MX[b]
	[4] -1  0	   0xfe02a000 - 0xfe02afff (0x1000) MX[b]
	[5] -1  0	   0xfe024000 - 0xfe027fff (0x4000) MX[b]
	[6] -1  0	   0xfe02b000 - 0xfe02bfff (0x1000) MX[b]
	[7] -1  0	   0xfe02c000 - 0xfe02cfff (0x1000) MX[b]
	[8] -1  0	   0xfe02d000 - 0xfe02dfff (0x1000) MX[b]
	[9] -1  0	   0xfe02e000 - 0xfe02e0ff (0x100) MX[b]
	[10] -1 0	   0xfe02f000 - 0xfe02ffff (0x1000) MX[b]
	[11] -1 0	   0xfcfe0000 - 0xfcffffff (0x20000) MX[b](
	[12] -1 0	   0xfb000000 - 0xfbffffff (0x1000000) MX[b](
	[13] -1 0	   0xe0000000 - 0xefffffff (0x10000000) MX[b](
	[14] -1 0	   0xfa000000 - 0xfaffffff (0x1000000) MX[b](
	[15] -1 0	   0x0000b000 - 0x0000b007 (0x8) IX[b]
	[16] -1 0	   0x0000b400 - 0x0000b40f (0x10) IX[b]
	[17] -1 0	   0x0000b800 - 0x0000b803 (0x4) IX[b]
	[18] -1 0	   0x0000bc00 - 0x0000bc07 (0x8) IX[b]
	[19] -1 0	   0x0000c000 - 0x0000c003 (0x4) IX[b]
	[20] -1 0	   0x0000c400 - 0x0000c407 (0x8) IX[b]
	[21] -1 0	   0x0000c800 - 0x0000c80f (0x10) IX[b]
	[22] -1 0	   0x00000b60 - 0x00000b63 (0x4) IX[b]
	[23] -1 0	   0x00000960 - 0x00000967 (0x8) IX[b]
	[24] -1 0	   0x00000be0 - 0x00000be3 (0x4) IX[b]
	[25] -1 0	   0x000009e0 - 0x000009e7 (0x8) IX[b]
	[26] -1 0	   0x0000dc00 - 0x0000dc0f (0x10) IX[b]
	[27] -1 0	   0x00000b70 - 0x00000b73 (0x4) IX[b]
	[28] -1 0	   0x00000970 - 0x00000977 (0x8) IX[b]
	[29] -1 0	   0x00000bf0 - 0x00000bf3 (0x4) IX[b]
	[30] -1 0	   0x000009f0 - 0x000009f7 (0x8) IX[b]
	[31] -1 0	   0x0000f000 - 0x0000f00f (0x10) IX[b]
	[32] -1 0	   0x00001c40 - 0x00001c7f (0x40) IX[b]
	[33] -1 0	   0x00001c00 - 0x00001c3f (0x40) IX[b]
	[34] -1 0	   0x0000fc00 - 0x0000fc3f (0x40) IX[b]
	[35] -1 0	   0x0000ac00 - 0x0000ac7f (0x80) IX[b](
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[4] -1  0	   0xfdef8000 - 0xfdefbfff (0x4000) MX[b]
	[5] -1  0	   0xfdeff000 - 0xfdeff7ff (0x800) MX[b]
	[6] -1  0	   0xfe028000 - 0xfe02800f (0x10) MX[b]
	[7] -1  0	   0xfe029000 - 0xfe0290ff (0x100) MX[b]
	[8] -1  0	   0xfe02a000 - 0xfe02afff (0x1000) MX[b]
	[9] -1  0	   0xfe024000 - 0xfe027fff (0x4000) MX[b]
	[10] -1 0	   0xfe02b000 - 0xfe02bfff (0x1000) MX[b]
	[11] -1 0	   0xfe02c000 - 0xfe02cfff (0x1000) MX[b]
	[12] -1 0	   0xfe02d000 - 0xfe02dfff (0x1000) MX[b]
	[13] -1 0	   0xfe02e000 - 0xfe02e0ff (0x100) MX[b]
	[14] -1 0	   0xfe02f000 - 0xfe02ffff (0x1000) MX[b]
	[15] -1 0	   0xfcfe0000 - 0xfcffffff (0x20000) MX[b](
	[16] -1 0	   0xfb000000 - 0xfbffffff (0x1000000) MX[b](
	[17] -1 0	   0xe0000000 - 0xefffffff (0x10000000) MX[b](
	[18] -1 0	   0xfa000000 - 0xfaffffff (0x1000000) MX[b](
	[19] -1 0	   0x0000ffff - 0x0000ffff (0x1) IX[b]
	[20] -1 0	   0x00000000 - 0x000000ff (0x100) IX[b]
	[21] -1 0	   0x0000b000 - 0x0000b007 (0x8) IX[b]
	[22] -1 0	   0x0000b400 - 0x0000b40f (0x10) IX[b]
	[23] -1 0	   0x0000b800 - 0x0000b803 (0x4) IX[b]
	[24] -1 0	   0x0000bc00 - 0x0000bc07 (0x8) IX[b]
	[25] -1 0	   0x0000c000 - 0x0000c003 (0x4) IX[b]
	[26] -1 0	   0x0000c400 - 0x0000c407 (0x8) IX[b]
	[27] -1 0	   0x0000c800 - 0x0000c80f (0x10) IX[b]
	[28] -1 0	   0x00000b60 - 0x00000b63 (0x4) IX[b]
	[29] -1 0	   0x00000960 - 0x00000967 (0x8) IX[b]
	[30] -1 0	   0x00000be0 - 0x00000be3 (0x4) IX[b]
	[31] -1 0	   0x000009e0 - 0x000009e7 (0x8) IX[b]
	[32] -1 0	   0x0000dc00 - 0x0000dc0f (0x10) IX[b]
	[33] -1 0	   0x00000b70 - 0x00000b73 (0x4) IX[b]
	[34] -1 0	   0x00000970 - 0x00000977 (0x8) IX[b]
	[35] -1 0	   0x00000bf0 - 0x00000bf3 (0x4) IX[b]
	[36] -1 0	   0x000009f0 - 0x000009f7 (0x8) IX[b]
	[37] -1 0	   0x0000f000 - 0x0000f00f (0x10) IX[b]
	[38] -1 0	   0x00001c40 - 0x00001c7f (0x40) IX[b]
	[39] -1 0	   0x00001c00 - 0x00001c3f (0x40) IX[b]
	[40] -1 0	   0x0000fc00 - 0x0000fc3f (0x40) IX[b]
	[41] -1 0	   0x0000ac00 - 0x0000ac7f (0x80) IX[b](
(II) LoadModule: "i2c"(II) Module already built-in
(II) LoadModule: "type1"
(II) Loading /usr/lib/xorg/modules/fonts//libtype1.so
(II) Module type1: vendor="X.Org Foundation"
	compiled for 1.3.0, module version = 1.0.2
	Module class: X.Org Font Renderer
	ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Type1
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
	compiled for 1.3.0, module version = 1.1.0
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/nvidia//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
	compiled for 4.0.2, module version = 1.0.0
	Module class: X.Org Server Extension
	ABI class: X.Org Server Extension, version 0.1
(II) NVIDIA GLX Module  169.12  Thu Feb 14 18:45:56 PST 2008
(II) Loading extension GLX
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
	ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
	Module class: X.Org Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
	compiled for 1.3.0, module version = 1.2.3
	Module class: X.Org XInput Driver
	ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
	compiled for 1.3.0, module version = 1.2.2
(II) NVIDIA dlloader X Driver  169.12  Thu Feb 14 17:55:38 PST 2008
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 02:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
	ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules/extensions/nvidia//libwfb.so
(II) Module wfb: vendor="NVIDIA Corporation"
	compiled for 7.1.99.2, module version = 1.0.0
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"(II) Module already built-in
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
	[19] 0  0	   0x000a0000 - 0x000affff (0x10000) MS[b]
	[20] 0  0	   0x000b0000 - 0x000b7fff (0x8000) MS[b]
	[21] 0  0	   0x000b8000 - 0x000bffff (0x8000) MS[b]
	[22] -1 0	   0x0000ffff - 0x0000ffff (0x1) IX[b]
	[23] -1 0	   0x00000000 - 0x000000ff (0x100) IX[b]
	[24] -1 0	   0x0000b000 - 0x0000b007 (0x8) IX[b]
	[25] -1 0	   0x0000b400 - 0x0000b40f (0x10) IX[b]
	[26] -1 0	   0x0000b800 - 0x0000b803 (0x4) IX[b]
	[27] -1 0	   0x0000bc00 - 0x0000bc07 (0x8) IX[b]
	[28] -1 0	   0x0000c000 - 0x0000c003 (0x4) IX[b]
	[29] -1 0	   0x0000c400 - 0x0000c407 (0x8) IX[b]
	[30] -1 0	   0x0000c800 - 0x0000c80f (0x10) IX[b]
	[31] -1 0	   0x00000b60 - 0x00000b63 (0x4) IX[b]
	[32] -1 0	   0x00000960 - 0x00000967 (0x8) IX[b]
	[33] -1 0	   0x00000be0 - 0x00000be3 (0x4) IX[b]
	[34] -1 0	   0x000009e0 - 0x000009e7 (0x8) IX[b]
	[35] -1 0	   0x0000dc00 - 0x0000dc0f (0x10) IX[b]
	[36] -1 0	   0x00000b70 - 0x00000b73 (0x4) IX[b]
	[37] -1 0	   0x00000970 - 0x00000977 (0x8) IX[b]
	[38] -1 0	   0x00000bf0 - 0x00000bf3 (0x4) IX[b]
	[39] -1 0	   0x000009f0 - 0x000009f7 (0x8) IX[b]
	[40] -1 0	   0x0000f000 - 0x0000f00f (0x10) IX[b]
	[41] -1 0	   0x00001c40 - 0x00001c7f (0x40) IX[b]
	[42] -1 0	   0x00001c00 - 0x00001c3f (0x40) IX[b]
	[43] -1 0	   0x0000fc00 - 0x0000fc3f (0x40) IX[b]
	[44] -1 0	   0x0000ac00 - 0x0000ac7f (0x80) IX[b](
	[45] 0  0	   0x000003b0 - 0x000003bb (0xc) IS[b]
	[46] 0  0	   0x000003c0 - 0x000003df (0x20) IS[b]
(II) Setting vga for screen 0.
(II) Enabling PCI device
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "RenderAccel" "True"
(**) NVIDIA(0): Option "AddARGBGLXVisuals" "True"
(**) NVIDIA(0): Option "DisableGLXRootClipping" "true"
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0):	 enabled.
(II) NVIDIA(0): NVIDIA GPU GeForce 7900 GS (G71) at PCI:2:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 262144 kBytes
(--) NVIDIA(0): VideoBIOS: 05.71.22.44.06
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce 7900 GS at PCI:2:0:0:
(--) NVIDIA(0):	 Samsung SyncMaster (DFP-0)
(--) NVIDIA(0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
(--) NVIDIA(0): Samsung SyncMaster (DFP-0): Internal Dual Link TMDS
(II) NVIDIA(0): Assigned Display Device: DFP-0
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0):	 "1280x1024"
(II) NVIDIA(0):	 "1280x960"
(II) NVIDIA(0):	 "1280x800"
(II) NVIDIA(0):	 "1280x720"
(II) NVIDIA(0):	 "1152x864"
(II) NVIDIA(0):	 "1024x768"
(II) NVIDIA(0):	 "800x600"
(II) NVIDIA(0):	 "640x480"
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
(--) NVIDIA(0): DPI set to (85, 86); computed from "UseEdidDpi" X config
(--) NVIDIA(0):	 option
(**) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
(II) NVIDIA(0): Initialized GPU GART.
(II) NVIDIA(0): Setting mode "1280x1024"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(**) Option "Protocol" "auto"
(**) Option "Device" "/dev/input/mice"
(II) Mouse0: Setting mouse protocol to "ExplorerPS/2"
(**) Mouse0: Device: "/dev/input/mice"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: Core Pointer
(**) Option "Emulate3Buttons" "no"
(**) Option "ZAxisMapping" "4 5"
(**) Mouse0: ZAxisMapping: buttons 4 and 5
(**) Mouse0: Buttons: 9
(**) Mouse0: Sensitivity: 1
(**) Option "CoreKeyboard"
(**) Keyboard0: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "pl"
(**) Keyboard0: XkbLayout: "pl"
(**) Option "XkbOptions" "altwin:super_win"
(**) Keyboard0: XkbOptions: "altwin:super_win"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) Mouse0: ps2EnableDataReporting: succeeded
/var/log/kdm.log - nie istnieje
Po wysypie w home pojawia mi sie jescze taki log
.xsesions-errors
W: polkit.c: Failed to show grant dialog: Unable to lookup exe for caller
W: polkit.c: PolicyKit responded with 'auth_admin_keep_always'
N: main.c: Called SUID root and real-time/high-priority scheduling was requested in the configuration. However, we lack the necessary priviliges:
N: main.c: We are not in group 'pulse-rt' and PolicyKit refuse to grant us priviliges. Dropping SUID again.
N: main.c: For enabling real-time scheduling please acquire the appropriate PolicyKit priviliges, or become a member of 'pulse-rt', or increase the RLIMIT_NICE/RLIMIT_RTPRIO resource limits for this user.
xset:  bad font path element (#422), possible causes are:
Directory does not exist or has wrong permissions
Directory missing fonts.dir
Incorrect font server address or syntax
startkde: Starting up...
kbuildsycoca running...
Failure: Module initalization failed
** (nm-applet:14974): WARNING **: nm_object_get_property: Error getting 'WirelessEnabled' for /org/freedesktop/NetworkManager: The name org.freedesktop.NetworkManager was not provided by any .service files
** (nm-applet:14974): WARNING **: nm_object_get_property: Error getting 'WirelessHardwareEnabled' for /org/freedesktop/NetworkManager: The name org.freedesktop.NetworkManager was not provided by any .service files
X Error: BadWindow (invalid Window parameter) 3
 Major opcode:  12
 Minor opcode:  0
 Resource id:  0x2400003
 Major opcode:  12
 Minor opcode:  0
 Major opcode:  6
 Minor opcode:  0
 Major opcode:  12
 Minor opcode:  0
 Major opcode:  12
 Minor opcode:  0
 Major opcode:  8
 Minor opcode:  0
 Major opcode:  12
 Minor opcode:  0
 Major opcode:  12
 Minor opcode:  0
 Major opcode:  25
 Minor opcode:  0
 Major opcode:  25
 Minor opcode:  0
Przy długich listingach (>15 linii) używamy codebox zamiast code, tak jest czytelniej /Karlik
to mi się nie podoba coś. Dziwne że nie masz kdm.log... poszukaj dobrze w /var/log/
I jeszcze takie pytanko. Jakiej wersji KDE używasz ?
KDE wersja 3.5.9-3.fc8
Pisałem już wyżej.
# rpm -qa |grep kde
kde-i18n-Polish-3.5.9-4.fc8
kdegraphics-libs-3.5.9-1.fc8
kdemultimedia-3.5.9-1.fc8
kdepim-libs-3.5.9-6.fc8
kdeartwork-3.5.9-1.fc8
lockdev-1.0.1-11.fc8.1
kde-settings-kdm-3.5-36.fc8.1
kde-filesystem-4-8.fc8
kde-settings-3.5-36.fc8.1
kdenetwork-libs-3.5.9-2.fc8
kdegraphics-3.5.9-1.fc8
kdenetwork-3.5.9-2.fc8
kdeutils-3.5.9-1.fc8
kdelibs-3.5.9-4.fc8
kdemultimedia-libs-3.5.9-1.fc8
kdebase-libs-3.5.9-3.fc8
kdepim-3.5.9-6.fc8
kdeaccessibility-3.5.9-1.fc8
kdebase-3.5.9-3.fc8
kdeaddons-3.5.9-1.fc8
kde-settings-pulseaudio-3.5-36.fc8.1
Nie mam tego loga.....
