Instalacja Skype W F 21 64 Bit
Rysio
Po dodaniu russian repo:
yum install -y skype
Noi skończyło się to tym :
--> Ukończono rozwiązywanie zależności
Błąd:  Multilib version problems found. This often means that the root
      cause is something else and multilib version checking is just
      pointing out that there is a problem. Eg.:
        1. You have an upgrade for cairo which is missing some
           dependency that another package requires. Yum is trying to
           solve this by installing an older version of cairo of the
           different architecture. If you exclude the bad architecture
           yum will tell you what the root cause is (which package
           requires what). You can try redoing the upgrade with
           --exclude cairo.otherarch ... this should give you an error
           message showing the root cause of the problem.
        2. You have multiple architectures of cairo installed, but
           yum can only see an upgrade for one of those architectures.
           If you don't want/need both architectures anymore then you
           can remove the one with the missing update and everything
           will work.
        3. You have duplicate versions of cairo installed already.
           You can use "yum check" to get yum show these errors.
      ...you can also use --setopt=protected_multilib=false to remove
      this checking, however this is almost never the correct thing to
      do as something else is very likely to go wrong (often causing
      much more problems).
      Chronione wersje multilib: cairo-1.13.1-0.4.git337ab1f.fc21.i686 != cairo-1.14.0-2.fc21.x86_64
Błąd: Chronione wersje multilib: libgpg-error-1.13-3.fc21.i686 != libgpg-error-1.17-2.fc21.x86_64
Z tego co widzę to yum chce instalować zależne pakiety dla systemu 32 bit (wklejam kawałek z zależnościami)
---> Pakiet libselinux.i686 0:2.3-5.fc21 zostanie zainstalowany
--> Przetwarzanie zależności: libpcre.so.1 dla pakietu: libselinux-2.3-5.fc21.i686
---> Pakiet libtheora.i686 1:1.1.1-12.fc21 zostanie zainstalowany
---> Pakiet libuuid.i686 0:2.25.2-2.fc21 zostanie zainstalowany
---> Pakiet libvisual.i686 1:0.4.0-17.fc21 zostanie zainstalowany
---> Pakiet libvorbis.i686 1:1.3.4-3.fc21 zostanie zainstalowany
---> Pakiet libxshmfence.i686 0:1.2-1.fc21 zostanie zainstalowany
---> Pakiet mesa-libglapi.i686 0:10.4.3-1.20150124.fc21 zostanie zainstalowany
---> Pakiet ncurses-libs.i686 0:5.9-16.20140323.fc21 zostanie zainstalowany
---> Pakiet orc.i686 0:0.4.22-3.fc21 zostanie zainstalowany
---> Pakiet pam.i686 0:1.1.8-16.fc21 zostanie zainstalowany
Sprawdziłem i większość pakietów jest już zainstalowana dla wersji 64 bit.
Jak to obejść ?
Raczej nic z tym nie zrobisz jeśli Skype wymaga biblioteki o niższej wersji niż zainstalowana. Można mieć biblioteki 32- i 64-bitowe (instalują się w /lib albo /lib64 odpowiednio), ale muszą być w tej samej wersji. Np. u mnie
[waldo@F21 ~]$ rpm -qa cairo
cairo-1.13.1-0.4.git337ab1f.fc21.x86_64
[waldo@F21 ~]$ rpm -qa libgpg-error
libgpg-error-1.13-3.fc21.x86_64
Ciekawe skąd wytrzasnąłeś cairo-1.14.0-2.fc21.x86_64 i libgpg-error-1.17-2.fc21.x86_64? Aktualizowałem system i mam jak widać 1.13. Czy nie masz włączonego jakiegoś repo testing?
Jeśli masz włączone to wyłącz.
Spróbuj usunąć zbyt wysokie wersje bibliotek i wtedy Skype się zainstaluje. Obawiam się tylko, że możesz mieć śmietnik w systemie i takich zawyżonych wersji może być więcej a próba ich usunięcia spowoduje odinstalowanie połowy systemu.
Zwróć też uwagę na pkt.3. komunikatu.
Być może warto też sprawdzić (tylko myśleć przy tym trzeba)
package-cleanup --cleandupes
Możesz sprawdzić czy zadziała
 yum downgrade cairo-1.14.0-2.fc21.x86_64 libgpg-error-1.17-2.fc21.x86_64
Ale coś czuję że albo Skype albo reinstalacja systemu i tym razem rozsądek przy instalacji i późniejszych aktualizacjach. Edytowane przez WalDo
No tak coś mi się kojarzy że bywało że miałem biblioteki 32 i 64 bit w systemie. A co do repozytoriów to te testing mam enable=0 więc trudno mi powiedzieć skąd się wzięło cairo w takiej wysokiej wersji.
System instalowałem dla kolegi i troszeczkę "rozdarty" pomiędzy różnymi innymi zajęciami. Może czas zaleczy rany i wyjdzie nowsza wersja SKYPE. Póki co odinstalowanie połowy systemu to może być strzał w kolano bo mam na razie tylko zdalny dostęp.
 Dzięki za pomoc, może w wolnej chwili uda się ściągnąć ręcznie pakiety o niższej wersji i je zainstalować.
Myślę, że możesz spróbować odinstalować bez zależności, chociaż instalacja od nowa byłaby pewniejsza. Z tego co mówisz system jest nowy, więc może nie warto się z tym babrać.
rpm -e --nodeps cairo-1.14.0-2.fc21.x86_64 libgpg-error-1.17-2.fc21.x86_64
yum install cairo.x86_64 lipgpg-error.x86_64
