bieszczaders Napisano Październik 31, 2009 Zgłoszenie Share Napisano Październik 31, 2009 Witam, Zakupilem sobie dzis konwerter USB-RS232 i za skarby swiata nie moge tego skonfigurowac. lsusb Bus 007 Device 003: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 002: ID 046d:c50a Logitech, Inc. Cordless Mouse Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 003: ID 04f2:b008 Chicony Electronics Co., Ltd USB 2.0 Camera Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 0483:2016 SGS Thomson Microelectronics Fingerprint Reader Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub dmesg pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0 pl2303 7-1:1.0: device disconnected usb 7-1: usbfs: process 11432 (VirtualBox) did not claim interface 0 before use usb 7-1: reset full speed USB device using uhci_hcd and address 2 usb 7-1: device firmware changed usb 7-1: USB disconnect, address 2 usb 7-1: new full speed USB device using uhci_hcd and address 3 usb 7-1: New USB device found, idVendor=067b, idProduct=2303 usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 7-1: Product: USB-Serial Controller usb 7-1: Manufacturer: Prolific Technology Inc. usb 7-1: configuration #1 chosen from 1 choice pl2303 7-1:1.0: pl2303 converter detected usb 7-1: pl2303 converter now attached to ttyUSB0 Zainstalowalem gtkterm i za nic nie moge nawiazac polaczenia Jakies sugestie co jeszcze moge zrobic? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Październik 31, 2009 Zgłoszenie Share Napisano Październik 31, 2009 Konwerter to konwerter - co tu konfigurować? Opisz dokładniej jaki chcesz efekt osiągnąć i co podłączasz od strony RS-232. Pozornie wszystko jest jak najbardziej OK → "usb 7-1: pl2303 converter now attached to ttyUSB0" P.S. Co tam robi VirtualBox? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bieszczaders Napisano Październik 31, 2009 Autor Zgłoszenie Share Napisano Październik 31, 2009 No wlasnie wyglada jak powinno wirtualny port mam pod /dev/ttyUSB0 mimo to nie moge nawiazac sesji. Podlaczyc sie chce do serwera (rs232). Co do tego wpisu virtualbox to bierze sie on stad, ze chcialem udsotepnic zasoby USB pod virtualboxa (odpowiedni wpis do fstab). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Październik 31, 2009 Zgłoszenie Share Napisano Październik 31, 2009 Zacząłbym z wyłączonym VB i sprawdził czy przejściówka działa poprawnie na systemie-gospodarzu. Jak się podłączysz z hosta, to wtedy dopiero próbuj pokazać urządzenie pod VB. Pamiętaj, że na gospodarzu zasób podłączony przez USB musi być odmontowany (chociaż chyba najnowsze VB same dbają o odmontowanie na gospodarzu zanim udostępnią dla gościa). [EDIT] Przy okazji powiedz jaki system na gospodarzu - windy czy Linux. Zakładam, że na gościu jest tak jak w tytule - F11. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Rysio Napisano Styczeń 25, 2010 Zgłoszenie Share Napisano Styczeń 25, 2010 Mam nadzieję że mogę w tym temacie zadać pytanie. Mam w planie również zakup przejściówki USB/RS232 aby łączyć się z urządzeniami (modemem) poprzez MINICOM. Czy zatem obojętne jest jakiej firmy i czy jakieś sterowniki są niezbędne i wreszcie czy w pliku konfiguracyjnym MINICOM a mam wpisać jakiś /dev/USB zamiast /dev/ttyS0 . Obecnie pracuję na FC11. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
