JanuszWo Napisano Listopad 18, 2008 Zgłoszenie Share Napisano Listopad 18, 2008 Witam! Po aktualizacji kernela do wersji 2.6.27 na fedorze 9 (laptop lenowo r61i) mam przy wejściu na użytkownika piękne okienko z napisem: Your system had a kernel failure Kiedy kliknę na napis "Show details" mogę poczytać Kernel failure message 1: ------------[ cut here ]------------ WARNING: at fs/sysfs/dir.c:463 sysfs_add_one+0x2a/0x36() sysfs: duplicate filename '1' can not be created Modules linked in: Pid: 1, comm: swapper Not tainted 2.6.27.5-37.fc9.i686 #1 [<c042a052>] warn_slowpath+0x4b/0x6c [<c0402707>] ? __switch_to+0xd3/0x153 [<c0500684>] ? idr_get_empty_slot+0x12a/0x1d9 [<c0500803>] ? ida_get_new_above+0xd0/0x171 [<c04c9ef4>] ? sysfs_ilookup_test+0x0/0x11 [<c049f0ee>] ? ifind+0x55/0x60 [<c04ca0e7>] ? sysfs_find_dirent+0x16/0x27 [<c04ca239>] sysfs_add_one+0x2a/0x36 [<c04ca6d6>] create_dir+0x43/0x68 [<c04ca728>] sysfs_create_dir+0x2d/0x41 [<c0501185>] kobject_add_internal+0xb2/0x153 [<c05012d1>] kobject_add_varg+0x35/0x41 [<c05012fd>] kobject_init_and_add+0x20/0x22 [<c050f172>] pci_create_slot+0x93/0xe1 [<c054a3a8>] register_slot+0x14f/0x1e7 [<c043e958>] ? up+0x2b/0x2f [<c053b99e>] acpi_ns_walk_namespace+0x9a/0x110 [<c053a271>] acpi_walk_namespace+0x46/0x66 [<c054a259>] ? register_slot+0x0/0x1e7 [<c054a228>] walk_p2p_bridge+0xb7/0xe8 [<c054a259>] ? register_slot+0x0/0x1e7 [<c054a259>] ? register_slot+0x0/0x1e7 [<c054a259>] ? register_slot+0x0/0x1e7 [<c053b99e>] acpi_ns_walk_namespace+0x9a/0x110 [<c053a271>] acpi_walk_namespace+0x46/0x66 [<c054a171>] ? walk_p2p_bridge+0x0/0xe8 [<c054a124>] acpi_pci_slot_add+0x10d/0x15a [<c054a171>] ? walk_p2p_bridge+0x0/0xe8 [<c054a259>] ? register_slot+0x0/0x1e7 [<c0548901>] acpi_pci_register_driver+0x39/0x50 [<c079f5f6>] acpi_pci_slot_init+0x17/0x1b [<c0401125>] _stext+0x3d/0x115 [<c079f5df>] ? acpi_pci_slot_init+0x0/0x1b [<c0463028>] ? register_irq_proc+0x92/0xae [<c0463081>] ? init_irq_proc+0x3d/0x4a [<c077e362>] kernel_init+0x177/0x1c5 [<c077e1eb>] ? kernel_init+0x0/0x1c5 [<c040494b>] kernel_thread_helper+0x7/0x10 ======================= ---[ end trace a7919e7f17c0a725 ]--- Przy starcie systemu, przy ładowaniu kernela pojawia się informacja (spisane ze zdjęcia): kobject_add_internal failed for 1 with - EEXIST don't try to register thing with the same name in the same directory Unable to register kobject 1 pci_slot: pci_create_slot returned -17 Potem jest to, co zwykle: Red Hat nash version i tak dalej... Mam się bać? Coś się złego dzieje z kompem? Systemem? Pozdrawiam, proszę o odpowiedź - JanuszWo W ogóle, to się wkurzyłem... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
morsik Napisano Listopad 19, 2008 Zgłoszenie Share Napisano Listopad 19, 2008 Chyba w Twojej wypowiedzi jest jakaś nieścisłość... Piszesz o momencie ładowania kernela, podczas gdy w Twoim poście jest napisane coś o przycisku Show details który jak podejrzewam jest w RHGB. Proszę, wyjaśnij dokładnie jeszcze raz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 19, 2008 Zgłoszenie Share Napisano Listopad 19, 2008 (...)w Twoim poście jest napisane coś o przycisku Show details który jak podejrzewam jest w RHGB.@JanuszWo - Może na początek po prostu wyłącz rhgb przy starcie. Uruchomienie w trybie tekstowym może przynieść istotne informacje. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Listopad 19, 2008 Zgłoszenie Share Napisano Listopad 19, 2008 Mi się wydaje, że to chodzi o dymek pojawiajacy sietuż po zalogowaniu do systemu. Miałem podobny w F10. ja bym zgłosił ten bład. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
JanuszWo Napisano Listopad 19, 2008 Autor Zgłoszenie Share Napisano Listopad 19, 2008 Witam! Przepraszam, za pewną nieścisłość. Najpierw przy starcie systemu, przy ładowaniu kernela mam informację ,że kobject_add_internal failed for 1 with - EEXIST don't try to register thing with the same name in the same directory Unable to register kobject 1 - i tak dalej... A potem po zalogowaniu jako użytkownik pojawia się na dole ekranu takie okienko "Your system had a kernel failure" Na nim mogę kliknąć napis "Show details" i tak dalej... Czy jak pozwalam przesłać raport to nie jest to jeszcze zgłoszenie błędu? Jakoś mam się gdzieś z tym opisywać? Czy to nie jest niebezpieczne dla mojego komputera? Wrócić na starsze jądro, czy używać tak jak jest? Pozdrawiam - JanuszWo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Listopad 20, 2008 Zgłoszenie Share Napisano Listopad 20, 2008 Ja bym używał starego jadra a bład możesz zgłosić https://bugzilla.redhat.com/ tutaj. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dj_oko Napisano Listopad 20, 2008 Zgłoszenie Share Napisano Listopad 20, 2008 Mam to samo "Dymka" nie uświadczyłem, ale system zachowuje się w ten sam sposób. Laptop Lenovo R61i 8932-AEG. Idę na bugzillę z tym Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Listopad 20, 2008 Zgłoszenie Share Napisano Listopad 20, 2008 W zasadzie to błędu nie musi wcale na bugzillę zgłaszać, jako że kerneloops już się tym poniekąd zajął, z tą różnicą że wysłał info o tym nie na bugzillę, tylko bezpośrednio do developerów jądra na www.kerneloops.org . Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
daf Napisano Listopad 20, 2008 Zgłoszenie Share Napisano Listopad 20, 2008 W zasadzie to błędu nie musi wcale na bugzillę zgłaszać, jako że kerneloops już się tym poniekąd zajął, z tą różnicą że wysłał info o tym nie na bugzillę, tylko bezpośrednio do developerów jądra na www.kerneloops.org . nie wiadomo jednak czy to nie jest ze wzgledu na modyfikacje wprowadzane przez programistow Fedory wiec nich lepiej zglosi. najwyzej zamkna sprawe. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Listopad 21, 2008 Zgłoszenie Share Napisano Listopad 21, 2008 Spokojnie, jest już dobrze znane z pewnością, również opiekunom fedory (którzy również są developerami kernela przecież ) → http://www.kerneloops.org/searchfile.php?s...Filename+Search Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
