donEscopeta Napisano Sierpień 8, 2010 Zgłoszenie Share Napisano Sierpień 8, 2010 Jak w temacie. Problem ten jest w h#$ uciążliwy ponieważ trzeba 5 - 6 razy uruchamiać fedore. Sterownik instalowałem w sposób z http://rpmfusion.org/Howto/nVidia#head-b52...c75f8d7e37c9e2b z tym żę urzyłem tych ze strony nvidiii. Mój xorg.comf: # nvidia-settings: X configuration file generated by nvidia-settings # nvidia-settings: version 256.44 ([email protected]) Thu Jul 29 01:59:48 PDT 2010 # nvidia-xconfig: X configuration file generated by nvidia-xconfig # nvidia-xconfig: version 256.44 ([email protected]) Thu Jul 29 02:00:07 PDT 2010 Section "ServerLayout" Identifier "Layout0" Screen 0 "Screen0" 0 0 InputDevice "Keyboard0" "CoreKeyboard" InputDevice "Mouse0" "CorePointer" Option "Xinerama" "0" EndSection Section "Files" FontPath "/usr/share/fonts/default/Type1" EndSection Section "InputDevice" # generated from default Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" Option "Emulate3Buttons" "no" Option "ZAxisMapping" "4 5" EndSection Section "InputDevice" # generated from default Identifier "Keyboard0" Driver "kbd" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Unknown" ModelName "Maxdata/Belinea Belinea101920" HorizSync 31.0 - 83.0 VertRefresh 56.0 - 75.0 Option "DPMS" EndSection Section "Device" Identifier "Device0" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "GeForce 9400 GT" EndSection Section "Screen" Identifier "Screen0" Device "Device0" Monitor "Monitor0" DefaultDepth 24 Option "TwinView" "1" Option "TwinViewXineramaInfoOrder" "DFP-0" Option "metamodes" "CRT: 1280x1024 +0+0, DFP: 1920x1200 +1280+0" SubSection "Display" Depth 24 EndSubSection EndSection A oto log: [ 33.901] X.Org X Server 1.8.2 Release Date: 2010-07-01 [ 33.901] X Protocol Version 11, Revision 0 [ 33.901] Build Operating System: x86-20 2.6.32-44.el6.x86_64 [ 33.901] Current Operating System: Linux MateuszFedora 2.6.33.6-147.2.4.fc13.i686.PAE #1 SMP Fri Jul 23 17:21:06 UTC 2010 i686 [ 33.901] Kernel command line: ro root=UUID=2d2158be-cf17-4b62-9561-adb7d8cfe7c4 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=pl_PL.UTF-8 SYSFONT=latarcyrheb-sun16 KEYTABLE=pl2 rhgb quiet vga=792 rdblacklist=nouveau nomodeset [ 33.901] Build Date: 20 July 2010 02:11:10AM [ 33.901] Build ID: xorg-x11-server 1.8.2-2.fc13 [ 33.901] Current version of pixman: 0.18.0 [ 33.901] Before reporting problems, check http://bodhi.fedoraproject.org/ to make sure that you have the latest version. [ 33.901] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 33.901] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Aug 8 10:27:43 2010 [ 33.901] (==) Using config file: "/etc/X11/xorg.conf" [ 33.901] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 33.901] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 33.902] (==) ServerLayout "Layout0" [ 33.902] (**) |-->Screen "Screen0" (0) [ 33.902] (**) | |-->Monitor "Monitor0" [ 33.902] (**) | |-->Device "Device0" [ 33.902] (**) |-->Input Device "Keyboard0" [ 33.902] (**) |-->Input Device "Mouse0" [ 33.902] (**) Option "Xinerama" "0" [ 33.902] (==) Automatically adding devices [ 33.902] (==) Automatically enabling devices [ 33.902] (**) FontPath set to: /usr/share/fonts/default/Type1, catalogue:/etc/X11/fontpath.d, built-ins [ 33.902] (==) ModulePath set to "/usr/lib/xorg/modules" [ 33.902] (WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled. [ 33.902] (WW) Disabling Keyboard0 [ 33.902] (WW) Disabling Mouse0 [ 33.902] (II) Loader magic: 0x82220e0 [ 33.902] (II) Module ABI versions: [ 33.902] X.Org ANSI C Emulation: 0.4 [ 33.902] X.Org Video Driver: 7.0 [ 33.902] X.Org XInput driver : 9.0 [ 33.902] X.Org Server Extension : 3.0 [ 33.910] (--) PCI: (0:1:6:0) 109e:036e:1822:0001 Brooktree Corporation Bt878 Video Capture rev 17, Mem @ 0xd6100000/4096, BIOS @ 0x????????/65536 [ 33.916] (--) PCI:*(0:2:0:0) 10de:0641:1043:82be nVidia Corporation G96 [GeForce 9400 GT] rev 161, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000b000/128, BIOS @ 0x????????/524288 [ 33.916] (II) LoadModule: "extmod" [ 33.917] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so [ 33.917] (II) Module extmod: vendor="X.Org Foundation" [ 33.917] compiled for 1.8.2, module version = 1.0.0 [ 33.917] Module class: X.Org Server Extension [ 33.917] ABI class: X.Org Server Extension, version 3.0 [ 33.917] (II) Loading extension SELinux [ 33.917] (II) Loading extension MIT-SCREEN-SAVER [ 33.917] (II) Loading extension XFree86-VidModeExtension [ 33.917] (II) Loading extension XFree86-DGA [ 33.917] (II) Loading extension DPMS [ 33.917] (II) Loading extension XVideo [ 33.917] (II) Loading extension XVideo-MotionCompensation [ 33.917] (II) Loading extension X-Resource [ 33.917] (II) LoadModule: "dbe" [ 33.917] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so [ 33.917] (II) Module dbe: vendor="X.Org Foundation" [ 33.917] compiled for 1.8.2, module version = 1.0.0 [ 33.917] Module class: X.Org Server Extension [ 33.917] ABI class: X.Org Server Extension, version 3.0 [ 33.917] (II) Loading extension DOUBLE-BUFFER [ 33.917] (II) LoadModule: "glx" [ 33.917] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 33.923] (II) Module glx: vendor="NVIDIA Corporation" [ 33.923] compiled for 4.0.2, module version = 1.0.0 [ 33.923] Module class: X.Org Server Extension [ 33.923] (II) NVIDIA GLX Module 256.44 Thu Jul 29 01:55:11 PDT 2010 [ 33.924] (II) Loading extension GLX [ 33.924] (II) LoadModule: "record" [ 33.924] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so [ 33.924] (II) Module record: vendor="X.Org Foundation" [ 33.924] compiled for 1.8.2, module version = 1.13.0 [ 33.924] Module class: X.Org Server Extension [ 33.924] ABI class: X.Org Server Extension, version 3.0 [ 33.924] (II) Loading extension RECORD [ 33.924] (II) LoadModule: "dri" [ 33.924] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so [ 33.924] (II) Module dri: vendor="X.Org Foundation" [ 33.924] compiled for 1.8.2, module version = 1.0.0 [ 33.924] ABI class: X.Org Server Extension, version 3.0 [ 33.924] (II) Loading extension XFree86-DRI [ 33.924] (II) LoadModule: "dri2" [ 33.924] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so [ 33.924] (II) Module dri2: vendor="X.Org Foundation" [ 33.924] compiled for 1.8.2, module version = 1.2.0 [ 33.924] ABI class: X.Org Server Extension, version 3.0 [ 33.924] (II) Loading extension DRI2 [ 33.924] (II) LoadModule: "nvidia" [ 33.925] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so [ 33.925] (II) Module nvidia: vendor="NVIDIA Corporation" [ 33.925] compiled for 4.0.2, module version = 1.0.0 [ 33.925] Module class: X.Org Video Driver [ 33.925] (II) NVIDIA dlloader X Driver 256.44 Thu Jul 29 01:32:42 PDT 2010 [ 33.925] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs [ 33.925] (--) using VT number 7 [ 33.947] (II) Primary Device is: PCI 02@00:00:0 [ 33.947] (II) Loading sub module "fb" [ 33.947] (II) LoadModule: "fb" [ 33.947] (II) Loading /usr/lib/xorg/modules/libfb.so [ 33.947] (II) Module fb: vendor="X.Org Foundation" [ 33.947] compiled for 1.8.2, module version = 1.0.0 [ 33.947] ABI class: X.Org ANSI C Emulation, version 0.4 [ 33.948] (II) Loading sub module "wfb" [ 33.948] (II) LoadModule: "wfb" [ 33.948] (II) Loading /usr/lib/xorg/modules/libwfb.so [ 33.948] (II) Module wfb: vendor="X.Org Foundation" [ 33.948] compiled for 1.8.2, module version = 1.0.0 [ 33.948] ABI class: X.Org ANSI C Emulation, version 0.4 [ 33.948] (II) Loading sub module "ramdac" [ 33.948] (II) LoadModule: "ramdac" [ 33.948] (II) Module "ramdac" already built-in [ 33.948] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32 [ 33.948] (==) NVIDIA(0): RGB weight 888 [ 33.948] (==) NVIDIA(0): Default visual is TrueColor [ 33.948] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0) [ 33.948] (**) NVIDIA(0): Option "TwinView" "1" [ 33.948] (**) NVIDIA(0): Option "MetaModes" "CRT: 1280x1024 +0+0, DFP: 1920x1200 +1280+0" [ 33.948] (**) NVIDIA(0): Option "TwinViewXineramaInfoOrder" "DFP-0" [ 33.948] (**) NVIDIA(0): Enabling RENDER acceleration [ 33.948] (II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is [ 33.948] (II) NVIDIA(0): enabled. [ 34.150] (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device PCI:2:0:0. [ 34.150] (EE) NVIDIA(0): Please check your system's kernel log for additional error [ 34.150] (EE) NVIDIA(0): messages and refer to Chapter 8: Common Problems in the [ 34.150] (EE) NVIDIA(0): README for additional information. [ 34.150] (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device! [ 34.150] (II) UnloadModule: "nvidia" [ 34.150] (II) UnloadModule: "wfb" [ 34.150] (II) UnloadModule: "fb" [ 34.150] (EE) Screen(s) found, but none have a usable configuration. [ 34.150] Fatal server error: [ 34.150] no screens found [ 34.150] Please consult the Fedora Project support at http://bodhi.fedoraproject.org/ for help. [ 34.150] Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 34.150] Dzięki za każdą odpowieć Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Sierpień 8, 2010 Zgłoszenie Share Napisano Sierpień 8, 2010 Usuń nomodeset z opcji kernela w grub.conf Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
donEscopeta Napisano Sierpień 8, 2010 Autor Zgłoszenie Share Napisano Sierpień 8, 2010 Niestety nie pomogło Zauważyłem że ilość prób zmniejszyła się do 1-2 ale chyba to przypadek. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 9, 2010 Zgłoszenie Share Napisano Sierpień 9, 2010 Dzięki za każdą odpowieć odpowiedź. Ja działam na nieprzebudowanym initramfs i jest OK. Poza tym usuń (zmień nazwę) xorg.conf i zobacz jak pójdzie bez tego na domyślnej konfiguracji systemowej. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
