Flash Fullscreen - Nie Działa
matlas
Po ostatnich aktualizacjach nie działa mi full screen w flash playerach (ani na youtube, ani inne serwisy z innymi playerami). Po kliknieciu w przycisk full screenu, nic sie nie dzieje a otwarzany fim zmienia sie na szary prostokat. W konsoli (przy uruchomieniu firefox) wypluwa takie cuda:
Gdk-ERROR **: The program 'npviewer.bin' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadLength (poly request too large or internal Xlib length erro'.
  (Details: serial 1473 error_code 16 request_code 135 minor_code 17)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
aborting...
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2344):invoke_NPP_WriteReady: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2394):invoke_NPP_Write: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2239):invoke_NPP_DestroyStream: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:2123):invoke_NPP_URLNotify: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** WARNING:(../src/npw-wrapper.c:1977):invoke_NPP_GetValue: assertion failed: (rpc_method_invoke_possible(plugin->connection))
*** NSPlugin Wrapper *** ERROR: NPObject 0x7fd70729af00 is no longer valid!
Mam 64 bitowy system F12 , sterowniki nvidi. Flash w wersji:
flash-plugin.i386                                      10.0.42.34-release
Wydajesz się być bardziej doświadczonym userem, ale co tam:
* sprawdzałeś testowe aktualizacje?
yum \
   --enablerepo=updates-testing \
   --enablerepo=rpmfusion-free-updates-testing \
   --enablerepo=rpmfusion-nonfree-updates-testing \
   update ...
* sprawdź czy to Ciebie dotyczy:
http://support.mozilla.com/pl/kb/Cannot+vi...en+Flash+videos
* w komunikacie jest, że to raczej bug, więc ostatecznie można albo kompilować nowsze źródełka albo debugować :ph34r:
  • 3 weeks later...
  • 2 weeks later...
