Medion Ctx925 Tv Analog, Dvb-t, Dvb-s Uruchamia Się Po Restarcie
MGo
Karta jak w temacie w slocie Dual-PCI. Przy pierwszym starcie (z wyłączonego komputera) - nie działa. Robię restart - zaczyna działać:
Zjawisko jest powtarzalne.
Porównałem dmesg:
Time: 16:12:01  Date: 03/18/10				      |	Time: 16:17:10  Date: 03/18/10
saa7134[0]: subsystem: 16be:0003, board: Medion 7134 [card=12 |	saa7134[0]: subsystem: 00be:0003, board: Medion 7134 [card=12
ppdev: user-space parallel port driver			      |	saa7134[0]: i2c eeprom 00: 80 16 00 00 10 00 04 00 40 01 80 1
saa7134[0]: i2c eeprom 00: be 16 03 00 54 20 1c 00 43 43 a9 1 |	saa7134[0]: i2c eeprom 10: 00 7f 86 00 ab 00 a0 00 00 10 30 0
saa7134[0]: i2c eeprom 10: 00 ff 86 0f ff 20 ff 00 01 50 32 7 |	saa7134[0]: i2c eeprom 20: 00 40 00 00 00 00 01 00 00 3c 00 1
saa7134[0]: i2c eeprom 20: 01 40 01 02 02 03 01 00 06 ff 00 1 |	saa7134[0]: i2c eeprom 30: a2 58 78 18 02 8c 80 00 02 50 00 3
saa7134[0]: i2c eeprom 30: a7 58 7a 1f 03 8e 84 5e da 7a 04 b |	saa7134[0]: i2c eeprom 40: 56 1c 00 02 06 00 01 01 00 00 00 0
saa7134[0]: i2c eeprom 40: ff 1d 00 c2 86 10 01 01 00 00 fd 7 |	saa7134[0]: i2c eeprom 50: d3 d4 b8 13 04 77 00 06 0c 00 00 0
saa7134[0]: i2c eeprom 50: ff ff ff ff ff ff 06 06 0f 00 0f 0 |	saa7134[0]: i2c eeprom 60: 20 d4 b8 12 00 c2 fd 80 bb 51 30 7
saa7134[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom 70: d6 5e 1a 7d 00 86 b9 5e 1b fa 00 8
saa7134[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom 80: e9 f0 00 8c b9 50 76 50 10 20 ab d
saa7134[0]: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom 90: 02 d4 bc 12 00 d4 b8 14 13 83 fa f
saa7134[0]: i2c eeprom 90: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom a0: e0 00 00 50 71 d4 b8 11 28 50 41 d
saa7134[0]: i2c eeprom a0: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom b0: e0 51 10 d4 b8 14 13 83 fa ff fe 5
saa7134[0]: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom c0: 00 50 b2 d4 b8 11 28 96 bc 8c c0 0
saa7134[0]: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom d0: b8 11 28 67 d0 d4 bc 11 28 d4 b8 1
saa7134[0]: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom e0: 1f 58 1a 8d e0 00 80 50 52 d4 b8 1
saa7134[0]: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff f |	saa7134[0]: i2c eeprom f0: 00 50 40 d4 b8 12 04 81 fa 20 00 d
saa7134[0]: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff f <
saa7134[0] Board has DVB-T				      |	saa7134[0] Cant determine tuner type 1000 from EEPROM
						      >	tuner 3-0043: chip found @ 0x86 (saa7134[0])
						      >	tda9887 3-0043: creating new instance
						      >	tda9887 3-0043: tda988[5/6/7] found
saa7134[1]: board init: gpio is 0			      |	saa7134[1]: board init: gpio is 510006
Działa wtedy, gdy dmesg jest jak ten w prawej kolumnie. Jak umożliwić start karty bez restartu?
/etc/modprobe.d/saa7134.conf:
alias char-major-81 videodev
alias char-major-81-0 saa7134
alias char-major-81-1 saa7134
options saa7134 radio_nr=0 card=12,93 tuner=63 gbuffers=4
Może wystarczy przeładować moduł, czyli rmmod nazwa_modułu i modprobe nazwa_modułu .
Po przeładowaniu karta działa.
Ale po odpaleniu X-ów:
[root@k5 ~]# rmmod saa7134_alsa
ERROR: Module saa7134_alsa is in use
Trzeba ręcznie wyłączyć 2 urządzenia karty SAA7134 w preferencjach dźwięku - wtedy można przeładować. Potem włączyć ponownie.
Jak to zrobić automatycznie przy starcie? Do którego pliku wpisać polecenie przeładowania, aby moduł saa7134_alsa nie był zablokowany?
Do przeładowania są moduły saa7134, saa7134_dvb i saa7134_alsa.
EDIT
Stworzyłem plik /etc/init.d/saa7134
#!/bin/sh
#   saa7134 workaround
#   Linux chkconfig stuff:
#   chkconfig: 2345 25 10
#   description: saa7134 workaround.
# Linux
### BEGIN INIT INFO
# Provides: saa7134 workaround
# Required-Start:
# Required-Stop:
# Should-Start:
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: saa7134 workaround
# Description: saa7134 workaround
### END INIT INFO
start () {
   /sbin/rmmod saa7134_alsa saa7134_dvb saa7134  2>&1 > /dev/null
   echo "Przeładowywanie SAA7134"
   RETVAL=$?
   /bin/sleep 1
   /sbin/modprobe saa7134  2>&1 > /dev/null
return $RETVAL
case $1 in
start)
	start
stop)
echo $"Usage: $prog {start|stop}"
exit 2
esac
exit $RETVAL
... i już działa.
