murgal Napisano Listopad 19, 2009 Zgłoszenie Share Napisano Listopad 19, 2009 [root@localhost konrad]# yum install kmod-nvidia Loaded plugins: refresh-packagekit Setting up Install Process Resolving Dependencies --> Running transaction check ---> Package kmod-nvidia.i586 0:190.42-1.fc11.1 set to be updated --> Processing Dependency: kmod-nvidia-2.6.30.9-96.fc11.i586 >= 190.42-1.fc11.1 for package: kmod-nvidia-190.42-1.fc11.1.i586 --> Running transaction check ---> Package kmod-nvidia-2.6.30.9-96.fc11.i586.i586 0:190.42-1.fc11.1 set to be updated --> Processing Dependency: kernel-uname-r = 2.6.30.9-96.fc11.i586 for package: kmod-nvidia-2.6.30.9-96.fc11.i586-190.42-1.fc11.1.i586 --> Processing Dependency: nvidia-kmod-common >= 190.42 for package: kmod-nvidia-2.6.30.9-96.fc11.i586-190.42-1.fc11.1.i586 --> Running transaction check ---> Package kernel.i586 0:2.6.30.9-96.fc11 set to be installed --> Processing Dependency: kernel-firmware >= 2.6.30.9-96.fc11 for package: kernel-2.6.30.9-96.fc11.i586 ---> Package xorg-x11-drv-nvidia.i586 0:190.42-1.fc11 set to be updated --> Processing Dependency: xorg-x11-drv-nvidia-libs-i586 = 190.42-1.fc11 for package: xorg-x11-drv-nvidia-190.42-1.fc11.i586 --> Processing Dependency: livna-config-display >= 0.0.21 for package: xorg-x11-drv-nvidia-190.42-1.fc11.i586 --> Processing Dependency: livna-config-display for package: xorg-x11-drv-nvidia-190.42-1.fc11.i586 --> Processing Dependency: livna-config-display for package: xorg-x11-drv-nvidia-190.42-1.fc11.i586 --> Running transaction check ---> Package kernel-firmware.noarch 0:2.6.30.9-96.fc11 set to be updated ---> Package livna-config-display.noarch 0:0.0.23-1.fc11 set to be updated --> Processing Dependency: system-config-display for package: livna-config-display-0.0.23-1.fc11.noarch ---> Package xorg-x11-drv-nvidia-libs.i586 0:190.42-1.fc11 set to be updated --> Running transaction check ---> Package system-config-display.noarch 0:1.1.3-2.fc11 set to be updated --> Processing Dependency: rhpxl >= 0.34-1 for package: system-config-display-1.1.3-2.fc11.noarch --> Running transaction check ---> Package rhpxl.i586 0:1.12-2.fc11 set to be updated --> Finished Dependency Resolution Dependencies Resolved ================================================================================ ====================================== Package Arch Version Repository Size ================================================================================ ====================================== Installing: kmod-nvidia i586 190.42-1.fc11.1 rpmfusion-nonfree-updates 28 k Installing for dependencies: kernel i586 2.6.30.9-96.fc11 updates 21 M kmod-nvidia-2.6.30.9-96.fc11.i586 i586 190.42-1.fc11.1 rpmfusion-nonfree-updates 2.9 M livna-config-display noarch 0.0.23-1.fc11 rpmfusion-nonfree 67 k rhpxl i586 1.12-2.fc11 fedora 96 k system-config-display noarch 1.1.3-2.fc11 fedora 196 k xorg-x11-drv-nvidia i586 190.42-1.fc11 rpmfusion-nonfree-updates 3.3 M xorg-x11-drv-nvidia-libs i586 190.42-1.fc11 rpmfusion-nonfree-updates 7.4 M Updating for dependencies: kernel-firmware noarch 2.6.30.9-96.fc11 updates 675 k Transaction Summary ================================================================================ ====================================== Install 8 Package(s) Upgrade 1 Package(s) Total download size: 36 M Is this ok [y/N]: Takie coś mi wywala jak chce zainstalować steroniwki, a przeciez w wiki pisze zeby nie zgadzac sie jak chce karnela instalować. Co robić w takiej sytuacji? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 19, 2009 Zgłoszenie Share Napisano Listopad 19, 2009 [...] a przeciez w wiki pisze jest napisane zeby nie zgadzac sie jak chce karnela instalować. Co robić w takiej sytuacji?W którym miejscu tak jest napisane? Przeczytaj uważnie Instaluj śmiało - numer kernela zgadza się z numerkiem w pakiecie kmod-nvidia. Tylko po instalacji musisz zrestartowac system na tym najnowszym jądrze. Sprawdź tylko czy Twoja karta będzie obsługiwana przez kmod-nvidia czy może (w przypadku kart starszych) przez kmod-nvidia-173xx lub kmod-nvidia-96xx. [EDIT] I przy długich listingach korzystaj ze znaczników codebox a nie code (po lewej stronie okienka edycji postu jest link "Wstaw: CODEBOX") Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
murgal Napisano Listopad 19, 2009 Autor Zgłoszenie Share Napisano Listopad 19, 2009 Moja karta to nVidia Geforce 8600GT Palit Sonic+ . Okej, na przyszłość będe pamiętał. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lukaszw17 Napisano Listopad 21, 2009 Zgłoszenie Share Napisano Listopad 21, 2009 mam zaistalowany rpmfusion , również zrobiłem yum update i w dalszym ciągu wyskakuje mi że nie ma pakietu o nazwie kmod-nvidia :/ czy ktoś może pomóc ?? # # Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 21, 2009 Zgłoszenie Share Napisano Listopad 21, 2009 @lukaszw17 najpierw "yum update" całego systemu, potem sterowniki. Jak nie zadziała to pokaż co się dzieje wklejając wyjście polecenia yum install kmod-nvidia Oczywiście uwaga jak wcześniej do @murgal: przy długich listingach korzystaj ze znaczników codebox a nie code (po lewej stronie okienka edycji postu jest link "Wstaw: CODEBOX")1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lukaszw17 Napisano Listopad 21, 2009 Zgłoszenie Share Napisano Listopad 21, 2009 jak wpiszę # yum update Wczytane wtyczki: presto, refresh-packagekit Ustawianie procesu aktualizacji Brak pakietów oznaczonych do aktualizacji [root@Lukasz-PC ~]# jak to ma wyglądać mam pierwszy kontakt z Fedorą, wcześniej spotkałem się tylko susem ale mi się nie podobał Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Listopad 21, 2009 Zgłoszenie Share Napisano Listopad 21, 2009 Daj yum install kmod-nvidia --enablerepo=rpmfusion-nonfree-updates-testing Po instalacji mv /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r)-nouveau.img dracut /boot/initramfs-$(uname -r).img $(uname -r) Tu jest podobny temat. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lukaszw17 Napisano Listopad 21, 2009 Zgłoszenie Share Napisano Listopad 21, 2009 wyskakuje mi coś takiego po zainstalowaniu Zainstalowano: kmod-nvidia.i586 0:190.42-1.fc12.4 Zainstalowano zależność: kernel.i686 0:2.6.31.5-127.fc12 kmod-nvidia-2.6.31.5-127.fc12.i686.i586 0:190.42-1.fc12.4 livna-config-display.noarch 0:0.0.23-1.fc11 system-config-display.i686 0:2.2-1.fc12 xorg-x11-drv-nvidia.i686 0:190.42-2.fc12 xorg-x11-drv-nvidia-libs.i686 0:190.42-2.fc12 Ukończono. [root@Lukasz-PC ~]# mv /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r)-nouveau.img [root@Lukasz-PC ~]# dracut /boot/initramfs-$(uname -r).img $(uname -r) W: Possible missing firmware aic94xx-seq.fw for module aic94xx.ko W: Possible missing firmware ql8100_fw.bin for module qla2xxx.ko [root@Lukasz-PC ~]# wszystko jest ok ?? bo czegoś tam brakuje Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Listopad 21, 2009 Zgłoszenie Share Napisano Listopad 21, 2009 Tymi ostrzeżeniami się nie przejmuj. Przejrzyj wątek który Ci podlinkowałem, na wypadek gdyby sterowniki nie chciały działać. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
