Kino
azyl40
Witam mam problem z programem „Kino” gdy zaimportuję film i chę go obrobić program się zamyka i nie da się go ponowni uruchomić pomaga tylko restart Xów. Czy Zana ktoś na to odpowiedź lub miał już ktoś podobny problem.
pozdrawiam :-)
Proszę tylko to troche długie:
[tymek@dhcppc0 ~]$ kino
> help language code en
(kino:8351): Gtk-WARNING **: Nie można odnaleźć modułu obsługującego motyw w module_path: "nimbus",
> Kino Common being built
> Creating page editor
> Creating Capture Page
> Creating Export Page
> Creating Export1394 Page
> Creating ExportAVI Page
> Creating ExportStills Page
> Creating ExportAudio Page
> Creating ExportMJPEG Page
/usr/share/kino/scripts/dvdauthor/dvdauthor-k3b.sh
which: no dvdauthor in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/tymek/bin)
/usr/share/kino/scripts/dvdauthor/growisofs.sh
/usr/share/kino/scripts/dvdauthor/dvdauthor.sh
/usr/share/kino/scripts/dvdauthor/qdvdauthor.sh
which: no qdvdauthor in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/tymek/bin)
/usr/share/kino/scripts/dvdauthor/none.sh
> Initializing MJPEG Export Page settings from Preferences
> Creating ExportPipe Page
/usr/share/kino/scripts/exports/ffmpeg_xvid_dual.sh
/usr/share/kino/scripts/exports/ffmpeg_h264.sh
/usr/share/kino/scripts/exports/ffmpeg_flv.sh
/usr/share/kino/scripts/exports/rawplay.sh
/usr/share/kino/scripts/exports/ffmpeg_utils.sh
/usr/share/kino/scripts/exports/ffmpeg2theora.sh
/usr/share/kino/scripts/exports/ffmpeg_dvd_dual.sh
which: no mplex in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/tymek/bin)
/usr/share/kino/scripts/exports/ffmpeg_mov.sh
/usr/share/kino/scripts/exports/ffmpeg_mp4.sh
/usr/share/kino/scripts/exports/mencoder.sh
/usr/share/kino/scripts/exports/ffmpeg_dvd.sh
/usr/share/kino/scripts/exports/ffmpeg_divx.sh
/usr/share/kino/scripts/exports/extract_chapters
/usr/share/kino/scripts/exports/ffmpeg_xvid.sh
/usr/share/kino/scripts/exports/ffmpeg_divx_dual.sh
/usr/share/kino/scripts/exports/ffmpeg_vcd.sh
/usr/share/kino/scripts/exports/gstreamer_theora.sh
/usr/share/kino/scripts/exports/ffmpeg_3gp.sh
which: no MP4Box in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/tymek/bin)
/usr/share/kino/scripts/exports/ffmpeg_h264_dual.sh
/usr/share/kino/scripts/exports/ffmpeg_mp3.sh
/usr/share/kino/scripts/exports/ffmpeg_mp4_dual.sh
> Creating page trim
>>> Image Create: Colour Range
>>> Image Create: Fixed Colour
>>> Image Create: From File
>>> Image Create: Gradient
>>> Image Create: Random noise
>>> Image Filter: No Change
>>> Image Filter: Black & White
>>> Image Filter: Kaleidoscope
>>> Image Filter: Fade In
>>> Image Filter: Fade Out
>>> Image Filter: Flip
>>> Image Filter: Mirror
>>> Image Filter: Reverse Video
>>> Image Filter: Sepia
>>> Image Transition: Dissolve
>>> Image Transition: Barn Door Wipe
>>> Image Transition: Differences
>>> Image Transition: No Change
>>> Image Transition: Push Wipe
>>> Image Transition: Switch
>>> Audio Filter: No Change
>>> Audio Filter: Dub
>>> Audio Filter: Fade In
>>> Audio Filter: Fade Out
>>> Audio Filter: Gain
>>> Audio Filter: Mix
>>> Audio Filter: Silence
>>> Audio Transition: Cross Fade
>>> Audio Transition: No Change
> Creating Magick Page
>> Searching /usr/lib/kino-gtk2 for plugins
>>> Registering plugin /usr/lib/kino-gtk2/libtimfx.so
>>> Registering plugin /usr/lib/kino-gtk2/libdvtitler.so
>>> Registering plugin /usr/lib/kino-gtk2/libkinoplus.so
>>> Image Filter: Blur
>>> Image Filter: Colour Hold
>>> Image Filter: Soft Focus
>>> Image Transition: Luma Wipe
>>> Image Filter: Superimpose
>>> Image Filter: Titler
>>> Image Filter: Colour Average
>>> Image Filter: Charcoal
>>> Image Filter: Jerky
>>> Image Filter: Levels
>>> Image Filter: Pan and Zoom
>>> Image Filter: Pixelate
>>> Image Transition: Composite
>>> Image Transition: Blue Chroma Key
>>> Image Transition: Green Chroma Key
>> Starting Editor
>> Creating undo/redo buffer
>>> Received playlist to store at position 0
>>>> Adding to end
>>> Received request to undo from position 0
>> Trying XVideo at 720x576
>>> XvQueryAdaptors count: 2
>>> Xv: NV17 Video Texture: ports 355 - 386
>>> formats supported: 4
>>>	 0x32595559 (YUY2) packed
>>>	 0x32315659 (YV12) planar
>>>	 0x59565955 (UYVY) packed
>>>	 0x30323449 (I420) planar
>>> 0: XV_IMAGE, 2046x2046 rate = 1/1
kino: pcm_params.c:2351: sndrv_pcm_hw_params: Warunek zapewnienia `err >= 0' nie został spełniony.
Przerwane
[tymek@dhcppc0 ~]$
<Sorror> Do postowania długich listingów służą znaczniki CODEBOX
Jak się nie mylę problem z obsługa dźwięku. Nie podam Ci dokładnej przyczyny ale obstawiałbym, że to wina PulseAudio. Poszukaj w opcjach konfiguracyjnych kina jakiś opcji dotyczących dźwięku i/lub pozmieniaj ustawienia w System >> Preferencje >> Sprzęt >> Dźwięk (lub poprostu gnome-sound-properties). W ostateczności możesz spróbować usunąć PulseAudio, ale nie wiem czy dokładnie to jest źródłem twojego problemu oraz czy pomoże.
Pulse audio to zakilowałem już z 2 miesiące temu bo nie miałem dźwięku w skype i w wine.
Spróbuj odpalić program z roota. Wina leży oczywiście w PulseAudio, wstrzymałbym się jednak z ozgrzebywaniem configa, jeśli problem wystąpi również na roocie.
Wyskakuje tak i to samo się dzieje
[root@dhcppc0 ~]# kino
which: no dvdauthor in (/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
which: no qdvdauthor in (/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
which: no mplex in (/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
which: no MP4Box in (/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
> Creating page trim
>>> Image Filter: Flip
>>> Image Filter: Sepia
>>> Audio Filter: Dub
>>> Audio Filter: Gain
>>> Audio Filter: Mix
>>> Image Filter: Blur
>>> Image Filter: Jerky
>> Starting Editor
>> Kino Common newFile
>>>> Adding to end
>> Leaving Editor
>> Left Editor
>> Starting Editor
Video in input file (/home/tymek/Pulpit/100_2945.mov) must be in DV format.
>> Kino Common newFile
>>>> Adding to end
>>>> Adding to end
>> Leaving Editor
>> Left Editor
>> Starting Editor
Przerwane
[root@dhcppc0 ~]#
:angry:
Proszę
[tymek@dhcppc0 ~]$ ps aux
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root         1  0.0  0.0   2112   636 ?        Ss   10:12   0:00 init [5]
root         2  0.0  0.0      0     0 ?        S<   10:12   0:00 [kthreadd]
root         3  0.0  0.0      0     0 ?        S<   10:12   0:00 [migration/0]
root         4  0.0  0.0      0     0 ?        S<   10:12   0:00 [ksoftirqd/0]
root         5  0.0  0.0      0     0 ?        S<   10:12   0:00 [watchdog/0]
root         6  0.0  0.0      0     0 ?        S<   10:12   0:00 [events/0]
root         7  0.0  0.0      0     0 ?        S<   10:12   0:00 [khelper]
root        59  0.0  0.0      0     0 ?        S<   10:12   0:00 [kblockd/0]
root        62  0.0  0.0      0     0 ?        S<   10:12   0:00 [kacpid]
root        63  0.0  0.0      0     0 ?        S<   10:12   0:00 [kacpi_notify]
root       137  0.0  0.0      0     0 ?        S<   10:12   0:00 [cqueue/0]
root       139  0.0  0.0      0     0 ?        S<   10:12   0:00 [ksuspend_usbd]
root       144  0.0  0.0      0     0 ?        S<   10:12   0:00 [khubd]
root       147  0.0  0.0      0     0 ?        S<   10:12   0:00 [kseriod]
root       183  0.0  0.0      0     0 ?        S    10:12   0:00 [pdflush]
root       184  0.0  0.0      0     0 ?        S    10:12   0:00 [pdflush]
root       185  0.0  0.0      0     0 ?        S<   10:12   0:00 [kswapd0]
root       225  0.0  0.0      0     0 ?        S<   10:12   0:00 [aio/0]
root       374  0.0  0.0      0     0 ?        S<   10:12   0:00 [kpsmoused]
root       402  0.0  0.0      0     0 ?        S<   10:12   0:00 [ata/0]
root       403  0.0  0.0      0     0 ?        S<   10:12   0:00 [ata_aux]
root       406  0.0  0.0      0     0 ?        S<   10:12   0:00 [scsi_eh_0]
root       407  0.0  0.0      0     0 ?        S<   10:12   0:00 [scsi_eh_1]
root       414  0.0  0.0      0     0 ?        S<   10:12   0:00 [scsi_eh_2]
root       415  0.0  0.0      0     0 ?        S<   10:12   0:00 [usb-storage]
root       423  0.0  0.0      0     0 ?        S<   10:12   0:00 [kjournald]
root       455  0.0  0.0      0     0 ?        S<   10:12   0:00 [kauditd]
root       487  0.0  0.1   3504  1904 ?        S<s  10:12   0:00 /sbin/udevd -d
root      1161  0.0  0.0      0     0 ?        S<   10:12   0:00 [cx88 tvaudio]
root      1302  0.0  0.0      0     0 ?        S<   10:12   0:00 [kmpathd/0]
root      1329  0.0  0.0      0     0 ?        S<   10:12   0:00 [kjournald]
root      1330  0.0  0.0      0     0 ?        S<   10:12   0:00 [kjournald]
root      1787  0.0  0.0   2384   548 ?        Ss   10:13   0:00 /sbin/dhclient
root      1853  0.0  0.0  12232   664 ?        S<sl 10:13   0:00 auditd
root      1855  0.0  0.0  12148   680 ?        S<sl 10:13   0:00 /sbin/audispd
root      1869  0.0  0.9  11544 10052 ?        Ss   10:13   0:00 /usr/sbin/resto
rpc       1889  0.0  0.0   2256   692 ?        Ss   10:13   0:00 rpcbind
rpcuser   1908  0.0  0.0   1952   716 ?        Ss   10:13   0:00 rpc.statd
root      1936  0.0  0.0      0     0 ?        S<   10:13   0:00 [rpciod/0]
root      1944  0.0  0.0   5336   596 ?        Ss   10:13   0:00 rpc.idmapd
root      2000  0.0  0.1  12824  1316 ?        Ssl  10:13   0:00 pcscd
root      2010  0.0  0.1  12768  1192 ?        Sl   10:13   0:00 rsyslogd -m 0
root      2014  0.0  0.0   1760   328 ?        Ss   10:13   0:00 rklogd -x
dbus      2029  0.0  0.1  13188  1452 ?        Ssl  10:13   0:00 dbus-daemon --s
root      2041  0.1  3.3  65504 34388 ?        Ssl  10:13   0:05 /usr/bin/python
root      2054  0.0  0.1   6176  1136 ?        Ssl  10:13   0:00 automount
root      2093  0.0  0.0   1756   560 ?        Ss   10:13   0:00 /usr/sbin/acpid
root      2102  0.0  0.1   3148  1212 ?        Ss   10:13   0:00 /usr/sbin/hcid
root      2108  0.0  0.0      0     0 ?        S<   10:13   0:00 [btaddconn]
root      2109  0.0  0.0      0     0 ?        S<   10:13   0:00 [btdelconn]
root      2121  0.0  0.0   2960   984 ?        S    10:13   0:00 /usr/lib/blueto
root      2124  0.0  0.0      0     0 ?        S<   10:13   0:00 [krfcommd]
root      2135  0.0  0.0   6064  1008 ?        Ss   10:13   0:00 /usr/sbin/sshd
root      2156  0.0  0.1   9544  1692 ?        Ss   10:13   0:00 sendmail: accep
smmsp     2165  0.0  0.1   8248  1492 ?        Ss   10:13   0:00 sendmail: Queue
root      2176  0.0  0.0   1860   456 ?        S    10:13   0:00 nasd -b -local
root      2185  0.0  0.2   7724  2140 ?        Ssl  10:13   0:00 console-kit-dae
root      2217  0.0  0.1   5096  1156 ?        Ss   10:13   0:00 crond
root      2239  0.0  0.0   2072   444 ?        Ss   10:13   0:00 /usr/sbin/atd
avahi     2273  0.0  0.1   2704  1400 ?        Ss   10:13   0:00 avahi-daemon: r
avahi     2274  0.0  0.0   2704   452 ?        Ss   10:13   0:00 avahi-daemon: c
root      2291  0.0  0.2   9924  2764 ?        Ss   10:13   0:00 cupsd
68        2300  0.0  0.3   5852  3732 ?        Ss   10:13   0:00 hald
root      2301  0.0  0.0   3296   928 ?        S    10:13   0:00 hald-runner
root      2315  0.0  0.0   3396   996 ?        S    10:13   0:00 hald-addon-inpu
68        2330  0.0  0.0   2156   824 ?        S    10:13   0:00 hald-addon-acpi
root      2365  0.0  0.0   3396   888 ?        S    10:13   0:00 hald-addon-stor
root      2367  0.0  0.0   3396   884 ?        S    10:13   0:00 hald-addon-stor
root      2369  0.0  0.0   3396   884 ?        S    10:13   0:00 hald-addon-stor
root      2371  0.0  0.0   3396   888 ?        S    10:13   0:00 hald-addon-stor
root      2374  0.0  0.0   3396   988 ?        S    10:13   0:01 hald-addon-stor
root      2394  0.0  0.0   1804   748 ?        SNs  10:13   0:00 anacron -s
root      2450  0.0  0.0   1744   420 tty1     Ss+  10:13   0:00 /sbin/mingetty
root      2451  0.0  0.0   1744   420 tty2     Ss+  10:13   0:00 /sbin/mingetty
root      2452  0.0  0.0   1744   416 tty3     Ss+  10:13   0:00 /sbin/mingetty
root      2453  0.0  0.0   1744   416 tty4     Ss+  10:13   0:00 /sbin/mingetty
root      2454  0.0  0.0   1744   416 tty5     Ss+  10:13   0:00 /sbin/mingetty
root      2455  0.0  0.0   1744   416 tty6     Ss+  10:13   0:00 /sbin/mingetty
root      2456  0.0  0.4  18700  4692 ?        Ss   10:13   0:00 /usr/sbin/gdm-b
root      2526  0.0  0.3  17508  3728 ?        S    10:13   0:00 /usr/sbin/gdm-b
root      2530  0.0  0.1  18400  1620 ?        S    10:13   0:00 /usr/sbin/gdm-b
root      2531  2.1  6.7  92720 70288 tty7     SLs+ 10:13   1:41 /usr/bin/X :0 -
root      2535  0.0  0.8  22476  9132 ?        SN   10:13   0:00 /usr/bin/python
root      2537  0.0  0.0   2700  1032 ?        SN   10:13   0:00 /usr/libexec/ga
tymek     2561  0.0  0.1  14340  1688 ?        SL   10:14   0:00 /usr/bin/gnome-
tymek     2563  0.0  0.6  34328  7160 ?        Ssl  10:14   0:00 /usr/bin/gnome-
tymek     2610  0.0  0.0   5536   604 ?        Ss   10:14   0:00 /usr/bin/ssh-ag
tymek     2613  0.0  0.0   2952   556 ?        S    10:14   0:00 /usr/bin/dbus-l
tymek     2614  0.0  0.1  12928  1152 ?        Ssl  10:14   0:00 /bin/dbus-daemo
tymek     2621  0.0  0.4   8348  4396 ?        S    10:14   0:00 /usr/libexec/gc
tymek     2625  0.0  1.1  38960 11924 ?        Sl   10:14   0:00 /usr/libexec/gn
tymek     2629  0.1  0.4  33352  5144 ?        Sl   10:14   0:04 /usr/bin/pulsea
tymek     2635  0.0  0.1   5216  1676 ?        S    10:14   0:00 /usr/libexec/pu
tymek     2636  0.1  0.9  21476  9620 ?        S    10:14   0:06 metacity --sm-c
tymek     2638  0.0  2.2  47404 23420 ?        S    10:14   0:02 gnome-panel --s
tymek     2639  0.0  1.9  80288 20352 ?        S    10:14   0:01 nautilus --no-d
tymek     2644  0.0  0.4  26528  5152 ?        Ss   10:14   0:00 gnome-volume-ma
tymek     2646  0.0  0.2  39056  2800 ?        Ssl  10:14   0:00 /usr/libexec/bo
tymek     2667  0.2  0.3  17396  3508 ?        Ss   10:14   0:10 gnome-screensav
tymek     2671  1.3  3.3  82904 34652 ?        Sl   10:14   1:01 skype
tymek     2675  0.0  0.3  11536  3508 ?        S    10:14   0:00 /usr/libexec/gn
tymek     2676  0.0  1.4  39560 14732 ?        Sl   10:14   0:01 kadu
tymek     2682  0.0  1.0  41300 10700 ?        S    10:14   0:00 nm-applet --sm-
tymek     2683  0.0  1.9  39284 20388 ?        S    10:14   0:00 /usr/bin/python
tymek     2684  0.0  1.2  28440 12500 ?        S    10:14   0:00 python /usr/sha
tymek     2686  0.0  0.3  17160  3936 ?        S    10:14   0:00 pam-panel-icon
tymek     2688  0.0  0.7  29456  7856 ?        Ss   10:14   0:00 gnome-power-man
root      2690  0.0  0.0   1940   616 ?        S    10:14   0:00 /sbin/pam_times
tymek     2692  0.0  1.3  40832 14060 ?        S    10:14   0:02 /usr/libexec/wn
tymek     2696  0.0  0.9  68024 10316 ?        S    10:14   0:00 /usr/libexec/tr
tymek     2710  0.0  0.0   2616   752 ?        S    10:14   0:00 /usr/libexec/ma
tymek     2716  0.0  0.0   2700   996 ?        S    10:14   0:00 /usr/libexec/ga
tymek     2731  0.0  0.9  27312  9340 ?        S    10:14   0:00 /usr/libexec/no
tymek     2734  0.0  2.5  62816 26032 ?        Sl   10:14   0:01 mono /usr/lib/t
tymek     2737  0.0  1.2  39940 12812 ?        S    10:14   0:00 /usr/libexec/fa
tymek     2740  0.0  1.2  33752 12632 ?        S    10:14   0:00 /usr/libexec/cl
tymek     2743  0.0  1.3  61612 13952 ?        Sl   10:14   0:00 /usr/libexec/mi
tymek     2781  0.0  1.0  30180 10468 ?        S    10:14   0:00 /usr/libexec/no
tymek     2873  0.0  0.1   4652  1096 ?        S    10:39   0:00 /bin/sh /usr/li
tymek     2891  0.0  0.1   4652  1112 ?        S    10:39   0:00 /bin/sh /usr/li
tymek     2896 27.6  6.5 218020 67956 ?        Sl   10:39  14:59 /usr/lib/firefo
tymek     2941  0.0  0.1   4652  1072 ?        S    10:45   0:00 /bin/sh /usr/li
tymek     2951  0.3  9.3 243768 97124 ?        Sl   10:45   0:08 /usr/lib/openof
root      3189  0.0  0.0   3000   232 ?        S    10:47   0:00 dbus-launch --a
root      3190  0.0  0.0  12796  1016 ?        Ssl  10:47   0:00 /bin/dbus-daemo
root      3193  0.0  0.3  11616  3588 ?        S    10:47   0:00 /usr/libexec/gn
root      3195  0.0  0.3   7808  3880 ?        S    10:47   0:00 /usr/libexec/gc
tymek     3391  0.0  0.1   4656  1092 ?        S    11:08   0:00 /bin/sh /usr/bi
tymek     3409  4.3  9.8 795792 102444 ?       Sl   11:08   1:06 java -Dazureus.
root      3624  0.0  0.1   4652  1096 ?        SN   11:18   0:00 /bin/bash /usr/
root      3625  0.0  0.1   4652  1056 ?        SN   11:18   0:00 /bin/bash /etc/
root      3626  0.0  0.0   4320   708 ?        SN   11:18   0:00 awk -v progname
root      3631  0.0  0.0   3796   468 ?        SN   11:18   0:00 sleep 2106
tymek     3804  5.0  1.9  84516 20048 ?        Sl   11:33   0:00 gnome-terminal
tymek     3806  0.0  0.0   2616   596 ?        S    11:33   0:00 gnome-pty-helpe
tymek     3807  0.0  0.1   4840  1512 pts/1    Ss   11:33   0:00 bash
tymek     3828  0.0  0.0   4524   932 pts/1    R+   11:33   0:00 ps aux
[tymek@dhcppc0 ~]$
Gdyby tak było to by w konsoli wypluł że nie może się połączyć z ASLĄ bo "coś" jej używa ;)
Jeśli robisz copy/paste z konsoli, to maksymalizuj okno, ponieważ w standardowym rozmiarze przycina output. Albo zrzucaj przez ps aux > ps.txt. Niemniej:
po rozwinięciu zapewne wygląda:
/usr/bin/pulseaudio --log-target=syslog
Tak więc wbrew temu co napisałeś korzystasz z PulseAudio i w nim leży przyczyna problemu z Kino.
To dziwne bo pamiętam jak kilowalem pulseaudio czyli jak zakiluje pulse audio to kino bedzie działać normalnie
Dzieki za pomoc pozdrawiam
No rozumiem, ja wklepuje killall pulseaudio odpalam program jak sończe to w konsoli pulseaudio i wszystko ładnie działa. A tak na marginesie się z zapytam co może być przyczynom. Gdy gadam z kimś przez skype nie mam dzwięku w CS 1.6 i nie mogę wtedy puścić żadnej muzyki a zaś jak sucha muzyki i ktoś domnie zadzwoni lub ja do niego zadzwonię to zaś nie mam dźwięku w skype. i muszę wybierać między tym a tym :unsure:
"Przyczynom" może być właśnie to że do alsy może się podłączyć tylko jedna aplikacja, a do PulseAudio moze się podłączyć wiele aplikacji. Problem jest taki że Kino czy Skype nie obsługują PulseAudio.
yhhhh że co ?????
1. Do alsy można podłaczyć ile aplikacji się chce
2. alsa to ogólnie coś a'la sterownik dźwięku
3. pulseaudio to ogólnie rozumiany serwer dźwięku
Pulseaudio odtwarzając dźwięk korzysta, uwaga, np. z ALSY !! ;) Po prostu to coś w rodzaju nakładki (backend) na sam sterownik. rzynajmniej jakoś tak to szło, nie chce mi się dokład nie wyszukiwać :-)
Gość
