quazar Napisano Wrzesień 19, 2012 Zgłoszenie Share Napisano Wrzesień 19, 2012 Witam, Ostatnio w logu wyskoczylo cos takiego: Sep 17 11:02:18 fedora kernel: ata1.00: qc timeout (cmd 0x2f) Sep 17 11:02:18 fedora kernel: ata1: failed to read log page 10h (errno=-5) Sep 17 11:02:18 fedora kernel: ata1.00: exception Emask 0x1 SAct 0x7 SErr 0x0 action 0x2 frozen Sep 17 11:02:18 fedora kernel: ata1.00: irq_stat 0x40000008 Sep 17 11:02:18 fedora kernel: ata1.00: cmd 60/08:00:5d:db:1b/00:00:01:00:00/40 tag 0 ncq 4096 in Sep 17 11:02:18 fedora kernel: res 40/00:04:5d:db:1b/00:00:01:00:00/40 Emask 0x1 (device error) Sep 17 11:02:18 fedora kernel: ata1.00: status: { DRDY } Sep 17 11:02:18 fedora kernel: ata1.00: cmd 60/20:08:7b:74:87/00:00:1a:00:00/40 tag 1 ncq 16384 in Sep 17 11:02:18 fedora kernel: res 40/00:04:5d:db:1b/00:00:01:00:00/40 Emask 0x1 (device error) Sep 17 11:02:18 fedora kernel: ata1.00: status: { DRDY } Sep 17 11:02:18 fedora kernel: ata1.00: cmd 60/08:10:13:14:da/00:00:1a:00:00/40 tag 2 ncq 4096 in Sep 17 11:02:18 fedora kernel: res 40/00:04:5d:db:1b/00:00:01:00:00/40 Emask 0x1 (device error) Sep 17 11:02:18 fedora kernel: ata1.00: status: { DRDY } Sep 17 11:02:18 fedora kernel: ata1: soft resetting link Sep 17 11:02:18 fedora kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) Sep 17 11:02:18 fedora kernel: ata1.00: configured for UDMA/133 Sep 17 11:02:18 fedora kernel: ata1: EH complete Sep 17 11:02:18 fedora kernel: sd 0:0:0:0: [sda] 488397168 512-byte hardware sectors (250059 MB) Sep 17 11:02:18 fedora kernel: sd 0:0:0:0: [sda] Write Protect is off Sep 17 11:02:18 fedora kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 Sep 17 11:02:18 fedora kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA a dzis w mailu logwatch pojawilo sie: Currently unreadable (pending) sectors detected: /dev/sda - 96 Time(s) 1 unreadable sectors detected Czy to oznacza koniec dysku? Co z tym zrobic? Help... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Wrzesień 19, 2012 Zgłoszenie Share Napisano Wrzesień 19, 2012 Co z tym zrobic?Backup Mozesz potestowac np. smartctl --test=long /dev/sda Wiecej szczególów w "man smartctl" no i Google. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
quazar Napisano Wrzesień 19, 2012 Autor Zgłoszenie Share Napisano Wrzesień 19, 2012 dzieki, backup robi sie codzien wybrane informacje z smartctl: 197 Current_Pending_Sector 0x0012 200 200 000 Old_age Always - 1 Error 1 occurred at disk power-on lifetime: 39291 hours (1637 days + 3 hours) SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 39341 - # 2 Short offline Completed without error 00% 208 - # 3 Short offline Completed without error 00% 32 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing mam RAID 1 , nie wiem czy wymieniac ten dysk od razu czy czekac jak sie to rozwinie? Backup Mozesz potestowac np. smartctl --test=long /dev/sda Wiecej szczególów w "man smartctl" no i Google. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Wrzesień 19, 2012 Zgłoszenie Share Napisano Wrzesień 19, 2012 Czy to oznacza koniec dysku? Co z tym zrobic? Help... W moim przypadku takie zapisy w logu oznaczaly koniec dysku. Mój (WD3200AAKS) nie mial nawet bad sectorów. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
quazar Napisano Wrzesień 19, 2012 Autor Zgłoszenie Share Napisano Wrzesień 19, 2012 odpalilem smartctl --test=long /dev/sda ale pojawia sie # 1 Extended offline Aborted by host 90% Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Wrzesień 19, 2012 Zgłoszenie Share Napisano Wrzesień 19, 2012 [...] czy czekac jak sie to rozwinie?Wg mnie rozwijac to sie moze tylko w jedna strone, wiec po co utrzymywac RAID na walnietym dysku? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
quazar Napisano Wrzesień 19, 2012 Autor Zgłoszenie Share Napisano Wrzesień 19, 2012 no tak, po co siedziec na nadpilowanej galezi, tylko jak teraz ten dysk wymienic , przy sprzetowym raid trzeba jakos nowy dysk przygotowac? gdzie znajde jakis rzetelny opis...? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
