Fedora 12 Brak Wstrzymania I Hibernacji
BogumilH
Witam,
notebook HP Pavilion dv 5 1110 ew. Komputer nie wchodzi w stan wstrzymania.
Log z komendy pm-suspend:
Initial commandline parameters:
wto, 2 mar 2010, 22:33:43 CET: Running hooks for suspend.
/usr/lib/pm-utils/sleep.d/00auto-quirk suspend suspend: Adding quirks from HAL: --quirk-dpms-on --quirk-dpms-suspend --quirk-vbe-post --quirk-vbemode-restore --quirk-vbestate-restore --quirk-vga-mode-3
success.
/usr/lib/pm-utils/sleep.d/00logging suspend suspend: Linux bogus-laptop 2.6.31.12-174.2.22.fc12.i686 #1 SMP Fri Feb 19 19:26:06 UTC 2010 i686 i686 i386 GNU/Linux
Module                  Size  Used by
michael_mic             2144  8
arc4                    1616  4
ecb                     2492  4
vfat                    8744  1
fat                    41836  1 vfat
fuse                   52740  2
rfcomm                 58236  4
sco                    16184  2
bridge                 43992  0
stp                     1988  1 bridge
llc                     4960  2 bridge,stp
bnep                   15028  2
l2cap                  32564  16 rfcomm,bnep
cpufreq_ondemand        6160  2
acpi_cpufreq            8848  0
ip6t_REJECT             4620  2
nf_conntrack_ipv6      17564  2
ip6table_filter         3168  1
ip6_tables             11144  1 ip6table_filter
ipv6                  239484  24 ip6t_REJECT,nf_conntrack_ipv6
dm_multipath           14472  0
uinput                  6852  0
snd_hda_codec_idt      53136  1
snd_hda_intel          25096  2
snd_hda_codec          60584  2 snd_hda_codec_idt,snd_hda_intel
nvidia               8871820  41
snd_hwdep               6900  1 snd_hda_codec
snd_seq                46960  0
snd_seq_device          6232  1 snd_seq
snd_pcm                64772  2 snd_hda_intel,snd_hda_codec
snd_timer              17992  2 snd_seq,snd_pcm
uvcvideo               51116  0
snd                    50908  12 snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_seq,snd_seq_device,s
nd_pcm,snd_timer
videodev               30160  1 uvcvideo
soundcore               5672  1 snd
mmc_block               9540  2
v4l1_compat            12164  2 uvcvideo,videodev
btusb                  15032  2
bluetooth              78336  9 rfcomm,sco,bnep,l2cap,btusb
rfkill                 16220  2 bluetooth
sdhci_pci               7140  0
sdhci                  17408  1 sdhci_pci
mmc_core               48640  2 mmc_block,sdhci
firewire_ohci          19516  0
firewire_core          39632  1 firewire_ohci
crc_itu_t               1620  1 firewire_core
hp_accel               11112  0
lis3lv02d               6448  1 hp_accel
input_polldev           3236  1 lis3lv02d
lirc_ene0100            7620  0
lirc_dev               14672  1 lirc_ene0100
iTCO_wdt               10432  0
iTCO_vendor_support     2812  1 iTCO_wdt
r8169                  28340  0
mii                     4120  1 r8169
lib80211_crypt_tkip     8176  0
snd_page_alloc          7832  2 snd_hda_intel,snd_pcm
jmb38x_ms              12088  0
memstick                9384  1 jmb38x_ms
wmi                     5952  0
joydev                  9320  0
wl                   1272524  0
i2c_i801               10284  0
i2c_core               23392  3 nvidia,videodev,i2c_i801
lib80211                5128  2 lib80211_crypt_tkip,wl
video                  19088  0
output                  2468  1 video
             total       used       free     shared    buffers     cached
Mem:       2060056     720192    1339864          0      33552     369216
-/+ buffers/cache:     317424    1742632
Swap:      2047988          0    2047988
success.
/usr/lib/pm-utils/sleep.d/00powersave suspend suspend: success.
/usr/lib/pm-utils/sleep.d/01grub suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/10-dhclient suspend suspend: success.
/usr/lib/pm-utils/sleep.d/49bluetooth suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/55NetworkManager suspend suspend: success.
/usr/lib/pm-utils/sleep.d/56atd suspend suspend: success.
/usr/lib/pm-utils/sleep.d/75modules suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/90clock suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/94cpufreq suspend suspend: success.
/usr/lib/pm-utils/sleep.d/95led suspend suspend: not applicable.
/usr/lib/pm-utils/sleep.d/95packagekit suspend suspend: success.
/usr/lib/pm-utils/sleep.d/98smart-kernel-video suspend suspend: success.
/usr/lib/pm-utils/sleep.d/99hd-apm-restore.hook suspend suspend: saving level 128 for device sda
success.
/usr/lib/pm-utils/sleep.d/99video suspend suspend: kernel.acpi_video_flags = 0
success.
wto, 2 mar 2010, 22:33:46 CET: performing suspend
W Ubuntu 9.04 działało w 9.10 nie.
Bardzo proszę o pomoc.
$ gunzip -c /proc/config.gz | grep -i acpi
# Power management and ACPI options
CONFIG_ACPI=y
CONFIG_ACPI_SLEEP=y
# CONFIG_ACPI_PROCFS is not set
# CONFIG_ACPI_PROCFS_POWER is not set
CONFIG_ACPI_SYSFS_POWER=y
# CONFIG_ACPI_PROC_EVENT is not set
# CONFIG_ACPI_AC is not set
# CONFIG_ACPI_BATTERY is not set
CONFIG_ACPI_BUTTON=y
CONFIG_ACPI_VIDEO=m
CONFIG_ACPI_FAN=y
CONFIG_ACPI_DOCK=y
CONFIG_ACPI_PROCESSOR=y
CONFIG_ACPI_THERMAL=y
# CONFIG_ACPI_CUSTOM_DSDT is not set
CONFIG_ACPI_BLACKLIST_YEAR=1999
# CONFIG_ACPI_DEBUG is not set
CONFIG_ACPI_PCI_SLOT=m
# CONFIG_ACPI_CONTAINER is not set
# CONFIG_ACPI_SBS is not set
# CONFIG_X86_ACPI_CPUFREQ is not set
CONFIG_X86_POWERNOW_K7_ACPI=y
CONFIG_PNPACPI=y
CONFIG_ATA_ACPI=y
# CONFIG_PATA_ACPI is not set
Zdaje się że w jądrze to "CONFIG_ACPI_SLEEP=y" odpowiada za hibernację i usypianie. Czyli musiałbyś chyba kompilować jądro. Ale nie zdziw się jeśli na 9.10 i tak się coś zwiesi. U mnie np. na Fedorze czasem się zwiesza po usypianiu a czasem nie... więc nie używam.
PS. To jest forum Fedory a nie Ubuntu;), choć wiem że fora Fedora i Ubuntu bywają wzajemnie pomocne.
No to tak, poszukałem w Wiki dodałem sobie repo z TuxOneIce zainstalował mi się nowy kernel wszystko cacy tylko X-y padły, sterownik od Nvidi się nie ładuje. A ja w przeciwieństwie do panów z Sexmisji "białość widzę".
Tryb tekstowy działa, z klawiatury wywołałem uśpienie , ale reakcja kompa taka jak wcześniej- czyli nic.
Jakieś inne pomysły?
1. Jak włączasz tego Tuxonice?
2. Ile masz swapa?
3. Poczytaj więcej Wiki i for tegoż programu gdzieś powinno być rozwiązanie. Najlepiej zacznij od logów. (podpowiedź: Jeżeli problemem jest nvidia, a wygląda na to, że jest, to musisz te stery zblacklistować) ;)
Heh wszystko łopatą trzeba... <_<
No niestety większości trzeba. W tym także Tobie o ile sobie dobrze przypominam. Jeśli już coś piszesz to w miarę konkretnie, a nie na zasadzie znajdź coś w repo czego tak naprawdę w nim nie ma.
@BogumilH zbuduj moduł dla nvidii na nowym jądrze, czyli zastąp kmod-nvidia pakietem akmod-nvidia (potrzebujesz kernel-devel) i uruchom go. Czuję, że z tym jądrem będziesz miał same problemy.
...poszukałem w Wiki dodałem sobie repo z TuxOneIce zainstalował mi się...
Dalej jesteś pewny, że takiego czegoś w repo nie ma?
Skoro mu działają stery na tym jądrze to chyba ta porada nic nie pomoże.
Dzięki wszystkim za pomoc, uciekłem z powrotem do Ubuntu 9.04. Z racji posiadania 5 miesięcznego syna mogę zapomnieć o czasach kiedy sobie kombinowałem , grzebałem, psułem itd. :(
Teraz muszę uśpić system-zmienić pieluchę-wzbudzić system.
Wrócę to tematu jak czas pozwoli.
Bogumił
