Mentat Napisano Luty 8, 2012 Zgłoszenie Share Napisano Luty 8, 2012 Pokaż jak wygląda Twój /etc/selinux/config. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adampzb Napisano Luty 8, 2012 Autor Zgłoszenie Share Napisano Luty 8, 2012 nie wiem tez czemu bierze tak duzo procesora przy normalym uzytkowaniu http://imageshack.us/photo/my-images/138/zrzutekranu2t.png # This file controls the state of SELinux on the system. # SELINUX= can take one of these three values: # enforcing - SELinux security policy is enforced. # permissive - SELinux prints warnings instead of enforcing. # disabled - No SELinux policy is loaded. SELINUX=enforcing # SELINUXTYPE= can take one of these two values: # targeted - Targeted processes are protected, # mls - Multi Level Security protection. SELINUXTYPE=targeted edit ten monitor chyba zle pokazuje top - 23:17:18 up 1:29, 2 users, load average: 1.12, 1.52, 1.44 Tasks: 168 total, 2 running, 165 sleeping, 1 stopped, 0 zombie Cpu(s): 20.9%us, 33.2%sy, 0.0%ni, 45.9%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st Mem: 2060596k total, 1444116k used, 616480k free, 34964k buffers Swap: 4128764k total, 244k used, 4128520k free, 825432k cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 19227 root 20 0 5700 1468 1112 R 98.8 0.1 19:04.83 top 19755 adam 20 0 149m 23m 17m S 4.0 1.2 0:02.84 konsole 1106 root 20 0 86024 39m 16m S 2.7 2.0 5:21.76 X 3 root 20 0 0 0 0 S 1.0 0.0 0:04.39 ksoftirqd/0 19717 root 20 0 0 0 0 S 0.7 0.0 0:00.16 kworker/u:0 19830 adam 20 0 5700 1460 1112 R 0.7 0.1 0:00.61 top 1707 adam 20 0 831m 172m 37m S 0.3 8.6 16:51.75 firefox 1 root 20 0 17336 14m 1672 S 0.0 0.7 0:02.77 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd 6 root RT 0 0 0 0 S 0.0 0.0 61:03.02 migration/0 7 root RT 0 0 0 0 S 0.0 0.0 0:00.04 watchdog/0 8 root RT 0 0 0 0 S 0.0 0.0 68:39.23 migration/1 10 root 20 0 0 0 0 S 0.0 0.0 0:04.96 ksoftirqd/1 12 root RT 0 0 0 0 S 0.0 0.0 0:00.04 watchdog/1 13 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 cpuset 14 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper 15 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs 16 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns 17 root 20 0 0 0 0 S 0.0 0.0 0:00.01 sync_supers Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Mentat Napisano Luty 8, 2012 Zgłoszenie Share Napisano Luty 8, 2012 nie wiem tez czemu bierze tak duzo procesora przy normalym uzytkowaniu http://imageshack.us...zutekranu2t.png W KDE jest skrót Ctrl+Esc do managera zadań. # This file controls the state of SELinux on the system. # SELINUX= can take one of these three values: # enforcing - SELinux security policy is enforced. # permissive - SELinux prints warnings instead of enforcing. # disabled - No SELinux policy is loaded. SELINUX=enforcing # SELINUXTYPE= can take one of these two values: # targeted - Targeted processes are protected, # mls - Multi Level Security protection. SELINUXTYPE=targeted Czyli jednak nie wyłączyłeś. Zmień na SELINUX=disabled i zrestartuj. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adampzb Napisano Luty 8, 2012 Autor Zgłoszenie Share Napisano Luty 8, 2012 ehh # service httpd start Starting httpd (via systemctl): Job failed. See system logs and 'systemctl status' for details. [NIEUDANE] moze to wina nowego kernela mam wersje 3.2.3.2 albo kde 4.7.4 nie wiem... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Mentat Napisano Luty 8, 2012 Zgłoszenie Share Napisano Luty 8, 2012 moze to wina nowego kernela mam wersje 3.2.3.2 albo kde 4.7.4 nie wiem... Mam te same wersje i nie mam problemów. Zrób te testy dysku o których mówił WalDo i przetestuj też pamięć (chyba była taka opcja na płytkach instalacyjnych - memtest). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adampzb Napisano Luty 8, 2012 Autor Zgłoszenie Share Napisano Luty 8, 2012 jesli chodzi o touch to juz sie zrobilo jak wylaczylem selinuxa. jak juz nie ma innej opcji to przeinstaluje system bo juz sam sie zaczalem filmowac tym zuzyciem ramu a poza tym caly czas dokucza mi ten blad 'process was killed by signal 11 a nigdzie nie moge znalesc iinformacji jak to naprawic wiec chyba i tak bede musial reinstalowac ;/... juz 3 raz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 9, 2012 Zgłoszenie Share Napisano Luty 9, 2012 jesli chodzi o touch to juz sie zrobilo jak wylaczylem selinuxa."touch" należy wykonać dopiero w momencie, kiedy SElinux jest włączony. Następnie trzeba zrestartować system. Na podstawie daty ostatniego dostępu do pliku /.autorelabel (ustawionej poleceniem touch) system wie, że powinien wykonać ponowne etykietowanie plików a to niezależnie od wielkości i ilości zainstalowanych plików nie trawa kilka sekund. jak juz nie ma innej opcji to przeinstaluje system To jest dobra opcja wobec tylu błędów i wobec faktu, że system masz świeżo postawiony, więc straty nie będą wielkie.Nie dodawaj żadnych repozytoriów poza RPMFusion i będzie OK. A swoją drogą nadal proponuję sprawdzić czy nie ma uszkodzonych sektorów na dysku. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adampzb Napisano Luty 9, 2012 Autor Zgłoszenie Share Napisano Luty 9, 2012 @waldo ale mi sie wydaje ze wlasnie jak zmienileem plik config i zresetowalem kompa jak pisal mentat poczas uruchamiania bylo cos takiego jak 'nadawanie znaczneia plikom selinux moze to potrwac ilestam w zaleznosci od wielkosci i szybkosci dysku' wnioskuje ze to to co kazales wykonac nie wiem czemu zaskoczylo gdy wylaczylem selinux trwalo okolo 10 min. # This file controls the state of SELinux on the system. # SELINUX= can take one of these three values: # enforcing - SELinux security policy is enforced. # permissive - SELinux prints warnings instead of enforcing. # disabled - No SELinux policy is loaded. SELINUX=disabled # SELINUXTYPE= can take one of these two values: # targeted - Targeted processes are protected, # mls - Multi Level Security protection. SELINUXTYPE=targeted samo przeinstalowanie to zaden problem tylko nie chcialem tero robic z tego wzgledy ze to juz bedzie chyba 3 raz w okresie tygodnia i znow bede musial robic wszystkie aktualizacje, konfigurowac system itp... ;/ inne repozytoria dodawalem tylko dlatego ze nie moglem na wiki znalesc jakiegos poradnika jak to zrobic wiec skorzystalem z innego... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adampzb Napisano Luty 9, 2012 Autor Zgłoszenie Share Napisano Luty 9, 2012 wlaczylem znow selinuxa bo podobno bardzo polepsza bezpieczenstwo i nie wiem czy automatycznie touch sie zrobil ale nie dawalem polecenia w terminalu a zrobilo sie. i w sumie to tyle bo nic sie nie zmienilo... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@jszubiak Napisano Luty 9, 2012 Zgłoszenie Share Napisano Luty 9, 2012 Hej, Zapodaj prosze: netstat -nltp systemctl restart httpd.service tail /var/log/httpd/error_log Pozdr. J.Sz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adampzb Napisano Luty 9, 2012 Autor Zgłoszenie Share Napisano Luty 9, 2012 # netstat -nltp Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 1121/rpcbind tcp 0 0 0.0.0.0:51413 0.0.0.0:* LISTEN 2196/transmission-g tcp 0 0 192.168.122.1:53 0.0.0.0:* LISTEN 1223/dnsmasq tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1111/sshd tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 1902/cupsd tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 2082/sendmail tcp 0 0 0.0.0.0:51420 0.0.0.0:* LISTEN 1141/rpc.statd tcp 0 0 :::111 :::* LISTEN 1121/rpcbind tcp 0 0 :::51413 :::* LISTEN 2196/transmission-g tcp 0 0 :::22 :::* LISTEN 1111/sshd tcp 0 0 :::52503 :::* LISTEN 1141/rpc.statd tcp 0 0 :::631 :::* LISTEN 1/init # systemctl restart httpd.service Job failed. See system logs and 'systemctl status' for details. # tail /var/log/httpd/error_log tail: nie można otworzyć `/var/log/httpd/error_log' do czytania: Nie ma takiego pliku ani katalogu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@jszubiak Napisano Luty 9, 2012 Zgłoszenie Share Napisano Luty 9, 2012 Oooookej to teraz: grep -E '(^ServerRoot|^ErrorLog)' /etc/httpd/conf/httpd.conf lub gdziekolwiek miesci sie Twoj httpd.conf Zmieniales wiele w httpd.conf ? Pozdr. J.Sz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adampzb Napisano Luty 9, 2012 Autor Zgłoszenie Share Napisano Luty 9, 2012 # grep -E '(^ServerRoot|^ErrorLog)' /etc/httpd/conf/httpd.conf ServerRoot "/etc/httpd" ErrorLog logs/error_log nic nie zmienilem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@jszubiak Napisano Luty 9, 2012 Zgłoszenie Share Napisano Luty 9, 2012 ls -la /etc/httpd/ i ls -l /etc/httpd/logs/error_log Powolutku dojdziemy do sedna:-) Pozdr. J.SZ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adampzb Napisano Luty 9, 2012 Autor Zgłoszenie Share Napisano Luty 9, 2012 # ls -a /etc/httpd . .. conf conf.d logs modules run # ls -l /etc/httpd/logs/error_log ls: nie ma dostępu do /etc/httpd/logs/error_log: Nie ma takiego pliku ani katalogu luz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
