slabypingwin Napisano Październik 8, 2011 Zgłoszenie Share Napisano Październik 8, 2011 (edytowane) Dzis pojawil sie pakiet KMOD-NVIDIA ale nie mozna go zainstalowac ; [darek@localhost ~]$ sudo yum install kmod-nvidia [sudo] password for darek: Loaded plugins: langpacks, presto, refresh-packagekit Setting up Install Process Resolving Dependencies --> Running transaction check ---> Package kmod-nvidia.i686 1:285.05.09-1.fc16 will be installed --> Processing Dependency: akmod-nvidia = 1:285.05.09-1.fc16 for package: 1:kmod-nvidia-285.05.09-1.fc16.i686 --> Running transaction check ---> Package akmod-nvidia.i686 1:285.05.09-1.fc16 will be installed --> Processing Dependency: nvidia-kmod-common >= 1:285.05.09 for package: 1:akmod-nvidia-285.05.09-1.fc16.i686 --> Processing Dependency: akmods for package: 1:akmod-nvidia-285.05.09-1.fc16.i686 --> Processing Dependency: kmodtool for package: 1:akmod-nvidia-285.05.09-1.fc16.i686 --> Running transaction check ---> Package akmods.noarch 0:0.3.7-1.fc16 will be installed --> Processing Dependency: rpm-build for package: akmods-0.3.7-1.fc16.noarch --> Processing Dependency: kernel-devel for package: akmods-0.3.7-1.fc16.noarch --> Processing Dependency: /usr/bin/rpmdev-vercmp for package: akmods-0.3.7-1.fc16.noarch ---> Package kmodtool.noarch 0:1-18.fc11 will be installed ---> Package xorg-x11-drv-nvidia.i686 1:285.05.09-1.fc16 will be installed --> Processing Dependency: xorg-x11-drv-nvidia-libs(x86-32) = 1:285.05.09-1.fc16 for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 --> Processing Dependency: nvidia-settings for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 --> Processing Dependency: nvidia-xconfig for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 --> Running transaction check ---> Package kernel-devel.i686 0:3.1.0-0.rc8.git0.1.fc16 will be installed ---> Package rpm-build.i686 0:4.9.1.2-1.fc16 will be installed --> Processing Dependency: patch >= 2.5 for package: rpm-build-4.9.1.2-1.fc16.i686 ---> Package rpmdevtools.noarch 0:8.1-1.fc15 will be installed --> Processing Dependency: emacs-filesystem for package: rpmdevtools-8.1-1.fc15.noarch --> Processing Dependency: fakeroot for package: rpmdevtools-8.1-1.fc15.noarch --> Processing Dependency: xemacs-filesystem for package: rpmdevtools-8.1-1.fc15.noarch ---> Package xorg-x11-drv-nvidia.i686 1:285.05.09-1.fc16 will be installed --> Processing Dependency: nvidia-settings for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 --> Processing Dependency: nvidia-xconfig for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 ---> Package xorg-x11-drv-nvidia-libs.i686 1:285.05.09-1.fc16 will be installed --> Running transaction check ---> Package emacs-filesystem.i686 1:23.3-7.fc16 will be installed ---> Package fakeroot.i686 0:1.12.4-3.fc15 will be installed --> Processing Dependency: fakeroot-libs = 1.12.4-3.fc15 for package: fakeroot-1.12.4-3.fc15.i686 ---> Package patch.i686 0:2.6.1-9.fc16 will be installed ---> Package xemacs-filesystem.noarch 0:21.5.31-2.fc16 will be installed ---> Package xorg-x11-drv-nvidia.i686 1:285.05.09-1.fc16 will be installed --> Processing Dependency: nvidia-settings for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 --> Processing Dependency: nvidia-xconfig for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 --> Running transaction check ---> Package fakeroot-libs.i686 0:1.12.4-3.fc15 will be installed ---> Package xorg-x11-drv-nvidia.i686 1:285.05.09-1.fc16 will be installed --> Processing Dependency: nvidia-settings for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 --> Processing Dependency: nvidia-xconfig for package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 --> Finished Dependency Resolution Error: Package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 (rpmfusion-nonfree-rawhide) Requires: nvidia-xconfig Error: Package: 1:xorg-x11-drv-nvidia-285.05.09-1.fc16.i686 (rpmfusion-nonfree-rawhide) Requires: nvidia-settings You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest [darek@localhost ~]$ Skad mamam mu wziac te rózne nvidia-xconfig i xsettings i inee zaleznosci Edytowane Październik 8, 2011 przez WalDo Znaczniki codebox 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alkuzad Napisano Październik 8, 2011 Zgłoszenie Share Napisano Październik 8, 2011 @slaby czy do ciebie kiedykolwiek dotrze znaczenie słowa RAWHIDE ? 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Październik 8, 2011 Zgłoszenie Share Napisano Październik 8, 2011 Skąd mamam mu wziąć te różne nvidia-xconfig i xsettings i inee zależności To jest wersja beta systemu (i sterowników też), czyli wersja w fazie testów. Zgłoś błąd i czekaj na poprawkę. Przy okazji: Długie listingi proszę umieszczać w znacznikach "codebox" a nie "code". A i całej listy update'ów systemu też nie musisz wklejać jeśli problem masz tylko z jednym pakietem. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
takori Napisano Październik 9, 2011 Autor Zgłoszenie Share Napisano Październik 9, 2011 old-style Gnome W związku z powracającym pytaniem podaję link. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
takori Napisano Październik 11, 2011 Autor Zgłoszenie Share Napisano Październik 11, 2011 (edytowane) Rpm gtk3-unico-engine-1.0.1-1 ** Jest to badz wersja 32 bitowa, lub jest jakis bug. Dla chcacych skompilowac samemu - instrukcja na blogu Murphy'a. Edytowane Październik 11, 2011 przez takori Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
